Question about Whirlpool LGR6636 Gas Dryer
Whirlpool gas dryer LGR6636PWO heats for appro. 5 minutes & quits heating but still runs.
    President:
  • 1,015 Answers
It sounds like the dryer might be overheating due to possible restricted moisture vent. What happens is the moisture vent can be restricted from a collapsed vent hose or built-up lint inside the vent hose and/or pipe inside wall. When the dryer is running go outside and see how much volume of air is coming out of the dryer vent cover. Verify there is plenty of air flow and no restrictions in the pipe screen. If the air flow feels low then remove the hose at the back of the dryer and verify the air flow is good.
Posted on Oct 04, 2009
  • Whirlpool Master
  • 3,361 Answers
First check the exhaust vent and connecting vent material for a clog. If vent is OK,replace the gas valve coils.
The dryer wont heat-it over 5 hrs to dry a load. it would not turn off on automatic side & just keeps running. it turned off on the timed side
If it's not making heat the humidity sensor will never dry out, therefore it keeps running. It sounds like your heating element is bad.
Jan 20, 2014 | Whirlpool GGW9200L Gas Dryer
Whirlpool Estate gas clothes dryer runs but the heat only lasts for about 10 minutes. the drum will be turning the heat will be on but only for about 10 minutes.After 10 minutes the drum will still be...
The gas coils have failed. These are the two round devices on the gas valve. You would need to open the dryer to access and replace the gas valves. Every make and model is different.
With the model number I would be able to better assist you.
Mar 31, 2011 | Whirlpool Dryers
I replaced the fuse and the coils for my Whirlpool dryer because it would heat up and then the flame would go out after it ran for 5 - 10 minutes. Now what could it be? Whirlpool Gas Dryer LGR8648LW0
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 19, 2010 | Whirlpool Dryers
Whirlpool gas dryer we have the ignitor comes on, gas lights, runs for a minute and shuts off. After about a minute the ignitor comes back on but the gas does not. thanks
heatman101
Aug 17, 2010 | Whirlpool LGR8648L Gas Dryer
Quit heating. occasionally it will heat for about 5 - 10 minutes, then goes cold. does this on both sensor drying and regular drying
This could be a couple of things.
First I am assuming that this is a gas dryer.
The most likely is the coils on the gas valve are failing your description of problem is a classic coil failure. However not very likely but this could be the gas valve or the flame sensor.
If I can help you further please let me know. For any further help I will also need an exact model #.
Apr 15, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer quit heating runs fine it is a gas dryer
Is the pilot light or "stricker" working when you start the unit.. Is it getting good supply of gas?
Mar 12, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Dryer wont heat up already replaced thermal fuse
You gas coils are probably old and weak. check this out
Gas dryer works and quits
Apr 11, 2009 | Whirlpool Dryers
No heat after a minute of drying
Your GAS dryer has no element.
You should remove the vent from the rear of the dryer.
Run on hi heat with no laundry.
Your exhaust temperature should be from 130 to 165 degrees.
If not you have a thermostat problem or a ignitor/gas valve problem.
Feb 21, 2009 | Whirlpool LGR3624JQ Gas Dryer
Gas Dryer quit heating today
Just click below;
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Hope it may help you;
Regards;
VOTIT
Jan 28, 2009 | Whirlpool LGR8648 Gas Dryer
Whirlpool LGR6636 Gas Dryer Logo
356 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
