Question about Garden
John deere bp 20(Kawasaki engine) cranks when cold but only runs a few seconds, wont rev and then wont do anything once it gets warm
boscia
  • 163 Answers
SOURCE: I need a replacement gas cap
try www,jackssmallengines.com
Posted on Nov 30, 2008
  • 246 Answers
SOURCE: John Deere 14SB mower with Kawasaki FC150V series - Throttle adj.
Hello rfbarrett:
From your Description it Sounds like the Plate that is Attached to the Carburetor (that the Throttle cable Attaches to) Thru Shaft (holds and Moves the Throttle Valve) has Loosened and is Simply Turning on the Thru Shaft and Not Moving the Thru Shaft and Throttle Valve at All.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers 14SB and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
moretons
  • 155 Answers
SOURCE: John Deere 14SB (with Kawasaki FC150V motor). It
sounds like the valve clearences need adjusting they should be set at 0.004 thou you should be able to find an exploded view at pats small engines site.
Posted on Aug 12, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
  • 64 Answers
SOURCE: John Deere 212 loses power after 20 minutes and
probably just carbon shot out. it sounds like your ignition coil is bad.
Posted on May 04, 2010
I have a John Deere Gator 825i that that starts hard and once it does start it smokes for a few seconds then it runs clear after that. The engine does not use any significant amount of oil either.
They have a throttle body fuel injected engine. If its hard starting then smokes usually that indicates pour fuel quality or something wrong with fuel system.
Nov 07, 2017 | John Deere Garden
John Deer 175 hydro garden tractor, Kawasaki FC420V engine wont crank when key is turned. Stopped cranking yesterday. Previously on occasion had to turn key on and off a few times to crank.
bad starter or bad ignition switch. try putting it in gear and rock it back and forth, if it starts then you have a dead spot in the starter.
Jun 11, 2017 | kawasaki Garden
John deere gx345 has no spark at plug what is the cause?
need new coil pack or have short in harness grounding engine from running. check fuel line to carburator. 1. take float bowel off bottom of carb. do not touch float or pin holding float. crank engine over until fuel comes out of carb. If fuel comes out, you don't have fuel problem. put float bowel back on carb. 2. check for spark. take spark plug out of mower. put wire back on plug and place the threads on head [or metal of engine to ground the plug]. crank engine over for a few seconds to see if plug gets spark . [always double check with another spark plug that is good]. [[ Remember!!! you have to have someone sitting on the lawnmower to start. unless you by-pass safety switch [only do this if you understand how the safety switch works. NOT EXPLAINED HERE!!!]] If spark is present, there is no grounding problem. when engine is cool. 3. CHECK COIL PACK. for continuity. When the coil pack gets hot it will stop any juice to the plug. A>Check temp sensor B> Check Safety switches grounding out. C> Check for cut wiring harnes. [loose wires rubbing against pulleys, wires cut by rodents]. Hope this helps.........................GAS
Jun 13, 2012 | John Deere 420,1020,2010,2020,2510,2520...
John Deere X304 PTO Engagement Problem When Warm
Hi, check your belt tension, check all idler pulleys and drive pulleys for free rotation with the belt off and finally check that the belt is not bottoming out in any of the drive pulleys. If so, replace the belt. The blades should come up to speed imediately wether hot or cold and it sounds like your belt is slipping in one or more of the pulleys which drags the motor revs down until it grips. Regards Phil.
Jun 13, 2012 | John Deere Garden
My John Deere 345 dies for no apparent reason
You have dirt in the fuel tank and it sucks the dirt up on the filter that is attached to the pump. After the machine stalls, the dirt falls off and it will restart and run for a few min.
Oct 02, 2009 | Garden
Cam shaft is not turning when i crank engine model 425 john deere
I'm guessing you have a 7-10 year old Kawasaki engine with the plastic cam gear, that is missing teeth.
Kawasaki has a service bulletin on this,they have changed to a steel gear. your Kawasaki or John Deere dealer will have that info.
Sep 19, 2009 | Garden
20 Hp (kawasaki) John Deere GX255 tractor over revs when cold.
the engine is icing up. Kawasaki may have a winter kit available. I have solved the problem it the past on other engines by partial blocking the air intake screen with cardboard. Cut a piece of heavy card board the same size as the intake screen cut a few pizza slice shapes out and zip tie it to screen. remove in the spring. refer to owners manual if you are unsure what the air intake screen is.
Dec 18, 2008 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
