Question about Olympus SP-350 Digital Camera
The camera won't turn on even on new batteries. It got wet with water but not soaked.
Won't turn on
possible battery problem. look at battery contacts. clean w/ pencil ereraser or small scraping devise.GENTLY, on battery and camera.
possible dead battery even if new.even if you buy a new battery, clean ththe contacts an battery and camera.
Sep 25, 2012 | Kodak EasyShare DX6490 Digital Camera
My Panasonic Lumix TZ5 died after apparent exposure to drinking water several days ago. It was turned off with battery installed and in a leather carrying case which was soaked. I removed the battery...
The only way to fix this problem is to get it repaired.The water has entered into your camera and it is possible that motherboard inside has been burnt or there is still some water inside. you can try one home remedy.Take you camera apart and then blow a compressed air or you can use a hair dryer to dry water inside.
Jul 22, 2008 | Cameras
My olympus tough tg-310 got wet inside with salt water form the beach now it won't turn on please help.
There is very little that can be done, salt water will corrode metal on contact, all eletronic parts have been compromised, if the memory card is still intact save your pictures and remove it from the camera to transfer to new hardware. Replacing the camera unfortuneately is the only option.
Apr 02, 2012 | Olympus TOUGH TG-310 Digital Camera
DSC-T70 camera got wet and now won't power on. Battery seems to charge fine.
I'm guessing you tried to turn it on way too soon and fried the circuits. A camera with fresh water damage should be buried in a bowl of dry rice for a week before even attempting to turn it on. Salt water damage?....chances of a complete recovery are slim to none.
Jul 24, 2011 | Sony Cyber-shot DSC-T70 Digital Camera
It got wet on the beach. water went into the camera and it won't start anymore.
The best way to try to recover items that have had water damage is to place them in a container with the gel packs you find in new shoes. If none of those are available to you try putting the camera in a ziplock bag with rice. This will absorb any moisture left in the camera. Take out the battery and memory card before trying either of the prior options.
After you have let the camera sit with the gel or rice overnight or for several hours, remove the camera from the bag and blow off any dust from the rice. Make sure that the inside of the camera is clean and dry (where the battery goes) Then put the battery and memory card back in. Make sure that the battery is fully charged and try turning it on.
If that doesn't work try going to a specialty camera store such as B&W. They can help you further and instruct you on how to procede.
It is advised not to get any digital electronic wet as most are not water proof and will be damaged by any exposure to water.
Jul 02, 2011 | Cameras
My Panasonic Lumix DMC-TZ3 was soaked in water. It isn't working, will it work when it drys out?
It depends on how wet it was, if the entire thing was submerged, or even a large portion, it probably will not.it may turn on but it is likely that the lens will be damaged permanently. However if it was just wet upon the outside, like it was used out side during a rain fall, and then wiped dry every thing should be fine.It all depends,try drying it out thoroughly, letting it sit out with all lens caps and lens attachments removed, battery doorway open. is the best thing you can do. I hope that everything works out for you. God bless...
Aug 17, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
My daughter has the fuji finepix that is white with pink polka dots. she took it to the beach and it was wrapped up in a towel, the tide came in and got the towels a little wet but not soaking wet, she...
you did good and removing the battery and memory card was also a good idea....leave the unit for a couple days the way it is...check later to see if there is any white or green residue(powder) or rust looking areas around the memory card and battery location...if it seems clear then it should be fine, if you see any type residue, then water got into the unit and is starting to corrode it...which means 2 things...either buy a new one or you can still try to salvage this one by having it opened and cleaned out with acetone and dried up completely..then for sure it will be good to go..but first try what I suggested
Aug 15, 2009 | Fuji FinePix Z10fd Digital Camera
LED Problem
try clining it using brushteeth and a lilbit of medical alcohol
the n dry it witha hair dryer teh tell me what u got
plz do rate this post
Sep 24, 2008 | Nokia N73 Cellular Phone
Camera got wet and now drains new batteries
Replace it a wet damged camera seldom survives
Nov 19, 2006 | Canon PowerShot A95 Digital Camera
Olympus SP-350 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
