Question about Teac Audio Players & Recorders
Tascam PA-150, won't power up. There a brief flash of the clip lights. No light at power light. No burnt components on the board. Looking for a service manual or service center. North Los Angeles area.
SOURCE: What is the ohm and taper value of the input pot
Hi doc2714,
The Ohm and Taper Value is " 4 ohms or 115W per channel at 8 ohms "
for more details here is a link providing you with full specifications to your Amp.
http://www.broadcaststore.com/pdf/model/19184/tascam_pa-150.pdf
I hope this helps.
Posted on Mar 27, 2011
  • 484 Answers
SOURCE: Looking for a Service Manual for Sansui AU 9500 Amp. more detailed than the Operating Instructions and Service Manual available on the Web.
I hope this schematic diagram will help you find the problem of this amp.
Try to give signal to the aux input and trace and find where the signal disappears.
When you get to the site using the link it is possible that you have to wait a little bit to be able to download.
After waiting you should see a button as "Get Manual" and simply click on it and save the file.
Thanks.
gylacz
Posted on Jan 03, 2012
Trippynet
  • 47 Answers
SOURCE: Power Block SOUNDSPACE 5
I have the needed information.
Posted on Feb 18, 2008
ladywinn
  • 5138 Answers
SOURCE: electronic component retail store los angeles
Electronix Parts look up on line they list all kinds of parts or call 1-800-223-3205
Posted on Dec 19, 2008
SOURCE: brothers service center in the Philippines
Try this one, hope this can help you out.
PHILIPPINES
Address : Brother International Philippines Corporation
6th Floor Marajo Tower,
312 26th Street West corner 4th Avenue
Bonifacio Global City,
Taguig City, Philippines
URL :
http://www.brother.com.ph/
Email Address : :sales@brother.com.ph
Phone : 632-581 9800
Fax : 632-581 9811
Posted on Mar 18, 2009
LG 47LN5400 blank screen after brief flash
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 12, 2016 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
Tv lcd inverter problems
May 28, 2016 | Televison & Video
Has audio and a black screen. Why is there a brief flash of video every 8 seconds?
http://electro-medical.blogspot.com/
Jan 18, 2016 | Televison & Video
The sreen does not light up when turned on
remove back panel and check fuses for simple fix but replacing fuse may further damage already damaged or burnt components.
Inspect boards for burnt components and inspect the solder joints of hot areas typically noticeable by dark areas on the boards.
Jan 21, 2014 | Televison & Video
What is the ohm and taper value of the input pot on the Tascam PA-150 Dual Power Amp?
Hi doc2714,
I hope this helps.
Mar 27, 2011 | Tascam Audio Players & Recorders
Craftman Garage Door Opener (Mdl: 139.53992) stopped working today. We had bad storms last night with numerous brief power outages. Light on back is now flashing orange. I can't get the opener to...
I would first of all unplug the opener for at least 15 minutes and see if it doesn't reset. If not, pull the logic board and check for burnt or missing traces on the printed circuit board.
Aug 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do i reset my fw 1082
I have the same problem. To reset you have to hold down the first row (horizontally) and third row of buttons on the upper left side (6 buttons in all) and power on the machine. The lights should all flash and come back on.
This reset does not however fix the problem that all the lights remain on. Has anyone found a fix to this? I've read that this is caused by a "burnt" out firewire card (due to the flaw in design that the card in the system draws too much power from the computer).
I've also read that the card is somewhere between $150 and $300...
My advices to anyone getting this thing... get as long a warranty as possible, because it will probably break after 4-5 years of light to moderate use.
Dec 20, 2008 | Tascam FW-1884 Firewire Audio / Midi...
I have a panasonic plasma th-42px60 tv for about a year and a half now when i changed the fuse in the plug the power led light is flashing but there is no picture
Panasonic shows multiple board replacement in sequence of boards that may be the problem. they start with the PA board as the most likely culprit start with that. how ever there may be 6 other boards that can cause a 10 flash code.
the PA board part # is TXNPA1BJTUJ.
Mar 13, 2008 | Televison & Video
300 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
