Question about Bosch Dishwashers
Bosch dishwasher not cleaning bottom rack
The dishes on the bottom rack are suddenly not getting clean. We have taken the bottom sprayer off and ran water through it and there doesn't seem to be a obstruction. What do we do next?
  • 87 Answers
SOURCE: Top rack dishes have grainy particles on them after washing and will not come clean.
Run the dishwasher and observe the spray arm,if split it will spray water down: Also check water in tub, is it filling up sufficiently to get near the heater? If it has a upper spray arm does it spray water? If not you may have a clogged upper spray arm.
Posted on Jun 08, 2007
SOURCE: Top rack remains dirty
spin the top rotary arm to make sure it spins freely also take it off to see if its blocked (run it under tap) check all other filters too and when you load dishes make sure they do not obstuct top rotary arm if none of this works then it's time for an engineer im affraid good luck
Posted on Jan 27, 2008
SOURCE: Bosch dishwasher
We were told by Bosch to not use lemon scent. Use the original generic soap with NO sprakle or smell because the jet dry does the rest. Just let the soap be soap. Hopes this helps.
Posted on Feb 20, 2008
  • 105 Answers
SOURCE: dishes not washing clean
check water level in machine
may be not filling enough and the wash pump is starved from water thus not pushing water to upper arm
drain water from machine dismantle and clean out air tube to pressure switch take off air tube at pressure switch and blow back into sump then pinch air tube with fingers to stop air from flowing back up tube then refit to p/s
run and see if that solves problem
Posted on Feb 24, 2008
SOURCE: Dishes not cleaning particularly on top rack
Thank you, so much, for the update!
Posted on Jun 18, 2008
Why doesn't the top rack of my dishwasher clean dishes?
the water tube may be clogged at the sprayer on the top of the basin. probably have to disassemble and clean
Apr 14, 2016 | GE Dishwashers
My dishwasher doesn't clean the all the dishes, esp on top rack
Check the jet holes on the sprayer arms. The outside holes usually plug first from calcification and centrifugal force causing only the center areas to clean. Remove these arms and shake out all of the "little white rocks" and then run the machine empty with a de-calcifying cleaner.
Sep 15, 2014 | Bosch Dishwashers
I have a Kenmore dishwasher, purchased in 2000, it is not cleaning the dishes on the top rack, just happened all the sudden.
You should check to make sure that the lower sprayer is extending to spray the bottom of the top rack and that water is being pumped up to the top sprayer. You will need to take the dishwaher out of the cabinet to test.
Jul 15, 2011 | Kenmore Dishwashers
We have a 2007 LG ldf6810ww dishwasher that suddenly is not getting dishes in the upper rack clean, nor is it fully removing the soap from its dispenser. I assume they're related and due to a lack of...
I once had gunk in the rotating sprayer itself that was blocking the dispenser opening properly? I reckon a thorough cleanse with a dishwasher cleaning detergent (the one that takes a super wash to do it) and check the joke a chicken bone was in one of them!!
Aug 19, 2010 | LG LDF6810ST Stainless Steel Built-in...
I don't beleive my sprayer arm is working on the bottom of DW
The problem is hard water and your softener must not be taken it all out. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to to find out more info.
May 05, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
We have a GE dishwasher with upper and lower sprayers. The upper sprayer (one located right under top rack) won't spray or turn which leaves the dishes in upper rack dirty, any suggestions on how to fix...
try c.l.r. to clean dishwasher check and clean lower and upper spray arms out, run no detergent you can also run vinegar in it as well about a cup full,let the machine start to run then stop dish washer for a few hours then restart see if this works for you use a short cycle.
Dec 01, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Our dishwasher is approximately 13 years old. Today I turned it on and it did not clean the dishes. After trying to wash the dishes three times, the dishes on the bottom rack were clean but the top rack...
13 years old?!? LOL, you're lucky it turns on!!!
Pop the sprayers off and check for clogs. Otherwise, get a new one, this machine is way, way, way past its life expectancy.
Nov 20, 2009 | Magic Chef Dishwashers
Top rack whisperquiet dishwasher no water
I know this isnt the same model, they dont carry your manual as of yet. But it does have some suggestions to look at on page 17. I had the same problem and I looked really carefully and found my sprayer arm was blocked. I cleaned it out and havent had a problem with it again. I do check it regular now.
Sep 27, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
My whisper quiet dishwasher is not cleaning the top rack dishes
I'm having the same problem. Did some testing and found that the sprayer on the top rack is not even moving and hence not getting any water. Not sure what to do.
Sep 07, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Dishwashers Logo
124 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
