Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
Hotpoint CSX22GR water/icemaker connection
I have a hotpoint CSX22GR and I'm missing the water connection from the wall water faucet to the fridge. Can you tell me the part number so I could buy this part? Thanks.
  • 454 Answers
You should be able to buy a generic water hose at your local hardware store.
Posted on Oct 04, 2009
My lg refrigerator lsxs26326 is dispensing water but not filling ice tray up. What could be wrong?
the water solenoid valve for the water dispenser is separate from the icemaker water supply solenoid valve . get to the icemaker water supply solenoid and test it if it works alright . unplug the fridge from wall outlet do not close water supply valve. disconnect water tube connection on the water discharge side of the icemaker water supply solenoid valve . pull - out power supply connection of the solenoid coil . connect solenoid valve directly to wall outlet. a faint click should be audible and water should come out from where the tube was removed -- from the water supply discharge side. if no water is coming out with the solenoid plug in , then the solenoid is faulty. but if water comes while solenoid is powered -on , check the position of the icemaker lever. if it is on off position icemaker timer won't activate icemaker water supply valve..move icemaker lever to on and check for water pouring into the icemaker tray' if no water comes out . change the icemaker timer. thanks.
Mar 04, 2016 | LG Refrigerators
Hotpoint refrigerator leaking water from hose underneath
It sounds like this may be coming from the icemaker water valve. If the refrigerator is an older one the tubing gets brittle and cracks. Check this first. But the water valve is usually on the left side in the back.
Apr 09, 2014 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
My ice maker is not bringing water up to make the ice
Pull the refrigerator out from the wall so that you can get behind it. Make sure that the faucet is turned on. (You might to desonect the fitting from the faucet to make sure that water is coming thru the faucet.) Assuming there's water there, follow the water line to the fridge, checking for any kinks that might stop water from flowing. There may be a panel down below that needs to be removed. Check the connection to the fridge. there might be a shut-off valve there. Make sure that's turned ON. Most fridges have the water line exposed on the back of the fridge. Follow the line , again checking for any kinks. Now the line goes inside the freezer. Make sure the connection is secure. Now, on most ice makers there is a box on the front of the icemaker that's removable. Inside is the switch that varies the size of the cubes. There also might be an on/off switch. Make sure it's on. That's it from me. Good Luck!
Jan 16, 2014 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
I cant find the filter on my hotpoint no frost refridg.number csx22gr where is it.
your model number doesn't come up.if it's an older machine some didn't come with water filters,you had to add an inline filter on the copper water line,you would run your copper,go down the cellar or behind the machine,cut the copper and the filter connects in between the copper where you cut the line.if you do have a filter it could be in the fridge section top right side or down in the bottom kickplate.i found your model the a was missing after the b baww.it doesn't show a filter,this is an older unit,check behind or in basement,wherever the water line goes and see if there's a filter added into it,if not you can cut the copper and add a filter yourself.home depot sells them
http://www.homedepot.com/p/Whirlpool-In-Line-Refrigerator-Water-Filter-4378411RB/202204720#.Ug7jNxXD_X4
Aug 16, 2013 | Hotpoint 21.7 cu. ft. Side-by-Side...
WMUD962p not taking water
Possible the filters in the inlet of your machine (top behind) are clogged. It is simple to clean out, refit carefully. Plug off the machine, unscrew the inlet water connection just behind machine to check fine filters. The water from your wall faucet should have good pressure.
If helped, pl click.
Apr 16, 2013 | Hotpoint Washing Machines
Can the icemaker on my hotpoint no frost fridge freezer s/s be turned off
Just turn the water off at the connection point behind the frige. otherwise you will have to disconnect the connector behind the side wall of the ice maker by removing the ice maker.
Jan 23, 2011 | Refrigerators
No ice
Pour about 1/2 cup of water into icemaker . If it freezes and dumps , the water valve is bad ( where the wall water line connects to the fridge ) . If it freezes and does not dump and the ice stays in the icemaker , replace the icemaker . Also check the fill tube ( the tube going from the freezer wall to the icemaker itself ) to see if it has frozen closed . If it has , the water valve is not closing completely , and letting a drop thru and freezing in the tube . Also an indication of a bad water valve .
Aug 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Hotpoint CSX22GR water dispenser not working
Sounds like to me your filter needs replaced...how long ago have you changed them?
Jul 18, 2008 | KitchenAid KSCS25FKSS Side by Side...
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
263 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
