Vizio HDTV now has grey haze with lines over picture
You can see computer screen anbd TV screen but there is a grey haze overthe color that Vizio could not help me fix by reseting everything
  • sbarbaro584 Oct 07, 2009
    Vizio HDTV now has grey haze with lines ove...You can see computer screen anbd TV screen but there is a grey haze overthe color that Vizio could not help me fix by reseting everything
    President:
  • 1,734 Answers
I think you will need to remove the back (be careful, this is only for professinal technicians). I am somewhat familiar with what is happening here - it has to do with the driver circuits, there are several and each controls a 'strip' of the screen.
We are going to have to look around for bad components. Do you have a multimeter and soldering tools?
Posted on Oct 07, 2009
  • 3,230 Answers
Well most likely problem is in the display panel, may be need a replacement. or might just be a loose solder joint, if you are lucky, you need a multimeter to check the panel...
post further comments for more help and information....
Thanks
Posted on Oct 04, 2009
How to fix a damage screen for a vizio vf550m
Vizio Flat Screen Repair - All - Instructables
www.instructables.com/id/Vizio-Flat-Screen-Repair/
InstructablesWhere can I get a replacement screen for a Vizio 70" that cracked. Model .... Is there a repair to resolve this problem and where do I find information? IMadeIt
Vizio TV cracked how to fix this? - YouTube
? 0:22
https://www.youtube.com/watch?v=d3wSCSfatjQ
Jan 27, 2014 - Uploaded by mario gutierrez
Find out how to repair this? I have the ... Cracked TV Screen - LCD & LED TV Panel Repair Options & Replacement ... VizioFlat Screen Repair.
Dec 10, 2015 | Vizio VF550M 55 in. LCD HDTV
Bought it used and the previous owner only used it in his salon. It worked fine for about a month and then I ended up with a line that went right to left and noticed two shaded boxes. I have been noti
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 02, 2014 | Vizio 55" VF550XVT1A 1080p 120Hz HDTV LCD
Vizio TV has purple haze and colored stripes on the sides of the picture.
You possibly have a failing hi-voltage module or fly-back transformer going bad. If it has a fly-back transformer, It's not worth the trouble. Some repair shops will sell you a module. Call a repair shop for help.
May 09, 2017 | Vizio Televison & Video
My TV all of a sudden turned white and grey.
First, try to play DVD on your tv to determine if the problem is on TV itself. If the TV looks fine on DVD you have cable box connection problem if not you have faulty t-con board not bulb etc.
T-con is the responsible for colors and image graphics.
Dec 10, 2012 | Vizio VS42LF 42 in. LCD HDTV
Screen turned black except vertical color lines in the center
good day your vertical ic is defective needs to replace look for qualified technician to fix your tv
Jun 20, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Yellow haze on screen
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 29, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Mar 14, 2010 | Vizio VW42LF 42 in. LCD HDTV
Screen flashing ribbons of color over picture
i think its your cable box. check it carefully.
May 25, 2009 | Vizio VA26L 26 in. LCD HDTV
Yellow Haze Center Screen
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
Mar 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
