Question about Cameras
Where is the ir receiver on a Bell Express VU 5900 DVR receiver?
  • 24 Answers
SOURCE: bell express vu remote codes for soyo tv
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Posted on Feb 25, 2009
  • 24 Answers
SOURCE: need codes for bell express vu satellite
Press and hold tv until red light flash , press code search , press channel up until the tv goes off , then press record and your done
  • 24 Answers
SOURCE: need codes for jumbo universal
Press the tv and hold it until the red light flash , then press code search , press channel up until your tv goes off , press record and that it your done . Will work for your tv but maybe not for the express vu receiver , this way of finding code makes the remote trying them all so if it dont work on your express vu remote , no other codes will .
SOURCE: No audio
Hi, I had a similar problem. I had my cable plugged in to the HT through the optical. All of a sudden it stopped working and the receiver started flashing PCM FIX. The solution is press and hold shift and Digital IN buttons and the setting changes to AUTO from PCM FIX.
Posted on Jun 09, 2009
  • 5 Answers
SOURCE: I need 3 digit code for my Prima tv to program bell express vu
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Posted on Aug 23, 2010
No power to receiver
Someone should at least open the unit to see if a fuse is blown etc.
May 04, 2012 | Televison & Video
I have direct tv dvr my remote wont work,but remote works on my other recivers,has the ir gone bad and can it be fixed
It's possible that the IR receiver in the DVR has failed. It's unlikely to be the remote as it works with other devices. If the remote was working with the DVR before, then in most cases the problem can be corrected by resetting the DVR as follows:
Press the RED RESET BUTTON behind the access card panel on the front of the DVR. Wait for the program guide information to update then try the remote again.
Try this and post back if you need further assistance.
Regards,
BElectric
Dec 07, 2010 | Directv Plus DVR DTV Receiver / 100-Hours...
I need a free online manual for my Bell Express Vu 3100
Try this:
http://support.bell.ca/en-on/tv/receivers/3100_receiver_user_guide
Sep 03, 2010 | Televison & Video
How to program 9242 remote to work with my Bell
The following instructions will enable the Bell 9242 remote to operate a Bell 5900 receiver. Remove back battery cover. Just below the "Bell" lettering on the front of the remote, there is a half moon shaped plastic insert "key" that slids out downward. Turn over the plastic key and reinsert back into postion and replace the battery cover. Success!
Oct 13, 2009 | Bell Televison & Video
Remote problem
Considering that none of the so-called 'universal' remotes really are, I would guess 'no' and this remote was designed for a specific system so your chances are even slimmer.
Before buying ANY 'universal' remote, check the remote mfr.'s website for a code list for the specific model you intend to buy and make sure that the devices you wish to control are included in that model. If you don't do this in advance, you will likely be disappointed.
The code lists are 'burned' into an IC in the remote and the only type that can accept new code sets are the 'learning' remotes and they do a lousy job; I own one of these and it will not accept input from either of my later TV set remotes.
Apr 14, 2009 | DISH Network IR Remote Control
Check in ur television option , try finding the problem by thinking the problem is not in the bell receiver , because im almost sure its not ... Give it a try im sure its worth it
Feb 05, 2009 | Samsung HCN4226W 42" Rear Projection...
Bell express vu remote codes for soyo tv
5-Press record
Jan 02, 2009 | Soyo Crystal DYLT032B 32 in. LCD...
Need codes for jumbo universal remote for phillips tv and bell express vu
Dec 08, 2008 | 2006 Honda ANF125 Innova
Home Theartes
Trying to program Toshiba remote CT90157 to work with my Koss KS-5116-2 DVD player... any suggestions ???????
Jan 12, 2008 | Televison & Video
Cameras Logo
882 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
