Question about Garden
JEnny JW1000 water does fill. Goes in and seems
JEnny JW1000 water does fill. Goes in and seems to come out the flexible tube by the line out from both the tube and the connector.
zeusfaber
  • 247 Answers
SOURCE: Replacing copper tubing with a flexible hose for water connection
Go to a place that sells plumbing supplies.
There, you will be able to buy an appliance hose and the fitting which is usually used to plumb these into the domestic water system (a stop valve with a compression fitting for hard tube on one end and a thread to take the hose on the other).
If you're replacing you're old machine with a new one, all you'll need to do is to trim the existing tube at a convenient place (with the water supply turned off) and fit the new stop valve. New dishwashers usually come with a hose, and that just screws onto the threaded end of the new stop valve.
Hints: The hose seals onto the metal fitting using a rubber washer that just sits between the two faces. This system works really well provided you don't try to "help" it with PTFE tape or anything like that. Moistening the threads with a drop of water to lubricate them sometimes helps, but then all you need to do is to assemble the joint (checking the rubber washer hasn't dropped out) and do the plastic nut up finger tight. Check it for leaks when you first use the machine. If it's all right for the first five minutes, it'll be all right for ever.
If you're trying to put your old machine back in, but with a hose to make it easier to move, you will need a second fitting with the same combination of connections as you used to connect the hose to the household plumbing - you may be able to get one without a built-in stop valve, but if you can't it doesn't really matter. Proceed as before, but attach a short stub of the tube you trimmed out in stage 1 to the inlet of the machine (using the existing coupling) and make the new fitting off to that.
A.
Posted on Mar 08, 2008
  • 210 Answers
SOURCE: LG REfrigerator - water line connector
Try closing the water valve slightly to reduce the water pressure to the unit.
Sgt 48
Posted on Jun 03, 2008
  • 659 Answers
SOURCE: My water heater outlet connection is leaking.
You can use hose washers but you really need to use two on water heaters. They aren't think enough for the nut to seat tight enough onto the nipple.
Posted on Mar 30, 2009
  • 90 Answers
SOURCE: Kenmore bottom freezer refrigerator warming up
Hi
There is a definetely leak in the cooling gas.
Firstly... You will need to find from where the gas has leaked. It is usually on the compressor pipes..... but not always.
Secondly you are right about the Water Valve... it needs to be changed.
Regards
Berry
Posted on Feb 02, 2010
  • 67 Answers
SOURCE: we are trying to install a rheem tankless water
Rheem warranty does not allow flex connector only hard gas pipe..also gas line should be properly sized to make sure there is enough volume of gas to the unit. Most unit fire at 199,000 btu and if your gas meter is more than 20 ft away and you have more than 1 gas appliance on the line there can be problems with firing if more than one appliance try to fire.. So you should have a qualified technician check before install..
Posted on Aug 08, 2010
I have a fill valve that says Fluidmaster 747. when tank goes to fill it sprays water out at the top
There should be a small flexible tube/hose that came with this and goes over where the water is spraying out, it should look like a little nipple, the hose goes on there and then to the white tube appoximately an inch or so in diameter that goes to the bottom of the tank where the flapper ball is connected. The small flexible tube is supposed to connect to the top of the larger tube via a clip so-as to fill the toilet bowl back with water. If everything is connected like it's supposed to be then you might have a cracked fluidmaster.
Mar 11, 2011 | Fluidmaster Plumbing
Wont make ice and frozen water running down door
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Whirlpool GS6NBEXR Side by Side...
Water and ice dispenser not working
Jun 06, 2010 | Refrigerators
The electricity went off yesterday while we were gone (not sure how long) and the freezer is no longer staying cold. The ice maker hasn't made any ice and it has melted on top of the other food. We have a...
Jun 06, 2010 | GE Profile Arctica 25.4 Cubic Feet...
My frigidarie refrigerator ice maker does't work
Jun 06, 2010 | Frigidaire PHSC39EESS Stainless Steel Side...
How do you get the ice maker to make ice consistently
Jun 06, 2010 | LG LSC27931S Side by Side Refrigerator
Icemaker not making ice
Jun 06, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Will not dispense ice or water, beeps when lever is pushed, no interior light in frig part. both frig and freezer work, freezer light works
Jun 06, 2010 | Maytag MFI2569VE Bottom Freezer French...
No water going to ice maker
Jun 06, 2010 | Whirlpool GC5SHEXNS Side by Side...
Kenmore washer
this could be the water level switch or the small flexible plastic tube that goes from the water level switch to the side of the tub. this tube may have worked loose if the washer is vibrating too much.
Jun 30, 2008 | Kenmore 22422 Top Load Washer
Garden Logo
105 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
