My cd dvd burner has stopped working,i get a code 41 error can you help me fix
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 166 Answers
Problably the electronics on the cd dvd are bad you going need to replace it
Posted on Oct 04, 2009
I have a code 41 error. can't id device
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 30, 2011 | Computers & Internet
Code 41 error
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 17, 2011 | Sony CRX830E CD-RW/DVD-ROM (Combo) Burner
My tsstcorp cdw/dvd TS-H492C rom is not being displayed on my comp....it displays a message... Dat is windows successfully loaded the device driver for this hardware but cannot find the hardware device....
Hi
I see this is a month old,but I'll answer this for anyone doing a future search that may come across this thread.
The link is to Microsoft's on-line repair center.This will fix several error codes,including 41,and is probably the first thing to try when your optical drive is installed but Windows can't find it.
If this helps with your problem,and anyone in the future,would you rate my post please?
Thanks
Bob
http://support.microsoft.com/gp/cd_dvd_drive_problems
Jul 12, 2010 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
HL-DT-ST DVD-RW GWA-4082N not regognized on laptop (code 41)
if ur using HP computer then start tapping F10 immediately when u start ur comp.. this will take u to Bios.. u should be able to see ur CD/DVD rom there..
second.. Error 41 normally means comp. is unable to read the CD/DVD rom properly.. heres wht u need to do ..
  1. Click Start vistastartbutton.jpg, type regedit in the Start Search box, and then click regedit in thePrograms list.
    securityshield.jpg If you are prompted for an administrator password or confirmation, type your password, or click Continue.
  2. Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
  3. In the right pane, right-click UpperFilters, and then click Delete.
  4. Click Yes to confirm the removal of the UpperFilters registry entry.
  5. In the right pane, right-click LowerFilters, and then click Delete.
  6. Click Yes to confirm the removal of the LowerFilters registry entry.
  7. Exit Registry Editor, and then restart the computer.
let me know if this resolved ur issue.. regards, guru
Feb 07, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
Error Code at 786 (16)- Code 037303 (Medium Error, Power Calibration Fail (Cd Burner is Dirty)
i had the same problem, first when i burn movies i was using fujilim dvd+r after 10 movies burned i use maxell dvd-r i burn just 3 movies then i had a error (Error Code at 786 (16)- Code 037303 (Medium Error, Power Calibration Fail (Cd Burner is Dirty) after doing a lot of things to fixed and research thounsands of webpages one told me to use a diferent dvd then i buy sony dvd+r and now everything work perfect, maybe it helps, write me if you need help.
weddie2006@univision.com
Jun 20, 2008 | Toshiba Computers & Internet
Code 41
This error occurs when Windows does not detect a non-Plug and Play device.If the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device. Hope this helps
Feb 16, 2008 | LG GSA 4163B DVD±RW Dual Layer Burner
Error Messages
CAN I CHEQ THE THE WARRANTY?
Nov 17, 2006 | LG (GSA-4167B) DVD RW Dual Layer Burner
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
