Question about Garden
Homelite back pack blower will start up fine but when you start to use it, it revs up and slows down. It is a UTO8111A. It was built in April of 2003. Fuel and air adjustments were turned by a neighbor and I have no idea where the proper settings for air and gas adjustments should be. I cannot locate my manual. It cranks easily and idles great, but it revs up and down when gas is given.
  • 246 Answers
SOURCE: homelite ut o8107 blower 25cc will only idle
Hello:
Have you Removed the Muffler and Checked the Exhaust Port and Muffler for Carbin Restriction?
Remove the Muffler and Start the Unit. If the Operates Correctly, then the Spark Arrestor Screen is Clogged and the Muffler/Screen Requires Replacing.
Make Sure the Exhaust Port is Not Restricted Also.
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
#1 Taper
  • 1041 Answers
SOURCE: can't get my echo to rev up
Your carburetor needs cleaned, or you need a new carb. kit. If you need tips on how best to do this, let me know.
Jim
Posted on Jun 04, 2009
  • 7 Answers
SOURCE: homelite back pack leaf blower
Close both the high and low speed air screws (clockwise). Reopen each 1 1/2 turns
Posted on Nov 03, 2009
SOURCE: bogs down at full thouldel tryed to adjust carberator
Hi
This is either a clogged muffler or carb. Take the off and see if it will rev. If not you need to clean carb and install a carb repair kit. Do not run long with muffler off.
Sam
Posted on Jan 07, 2010
  • 63 Answers
SOURCE: whats the gas oil mix ratio for a homelite
50:1 petrol oil mix 50 petrol 1 part oil
Posted on Jul 24, 2010
Homelite mightylite leaf blower starts and idles but wont rev to high speed
Have you moved the needle valves? If not good. If so bad. So if you have not moved them gently turn them in counting the turns and part of turns for each valve. Jot this down. Then take out the valves one at a time and spray some carb cleaner into the needle hole. Then put each valve back in the same number of turns and try to start. If you disturbed the valves first start by seating the valves then turn out one turn.
Nov 08, 2013 | Homelite Garden
Blower will not rev at high speed
What kind of blower is it? Make model and serial
My 130bt blower with start an idle fine but wont rev up
adjust the high speed screw on the carb. It is marked with an "H".
Nov 07, 2012 | Husqvarna 295cc Back Pack Blower HVH 130BT
My 5 year old homelite backpack blower starts and idles great but when I rev it up it dies
high speed jet pluged in carb get yourself a can of jet spray gumout with the tube take the bottom four screws out be carefull not to tair gasket clean entire serface with cleaner in all to little holes dont get this in your eyes where glasses if you have a little compressed air to dry and clean serface
put all back together and try it again
Jun 16, 2011 | Homelite Garden
Bogs down at full thouldel tryed to adjust carberator
Hi
Sam
Jan 06, 2010 | Homelite Consumer Products Backpack...
Homelite leaf blover run with choke soon when chokeis off ,cant rev up and die
if he put fuel in it dump it out & put yours in it , if problem persist there are 2 screws on the carberator turn the 1 on the right or th bottom 1/4 turn to the left!
Jun 02, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite ut o8107 blower 25cc will only idle
Hello:
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite back pack leaf blower
Mar 20, 2009 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
275 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
