Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
13.5 CRAFTSMAN MOWER WONT START NOT GETTING FIRE NEW BATTERY NOT SURE HOW TO CHECK THE 3 SAFETY SWITCHES WAS WORKING AND JUST QUIT
  • swampy42 May 11, 2010
    Will he mower turn o er when he key is turned
  • 472 Answers
SOUNDS LIKE THE CARB NEEDS CLENED UOT MY NEED A KIT IN IT
Posted on Oct 14, 2009
I have a craftsman riding mower model 247.288810. While cutting my lawn the engine all stalled and would not start anymore. I changed the spark plug and the battery is new, what could it be?
there are 3 safety switches,clutch,deck and seat, Craftsman 247288810 Lawn Tractor Parts
take the cover off so u can access the coil,unhook the black wire from the coil,not spark plug cable,try to start it,if it starts then a safety switch is bad,if it doesnt,then jump the solenoid,if it starts then it is the seat or clutch switch,if you want to bypass safety switches,connect a switch to the ground and coil
Jul 28, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 917.270514 not starting?
check to see if your getting power to the solenoid on the bottom of the carb a bad safety switch will shut it off they also stick closed from old fuel
Jun 04, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I got a 917259570 Model# Craftsman will not fire at the plugs and the Coil is new, getting power to the Coil and will not fire.
Make sure you have the air gao on your magneto set correctly, check/test your plugs.
All the safety switches are working correctly? Have your bypassed them?
May 26, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Riding mower wont start
check the safety switch on the clutch pedal
May 19, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Nothing happens when you turn on the lawn mower key for craftsman mower model 917 272072. I put a new battery in the mower, and new switch and a new solenoid switch but the mower don't make any noise when...
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Apr 16, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Older Craftsman 43" 17 HP Briggs
Check to make sure battery is above 12.3 volts, secondly bypass the solenoid to the starter by using jumper cables and see if the starter works, if so, you sureley have a safety switch problem, I beleive you have five on this model,
good luck
Jul 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Jun 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
I have a craftsman riding mower with a 27hp B&S engine. Have had sooo many problems with it. Now engine will crank but will not start. Have cleaned fuel line out and it just won't fire. Any...
Some of the riding mowers has a safety switch under the seat so when you get off it shuts off. If it goes bad it will not start. check by bypassing the switch. For safety make sure it's in neutral. This is a long shot . But it can be eliminated as a problem after being checked.
Jun 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
124 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
