Question about Dymo LetraTag QX50 Thermal Label Printer
To change sizes it says to push OK but there is no OK button
How do I make buttonholes on the Bernina 180?
I don't know about your Bernina but mine you have to manually set the button hole size every time you do a new button hole size. Practice on a scrap bit of fabric. I think you push the buttonhole button - sew which I think does an end, push the button again, sew for the distance forward you need and push the button again, and sew the other end and push the button again and it should go back to the beginning. That's off the top of my head, I could be wrong but try it on scrap. I think it might then have set the size until you change stitch types and it should continue to do the same amount of forward and back stitches with each button press to tell it to go forward, end, back, end etc. But practice! My machine has trouble feeding the fabric evenly.
Sep 13, 2014 | Sewing Machines
Fault 9 come on
9. (00001000) Size Switch Error
The Display size switch setting does not match that which is stored in memory.
Action GW Machines: Reselect the size of the machine by using the SIZE SETTING
MODE.
To set the size switch, turn the power on at the power point and off at
the console. Press and hold Wash Temperature Setting Up then
press Power. SmartDrive will give 4 short beeps and the pattern of
LEDs will change.
One of the following buttons needs to be pushed to lock the size into
memory.
• Press Wash Temperature Setting Up, the Cold LED is on for 5.5kg
(560mm wide).
• Press Water Level Up, the Low Water LED is on for 6.5kg / 7.0kg
(600mm wide).
517790C
35
• Press Spin Speed Up, the Spin Hold LED is on for 7.5 / 8.0kg
(650mm wide).
• Press Power to confirm the setting and also exit this mode.
Action IW Machines: To access Size Setting Mode, push and hold the Fabric Care button
and then press the Power button to enter Size Setting mode. Select
the correct size on the display by pushing the Adjust button to
highlight the correct size. Size setting is then achieved by pressing
the Power button. Powering off will set the size into the memory.
Note: Fault code 9 will only be logged into the memory of IW machines. GW and MW
machines can display this fault but it will not be recorded.
May 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
How do I change font size on p-touch 1880? I don't understand the manual.
To change the Font Size follow as below.
Press the 'Fn' Button
Then using the '' Buttons move to SIZE and press the 'OK' Button
Then again using the '' Buttons select which Font Size you require (Large, Medium, Small or Max) and press the 'OK' Button.
Jul 30, 2011 | Brother P-Touch PT-1880 Printer
How do i change my pictue size using remote control
Hello
To select the picture size using the remote control
Press "Picture Size Button" on the remote control
While the Picture Size screen is open, you can do one of
the following to select the desired picture size
Repeatedly press "Picture Size Button"
Press the corresponding Number button (0-6) while the
Press UPor DOWN button, while the Picture Size screen is open
Using these functions to change the picture size (i.e.,
changing the height/ width ratio) for any purpose other than
your private viewing may be prohibited under the Copyright
Laws of the United States and other countries, and may
subject you to civil and criminal liability
OK
May 11, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
How do i change screen size
Look for a button on the remote that said like VIEWMODE,ASPECT RATIO,ZOOM,P.Sizes.Tries pushes one of these buttons to changes ur tv picture screen sizes
Mar 06, 2011 | Televison & Video
Adjust monitor
hi, most monitors have between 4 buttons or 8 to udjust picture. the 4 button MENU, PLUS, MINUS, OFF. when the menu button is pushed the screen will show a list of COLOUR, BRIGHTNESS, CONTRAST, etc,etc the plus is pressed to change the COLOUR, BRIGHTNESS, etc,etc. if you need to change the SCREEN setting BECAUSE THE ICONS ARE TOO BIG click on START go up list to CONTROL PANEL go to DISPLAY click on this and go to SETTINGS click on this and on the left. change to 1024 by 768 SCREEN SIZE (COLOUR 256). press APPLY wait press OK. gerry
Sep 10, 2010 | Envision EN 9110 19" Flat Panel LCD...
The waste ink absorber for canon i9900. please help
you can change ink absorber. if not ,you can change this boxe,s absorber sponge in same size. it workes is absorber wastage ink of printer. thank (nepal)
Jun 28, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Change from mh to mph
Push bottom button until you see TRIP in bottom left corner of screen. Then go to the back, and push the small button and hold for about 3 seconds. The WS in the top will be blinking, and the number will be blinking. Push the bottom button to scroll through until KMH is blinking. Then push the top button, to toggle to MPH. Now... you will have to rest your wheel size on this screen (the numbers) go to Sigma sports website and get the manual, then look at your wheel size on the side of the tire, put in the correct number for your wheel size. Once all this is done, then turn over and push the small button for about a second for your changes to take effect. the screen will not be blinking now.
Apr 21, 2009 | Sigma Sport Bc Mhr Dts Wireless Bike...
Lost manual to Bell wireless bicycle computer
Here are some things the book doesn't tell you:
You have to completely reset the speedometer and lose your odometer to reset the MPH. Hold both buttons for 3 secs to get reset. (Remember to use the left button to walk through the setup process and use the right button to change the settings.) First set the wheel size using Ideluna's settings above on this page (right button to change the setting and left button to go to next number). Next is MPH/KPH, after wheel size setting, push left button again and km flashes. Push right button to change the setting to MI. Next is TIME. Push left button and you'll see the time. Hold down left button till 24hr appears. Push right button to change to 12hr. Then push left button to go to flashing hour. Change with right button. Then left button to go to flashing minute. Right button to change minute, hold down to change minutes fast. Now you are set up. Now the process changes, use the right button to walk through the menu and use the left button to reset. Don't push both buttons anymore unless you want to reset everything again. If you want to reset something just hold the left button down until 0. When you are in SCAN mode, push the right button to go to Time, To go back to SCAN once, hold the right button down - It will scan everything once and return to TIME. To go to ODO, push right button once, push again for DST, push again for MXS, push again for AVS, push again for TM, push again for SCAN to stay in SCAN.
Mar 24, 2009 | Cycling
Machine refuses to print incoming fax. "Paper mismatch"
HP Printer 7210 or 7310 Gives Error receving faxes Load a new blank paper on paper tray.
Press * and # simultaneously, and then release both buttons.
Press 1 , 2 ,and then 3 . The Service menu appears.
Press the right arrow button (>) until the System Configuration menu appears then press OK.
Press > until Media Sense Calibration or Calibrate Spot Sensor appear and then press OK. The unit should pick the paper and eject it.
Press the Cancel button until date and hour appear on display
Mar 05, 2009 | HP Officejet 7210 All-In-One InkJet...
Dymo LetraTag QX50 Thermal Label Printer Logo
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
