Question about PfaFF Sewing Machines
Skipping stitches and sometime the thread breaks.
PFAFF- 1222 (Purchased 1970's) Originally the wheel would stick at a certain spot, then slowly move on until it reached the same spot and would stick. I took the sole-plate off and doused the mechanisms with machine oil. It started doing it again, then seemed to work itself out as the motor moved faster, so started doing some free-hand embroidery (removed pressure foot, lowered feed-dogs) and suddenly my needle broke. I put another one in and it broke. When I put a third in, it started 'flagging' and the stitches skip and wouldn't register all -- couldn't sew anything.
I put the pressure foot back on and regular sewing thread -- same thing happens. I get skipped stitches, sometime the thread breaks.
    New Friend:
    Problem Solver:
  • 17 Answers
Sounds like a tension problem maybe. Too tight tension will bend, and break the needle, especially if sewing fast in free machine embroidery, in this mode, the tensions have to be looser anyway. I can't explain why the wheel flagged and stopped, but experiment with tensions first.
Posted on May 04, 2017
SewExpress
  • 41 Answers
SOURCE: pfaff 1222 belt
Hi - a few suggestions:
  1. May just need a good thorough service - generally a good idea to have it completely gone over - by an experienced Pfaff tech - every year or 2. Internal parts can dry out and simply get jammed.
  2. The timing could be off - again an experienced tech can take care of.
  3. The cam-stack (the part that actually makes your stitch formations) may have cracked. At the age of your machine, this isn't uncommon.
At the age of your machine, many other owners actually have it "rebuilt" by an authorized Pfaff service person. This model is one of those that's worth the investment compared to buying a new machine of the same caliber/quality.
If you are comfortable removing the top cover, you may be able to look at the internal parts to see if anything is broken. This will at least give you an idea of what may be happening.
Many authorized techs will not charge you to look at the machine and give you a quote. We'd suggest calling a few sewing machine stores in your area. Don't hesitate to ask friends for their recommendation of a good service person.
Hope this helps - please don't hesitate to respond if you need further info or clarification.
Happy sewing,
Kim & Linnette
Posted on Jun 13, 2008
SewExpress
  • 41 Answers
SOURCE: pfaff 1222 and pfaff 1229
Could be any number of things causing this problem - and would require a technician who's worked on your particular model to diagnose (Pfaff Dealer Locator).
It could even be something as simple as needing a good, thorough servicing - not the inexpensive blow out the dust & put oil on the hook type, but a full service that checks all the gears, timing, oiling, grease on the gears, motor brushes, etc. Having a full service done every 1-2 years is generally a good idea.
Hope you're up and running properly very soon.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Nov 29, 2008
  • 4 Answers
SOURCE: when I turn on my PFAFF 1222 it wont sew
It may be in bobbin filling mode. Can you turn the inner circular on the hand crank. If you can click it into position, this should engage the needle mechanism.
Posted on Jun 14, 2009
  • 632 Answers
SOURCE: my pfaff 1222 SE has a broken switch. I don't
I foud the correct power switch for your model (I have the same machine). This is located under the dark brown plastic cover. You can buy it on ebay and the item # 360066934338.
Posted on Jul 27, 2009
  • 980 Answers
SOURCE: Manual for a PFAFF 1222 sewing
Try www.sewingonline.co.uk/instructions or www.sewing-machine-manuals.com and click on relics, don't be put off by the word relics
Posted on Nov 03, 2009
My Pfaff 1222 will not sew; the needle moves up and down in the same hole. What does it need to fix this problem?
More than likely, the machine is seizing due to old oil that has dried out--probably affecting the movement of the feed dogs. As a mechanical machine, it needs frequent oiling and cleaning to keep it operating smoothly. Most older machines, like this, are set aside or abandoned for this very reason. If only their owners knew there is a very simple solution. They can be rejuvenated with some elbow grease, "good" sewing machine oil, and heat. Below is the method I've used to find a second life for several older machines:
Wheel on right side that controls the needle up and down is very tight...
Your machine may be purring again in no time!
FWIW--your machine is popular and well-worth spending a little time and money to make her hum again:
Thread Pfaff 1222 Vs New Machine
Manual:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0ahUKEwiSvKLPwNHTAhWmr1QKHQjLDYQQFgg7MAM&url=http%3A%2F%2Fwww.pfaff.com%2FSiteMedia%2FPFAFF%2FProducts%2FMachines%2FSupport-manuals%2Fpfaff_1221_1222-manual-EN.pdf&usg=AFQjCNEOGguC-PcdLTPymc0oWxgw7Utvkw&cad=rja
May 02, 2017 | PfaFF Sewing Machines
I have my moms pfaff 1222 which I love. But having issues with buttonholes. Seems first row of stitching works but when I push button to make end stitch and then reverse it doesnt reverse
Your machine looks quite similar to some of the older Berninas I've worked on in the past. Perhaps your machine has seized due to the old oil solidifying. This could have happened with the reverse mechanism and the selector levers/buttons on your machine.
Nov 22, 2016 | PfaFF Sewing Machines
My pfaff hobbymatic 875 is skipping thread on the bobbin side
Be sure to use a brand new needle. If the needle is bent or damaged, it will frequently skip stitches. Also, if you are using the incorrect needle for the fabric & thread you are using, it will skip stitches, ie a ball point needle on woven fabric.
All About Needles
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Oct 21, 2016 | PfaFF Sewing Machines
My pfaff2044 started sewing uneven stitches. It can sew nice then next second leave a big stretch then sew normal again and then itll leave a bigger stretch it also wont blind stitch.
3 Common Sewing Machine Problems (and How to Fix Them)
www.marthastewart.com/.../common-sewing-machine-rep...
Martha StewartSep 26, 2014 - We consulted Becky Hanson of Singer Sewing Company for her tips on ... The Problem: Stitches are coming out uneven or skipping entirely.
Basic Sewing Machine Troubleshooting - Sewing School
sewingschool.org/2011/03/16/basic-sewing-machine-troubleshooting/
Mar 16, 2011 - The thread breaks, my needle bends, or skipped stitches - UGH! Don't get ... Problem: My stitches are uneven and sometimes skipping!
My stitches are coming out uneven - SewingSupport.com
www.sewingsupport.com/sewing.../sewingsupport.../sewing.../my-stitches...
What to do if the stitches from your sewing machine are coming out uneven. Sewingmachine troubleshooting guide.
Dec 12, 2015 | Sewing Machines
Trying to quilt on my Hinterberg. First the thread kept breaking. Made some tension adjustments, now I am skipping stitches
possible problems
1) too thick for the feed dog to move the fabric forward need; lighter tension
2) are the upper and lower threads the same kind of thread?
3) is the thread feeding properly from above? sometimes the spool can snag the thread causing the tension to jump and skip stitches
Jan 15, 2014 | Janome 1600P-DB Mechanical Sewing Machine
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
The thread from the spool breaks immediately. Does it need a particular kind?
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
Oct 12, 2012 | PfaFF Sewing Machines
Free motion quilting skipped stitches, breaking threads
Might be that you need to lower the tensions quite a bit, you'll have to juggle with top and bottom tensions though, and experiment for just this operation with the Sensormatic.
Mar 27, 2017 | PfaFF Sewing Machines
Sewing Machines Logo
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
