Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Lines going across screen
My 72INCH Mitsubishi tv that i bought 9 years ago for 3500$$ is having some issues.
I recently had bulbs changed so this is not a problem.
There are lines going up and down screen, id like to fix this myself, anyone know what part it is and or how to fix. thanks
  • 3,741 Answers
Lines are commonly found when the horizontal blanking circuit in the vertical deflection circuit fails. or the lenses of the tv are getting weak.there are lenses in the tv from which the picture passes and falls on the tv screen.if the lens is weak the result will be either blurry or with lines. many times removing and readjusting the lens solves the problem. for parts you can get it from ------ www.radioshack.com ------- or from -------- www.shopjimmy.com ---------------- this will help.please do rate the solution.thank you for using fixya.keep updated
Posted on Oct 07, 2009
I've had a rca model l32hd31yx12 and recently began to get white vertical lines after a minute they fade but certain screen changes like volume adjustments and the lines come back and fade again same thing...
Sounds like the power supply has filtering issues, in other words bad capacitors. its best to have a tv shop take a look at it. they shouldn't charge you. good luck
Nov 06, 2010 | RCA L32HD31 32 in. LCD HDTV
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Jan 15, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
Mitsubishi rear projection tv white screen goes dark and....
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0157" use the audio button to select "video chroma" adjustments, use the video button to select item "68 - AG1", use the adjust button to change the setting to 0, then press the enter button to store the change
Mar 04, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Lines across my tv
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB.
Nov 03, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Vertical lines across the screen
Change ballast and lamp at same time. Ballast #75006507 lamp #23311153
Sep 11, 2007 | Toshiba 46HM95 46" HDTV
Ghostly vertical lines
you have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
May 13, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
