Question about Bose 3 2 1 GSX System
Converter needed As I moved back to Europe I now need a current converter for my Bose 321 GSX. However how powerful does this converter needs to be?
  • 52 Answers
If your unit is from the USA, 120 volt/ 300 watts.
EU is 220-240V / 300 Watts. Best choice is to go to Bose service center in EU and have your transformer inside your box replaced with 220-240V for EU operation. That way you don't have to worry about a converter. If not, 2nd choice is buy a step-down transformer 220-240V input and 120 Volt output that can handle 300Watts.
Good Luck.
Posted on Jan 03, 2008
  • mr_perfect76
    mr_perfect76 Jan 10, 2013
    how do you know about 300 Watts rating?
Bose 321 not recognizing cds
Contact Bose and send your unit back. Most likely the CD/DVD drive needs to be replaced
Dec 06, 2013 | Bose 3 2 1 GSX System
I have a Bose 321 GS III Cinema system. What code do I have to program in the Bose remote control to control my Motorola 1960 Cable tuner? The codes in the Bose manual do not work, so I expect that the...
having same problem with my bose 321 GSX. my mom just got shaw digital and likes the shaw remote better than the bose one. I can program the bose remote to do everything but can't seem to do it for the shaw remote. I think i need a code for bose as a reciever? I dunno... any help would be good eh!
Aug 10, 2010 | Bose (321GS) System
I put in a dvd and i get format not supported?bose 321 gsx system
-If this happens on all DVDs, then this may need to be repaired (Bose will repair this for free if this is the case- they can test it too) -If this happens on some or most DVDs, you can try a firmware update. Call Bose at 800-367-4008 and tell them about this. Request the most recent software/firmware update disc.
If you haven't already, just try resetting this first. (unplug the power cord from the acoustimass module for about 30+ seconds and try again)
If this happens primarily on rentals or home-made dvds, an update will most likely fix the problem.
Jul 15, 2009 | Bose 3 2 1 GSX System
My BOSE 321 GSX, was working just fine. I was listening to a CD and started storing it, then someone else tried to stop it, and pushed the on/off, source and eject buttons at the same time. Since then it...
you can open it up and see if you have broken the ac/dc converter. disc tray could have jammed it up. if you dont know much about them then try calling customer support. ^^
Jun 14, 2009 | Bose 3 2 1 GSX System
Adding Spaekers
If it's an original 321 system (series 1) then it has an audio output on the back. (via RCA jacks) You would still need an amp or receiver to connect the speakers to.. (unless they're powered speakers)
If it's a 321 series II or 321 series III- it does not have an audio output.
If the system has a DVD tray right in the middle of the media center, then it's a series 1.
Otherwise, you'd have to get a 1/8 splitter to come from your Mac's headphone output. (still- you will need an amp/receiver or powered speakers to have both 'rooms' playing the same thing from your computer)
May 29, 2009 | Bose 3 2 1 GSX System
Adding Spaekers
Are you able to add speakers to the Bose GSX 321 system?
Jan 01, 2009 | Bose 3 2 1 GSX System
Best way to use US-Bose SA3 amp in Europe ?
Bose say you should pay to get it converted because over time the slightly different power cycles can effect it, however it will still works fine if you change the voltage with an adapter - like I did!!!
Dec 12, 2008 | Bose Lifestyle SA-3 2-Channel Amplifier
Bose 321 system reads bad disc on all dvds
if will not read a laser lens cleaning disc , then it will need to be opened up and the laser lens will need to be cleaned manually with the cleaning solution and a cotton tip , but do it easy and dry the lens with the cotton tip
if that don't do it then the laser mechanism will need replacing
electech
Nov 27, 2008 | Bose 3 2 1 GSX System
Format unsupported
Format unsupported simply means the unit can not read the disc. The problem is either the disc or the player.
Contact Bose technical support if you are sure the discs are good. 800-367-4008
Jul 31, 2008 | Bose 3 2 1 GSX System
Bose 321 cd/dvd tray stuck closed
Please kindly check if this is d model of your 321
Nov 13, 2007 | Bose 3 2 1 GSX System
Bose 3 2 1 GSX System Logo
237 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
