Question about Andis T-Outliner Hair Trimmer
How do i get blades closer on the pivot pro t liners
    Problem Solver:
  • 11 Answers
You really can't move the cutting edge on any andis trimmer blades without throwing them out of spec. I say this to say that if you try (and the blades are not precisely set) it will scrape and cut the skin when you attempt to use them. They are factory set for optimum cutting. If you have found that they aren't cutting as closely or as cleanly lately, it just might be time to replace the blade entirely. I have a set of those, and a styliner II, but I prefer the cutting power of my T-Outliner over all.
Posted on Feb 22, 2010
How can i reassemble me pivot pro trimmers?
RTM. Read the manual. You can find a manual for the make and model on Google.
Sep 09, 2014 | Andis Pmt1-23475 Pivot Pro Trimmer T-shape...
Blades won,t disengage
Assuming this is a lever actuated deck (not electric p.t.o style) I would be checking the belt pivot tensioner assembly which the cable would be hooking to a lot of times moisture will get between the pivot and the deck and rust up not allowing the heavy return spring to slide the pivot back removing the tension from the belt. If you spray the pivot with a good lubricant and hand work the pivot tensioner back and forth it should loosen up. Usually it's the other way around and the 1st time of the year you use it you can't get it to engage.
Jul 13, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
44 swisher
THAY SHOULD MOOVE THE ONE THAT WONT MOVE NEEDS BEARINGS
Apr 27, 2013 | Swisher 44-Inch 12.5 HP Trailcutter...
Superior tool 37100 blade replacement
From Superior Tool Website, look up the tool, then click on "How to Use".
Blade Replacement:
1. Remove large pivot bolt and nut
2. Slide blade down through handle
3. Remove one (1) end of coil spring
4. Remove "E" clip from 1/4" pivot pin,
remove pin and blade
5. Install in reverse order
6. Torque nut until tool ratchets correctly
Mar 13, 2013 | SUPERIOR TOOL CO superior tool 37100...
I have alot of Case pocket knives and the blades on some are starting to become loose and have too much wiggle when blade is out. How can i fix this
Tony:
I have tapped the bolster pivot pin with a small hammer to tighten loose knife blades, but you have to be careful not to scar the knife or smack the bolster pin too hard or the blade will seize and be hard to open or close. If the pin has been necked by the blade (worn in the middle where the blade contacts the pivot pin, you'll have to replace the pin.
Jan 06, 2013 | Garden
I brought the andis speedmaster with the pivotpro trimmer model pmt-1 as was happy to purchase but when I got home and use the pro trimmers they didn't outline the way I expected I thought they would edge...
Some outliners have an adjustable blade set while others are fixed. You will need to remove the blade set and observe if the movable blade is adjustable forward and backward in relation to the stationary blade. If it is adjustable, take caution no to adjust the two blades completely flush. If they are too close they will nip and pinch and can break the skin.
Apr 10, 2011 | Andis Pivot Pro 18174 Hair Trimmer
I have john deer sabre 18 horse i have a snow blade but cant get on right
My name is Dane and I'll try to help you with your problem. I have given you the basic instructions here for mounting most john deere snow blades.
Here is a link to the parts diagram for the blade too.
http://www.searspartsdirect.com/partsdirect/part-model/Sabre-john-deere-Parts/Riding-mower-tractor-Parts/Model-15538G/1828/1509200/10060752/00034
You need to remove the mower deck from the machine, and you may have to remove the front bumper as well.
First, install the mounting brackets on the tractor. Align the holes in each mounting bracket with the holes in the tractor frame. Install using the kit that comes with the mounting bracket. Don't tighten this yet.
Next you should install the pivot support. Insert the pins on the right and left hitch plates into the notches on the mounting brackets. Install the pins and tighten the screws on those mounting brackets now.
Next you should Install the blade. Align the holes in the pivot support with the second holes from the end of the push channel assembly. Insert the channel pin and washer and secure with the spring locking pin.
Install the lift handle. Slide the lift handle rod into the end hole in the push channel assembly. Insert the lift link pin in the pivot support bracket into the lift handle rod. Add the washers and locking pin.
Now, Iistall the blade pivot rod. Either end of the blade pivot rod goes through the blade pivot shaft. The other end goes through the lift handle tube. Secure both ends with locking pins.
Lubricate the lift handle rods and pivot points.
Install the rear tire chains and wheel weights.
I hope I've helped. If you found this information useful, please leave feedback as deserved. Thanks! Dane
Dec 03, 2010 | John Deere Garden
The blades will not disengage
Usually when this happens, there is grass/dirt buildup on top of the mower deck and the pivot point for the tensioner pulley gets rusted to the point that it won't rotate easily. Clean it off and lubricate the pivot point and get it moving freely. Also, sometimes the blade brake arms get stuck. There are rollers on each blade brake arm towards the center of the deck. They are hard to see just by looking under there. I suggest pulling the deck and get it out where you can see it well. The rollers get rusted up and won't turn and follow the cam on the pivot bracket.
Apr 05, 2009 | Garden
Need to replace driver side wiper do not know how to get it off
I believe the blade is the same as my F-250, according to the manual. Pull the wiper away from the windshield, then push on either end of the blade, follow blade to pivot point at center, where blade pivots back and forth on wiper arm (wiper arm will not be moving as you do this). You need to push towards the windshield at this pivot point to push in on the wiper arm and out on the blade assembly to pop the round end of the wiper arm out of the hole in the blade assembly. Look at the new blade to see where this attaches. The new one should snap on to the arm when u squeeze the wiper arm to the blade. I prefer Exact Fit brand, as they seem to fit well. If u purchase at autozone, or advanced auto parts, they will install them for free.
Mar 24, 2009 | 1994 Ford F150 Styleside Supercab
Andis T-Outliner Hair Trimmer Logo
313 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
