Roomba Robotic Floor Bagless Vacuum
Problem for Roomba Robotic Floor Bagless Vacuum
Roomba stops and beeps three times.
By Kym107 on Dec 22, 2007
Roomba stops and beeps three times and the max light keeps flashing....
Same Problem
Sep 18, 2008
-   I have the same problem and I also just bought a new battery for it. -   mcescher38
Jun 21, 2008
-   I have a roomba discovery and the same thing happens to my unit. I tried cleaning all the brushes and the collection bin, but to no avail.-   kipas0314
May 20, 2008
-   My roomba scheduler 4230 will run for a few minutes and then stops. It gives the "uh oh" tone and then beeps three times. Supposedly this indicates that the vacuum is not functioning. However, even with the bin empty, everything scrubbed clean, the rotating vacuum device behind the grill in the back of the bin cleared, it does the same thing. It does the same thing even with the bin completely detached -- and that's where the vacuum is. So clearly the three beeps signal is not correct. I just bought a new battery for this unit and hate to just toss it. Any ideas?-   graptak
Best Solution
posted on May 29, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
try cleaning the front wheel. it is black and white. when it moves, a sensor detects the change from black to white. if the white part of the wheel is too dirty, the sensor can think the roomba is stuck.
Solution #2
posted on Sep 28, 2009
Very Helpful)
cdhillyer
Rank: Apprentice
Rating: 100%, 1 votes
After reading Solution #4 and not feeling much of any air come out of the vent, I used a flat head screwdriver to remove the grill at the back of the debris bin. I then spun the vacuum impeller around, shaking out any debris that was stuck (a little wad that had plugged it came out). I then replaced the grill and put the dirt bin back on, and my Roomba worked!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Jun 15, 2009
Very Helpful)
fixiturself2
Rank: Apprentice
Rating: 100%, 2 votes
Most likely the vacuum motor in the dustbin is stuck. Mine had a piece of grape branch stuck in it and wouldn't turn. Removed the 6 screws and cleaned it out and it works like new.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #4
posted on Mar 27, 2009
Very Helpful)
johnnyzero
Rank: Master
Rating: 90%, 24 votes
I had the same problem - 3 beep codes. According to iRobot's beep code table, this meant "The robot's vacuum is stalled". To verify this, put your hand in back of the rear vent - if you don't feel a decent amount of air coming out, then the vacuum impeller is indeed not functioning.
iRobot agreed to send us a new dirt cup/impeller assembly, but I figured I'd take a look at the original one and see if I could fix it.
In my case, a ground wire had come un-soldered from the side of the impeller motor casing - crappy factory soldering job. I suspect this is a rather common problem w/ the Roomba design - properly soldering a wire to a bare metal surface like a motor case is tricky to unless it's properly tinned & cleaned.
Anyway, I cleaned & tinned a small area of the motor case and reattached the wire the *RIGHT* way. Works great now.
If you're reasonable handy, it's not really a major job - about 10 screws & a little patience. The hardest part was removing the impeller from the motor shaft - use a flat head screwdriver, prying gently, and work it off a little at a time.
Now I've got a spare dirt cup / impeller assembly!
I hope this is helpful to others with the same problem.
JohnB
Was this helpful?
Yes
No
Solution #5
posted on Jan 09, 2009
Very Helpful)
Pjsteenwyk
Rank: Master
Rating: 82%, 12 votes
Just fixed my roomba that was doing the stop after 2-5 minutes of running, beep 3 times ect... What I did was took off the back part (the trash bin) removed the 5 screws on the bottom, this removes the top and bottom shell, then I removed the 2 screws that are at the bottom of the vacuum's motor. And I cleaned it with a damp cloth. Once clean I let it air dry. She is running like she is new :-)
Was this helpful?
Yes
No
Solution #6
posted on Jul 24, 2009
Not Rated)
skipdawg690
Rank: Master
Rating: 81%, 7 votes
I took the whole thing apart completely apart and removed every inch of hair and carpet fibers, removing the yellow wheel inserts and even the white cog wheels (powering the brushes), then took a toothbrush and clorox and scrubbed the front wheel. I took everyone's suggestions and applied them. This is the first time since the day I bought it, this thing worked! Am I going to have to do this every time?
Was this helpful?
Yes
No
Popular Solutions for Roomba Robotic Floor Bagless
Questions and Unsolved Problems for Roomba Robotic Floor Bagless
Do you recommend Roomba Robotic Floor Bagless Vacuum?
Answer
Answer
roomba is on, but it won't clean when 1) I press the clean button, or 2) when I schedule it. I did... (More)
Answer
The last 2-3 cleaning rounds, the dirt cup was empty at the end of a cleaning session, and this is... (More)
Answer
dirt & debris collect at the filter but do not get into the hopper
Answer
i have an i robot vacuum and it will not hold a charge
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Roomba Robotic Floor Bagless...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
