Question about Alps MD 5000 Thermal Printer
My Alps 550 slows then stops printing after a page
My Alps 5500 occasionaly slows then stops printing after a page and refuses to respond. When I restart the pc, a window pops up saying "AL1CSM.EXE" not responding. After restart the alps has hidden print tasks that I can't seem to clear. The tasks are the print job I was trying to do. Is the AL1CSM.EXE part of the driver? Is there a fix? Any suggestions?
fcollingwood
  • 58 Answers
SOURCE: Do you repair Alps MD 5000 printer
Unfortunately, this website is not a repair shop, but I'll give you what help I can....
Printhead problems are not repairable in the US or Europe any longer. You best bet is to upgrade to an MD-5500, which you can find here: http://www.alps-supplies.com
Posted on Mar 19, 2008
fcollingwood
  • 58 Answers
SOURCE: lines through my md 1300 alps printer
It sounds like the head has been damaged. Unfortunately, there is no fix for this, as Alps stopped production of these printers years ago, and now do not offer repairs for these printers.
If you still want a dye-sub capable Alps printer, the only model available is the MD-5500, which you can find here: http://www.alps-supplies.com
Posted on Mar 21, 2008
fcollingwood
  • 58 Answers
SOURCE: Looking for an Alps MD5000 driver for Mac OSX
There are no OS X drivers for the 5000.
If your version of OS X is old enough, you can run the )S 9 driver under classic.
Posted on Jul 19, 2009
SOURCE: How to remove cover off Alps md 1000 printer -
Remove the 4 screws holding the main feed tray. Then GENTLY pry the tabs on both edges of the printer. They are really tight! The fit is great but once you break the "seal" so to say the whole cover just pops off.
Posted on Aug 08, 2009
pineworks
  • 4041 Answers
SOURCE: The print que does not empty after a print job has
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 12, 2010
Why alps md-1000 printer not responding after driver installed
Can you provide more details about the problem? Will the printer print a self test page? What OS, computer, and cable connection are you using? The ALPS printers were designed to work with Windows 95 using a serial port internal to the motherboard. There is a driver that supports a USB port and Windows XP available. XP will automatically install the MS driver using the plug and play feature. The MS driver is useless and it shouldn't be used, but XP will default to it. Don't delete this driver, but rename. There are no native drivers for Windows 7 or higher.
Jul 15, 2014 | Alps MD 1000 Thermal Printer
How to open option setting tab on MD5500
Try using the property settings for the printer. I'm using Win XP SP2. Go to Printers and Faxes, and right click the ALPS 5500 printer. The properties setting should be at the bottom of the menu. Alternatively, you can access the printer properties settings when in application by clicking on File, Print, and then properties.
Aug 14, 2012 | Alps Office Equipment & Supplies
I'am trying to print a decal on am alps 5500
You could try using spot colors for each layer of the decal. This gives you the highest resolution.
Mar 31, 2010 | Alps MD 5000 Thermal Printer
ALPS 5000
Cartridge changer error can be bad. Inspect and clean the changer. Try changing the order of the cartridges in the holder. Any effect? With just the black cartridge installed, try printing an internal self print test. Does that work?
Sep 04, 2008 | Alps MD 5000 Thermal Printer
Problem Printing with Alps MD-1000
Have you ininstall the device and reinstall it? Do you have any pending print job?
Apr 22, 2008 | Alps MD 1000 Thermal Printer
Lines through my md 1300 alps printer
Feb 15, 2008 | Alps MD 1300 Thermal Printer
Alps MD 1000 self tests okay, but printing gives "nonvolatile error" (fast blink)
This is a symptom of the following:
You are running XP, and have installed SP3 and, you are using the microsoft driver bundled with XP.
The solution:
The m$ driver will have created a printer with "(MS)" as a suffix. Leave this intact, as it will cause major trouble on every reboot if you delete it.
Download the appropriate driver from the Files section in the Alps YahooGroup found at http://tech.groups.yahoo.com/group/Alps/
With your printer unplugged, install the downloaded driver
Shut down your computer and hook up the printer
Reboot
XP will detect the printer, and create a new printer in Control Panel without the "(MS)" suffix
Make the new printer your default printer.
The reason why you do not delete the printer with the "(MS)" suffix, is because every time you reboot, XP will ignore the fact that you have the correct Alps driver loaded, and will create a new printer using the m$ drivers, and set it to default. Of course, the m$ Alps driver is fundamentally broken
Nov 08, 2007 | Alps MD 1000 Thermal Printer
Alps md1300 lines through ink
Nov 04, 2007 | Alps MD 1300 Thermal Printer
Oct 29, 2007 | Alps MD 5000 Thermal Printer
Prints 1/3 to 1/2 a page then I get an error
Sounds like you have a problem with the anti-curl motor.
To confirm, you will need to print a test page from a computer that has the Alps drivers loaded (Not the drivers that Microsoft ship with XP, as the Alps drivers have a printer monitor that will inform you of any problems that the printer encounters, the Microsoft drivers do not). You can get them by joining the alps and alpsdecal groups at http://groups.yahoo.com. They are in the Files section of one of the groups.
Assuming you are using Alps drivers, and not the Microsoft drivers that are loaded by XP, you can disable the anti-curl function by the following process:
1. Click File->Print
2. Click the Properties button in the dialogue that opens.
3. Check the checkbox labelled "Print on backside" in the Media Type box of the properties dialogue.
Oct 14, 2007 | Alps MD 5000 Thermal Printer
Alps MD 5000 Thermal Printer Logo
78 people viewed this question
Top Alps Office Equipment & Supplies Experts
Jesse Walters
Jesse Walters
Samuel Konger
Samuel Konger
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
