Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Phillips 42 inch television
My menu screen continues to come on when I turn on the TV until I push my menu button on the remote. Then 3 or 4 seconds the menu screen comes on again. I continues to do that until a few more minutes then it comes on again. Sometimes it will let you watch TV for an hour or so then it starts appearing again on the screen
  • Jamestomasi Dec 24, 2007
    your answer is my question.. Am I missing something ??
  • 265 Answers
This can be solved with software release version V1.1.0 (or higher) that is now posted on the Philips web site. Go to the software section for download and more information or click here.
  • Download the latest software from the Philips web site and update TV by using a USB memory stick. (One without any other files on it is best).
  • Follow the Automatic Software Upgrade Procedure described in the Directions For Use (DFU) that came with the FTV.
The procedure is listed below:
  1. Turn off the TV.
  2. Insert the USB memory stick into the USB port on the TV.
  3. Turn the TV on.
  4. The software update will begin automatically.
  5. After the software update is complete, turn off the TV.
  6. Remove the USB Memory stick.
  7. Turn on the TV. The TV will start up with the new software.
Posted on Dec 27, 2007
  • Aimiel Ireman Dec 28, 2007
    I read the same question on Phillips' website, and copied and pasted the solution. =)
  • 790 Answers
HELLO!!
Try using TV button itself to turn off the menu ... dont use remote ... Just give a try ... wen did u buy this ???
    Sergeant:
  • 279 Answers
It sounds like a short in the menu button, most likely the one on the TV itself (though it could be the remote). To rule out the remote, just remove the batteries from it and see if it still does it - it probably will.
Fortunately, this should not be too hard to fix. You'll need to remove the faceplate around the menu button, and then look at the wires. Somewhere between the button and the board those wires connect to, you should find a spot where two bare wires or connectors are close enough that they almost touch. It may be that the wires are stripped somewhere, or that one of the connectors is bent over towards the other. If it's stripped wire, wrap it in electrical tape. If it's a bent connector, bend it back (and possibly wrap it in electrical tape as well).
Either something's causing the wires to move just enough that they occasionally touch, shorting, and thus the TV registers it as the menu button being hit, or they are close enough that the power occasionally arcs from one to the other, with the same result. Separating and insulating them should do the trick.
-Dyllan
How do I reset the password on 42 inch panasonic t.v. ?
It can be reset by turning the tv on and while pressing the "volume down button on the main unit, press the menu button on the remote control for more than 3 seconds. The self-check menu appears on the screen. Then, disconnect the ac cord from the wall outlet. You will back to when you first bought the set.
Regards,
Joe Van Buren
Jul 20, 2014 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
I have a RCA Truflat tv model 20F420T and serial number H494E2526 and accidentally hit a button on my digital cable box remote which sent the tv into a mode showing FRNT. In trying to solve the issue, the...
Using the remote control hand unit that came with the TV turn on TV. Then go to the set up menu. Locate the entry for Front Panel Lock (FPL) and select no. Once you have done that exit the set up menu then on the same remote push the "input" button while watching the screen. Push button once wait a few seconds for a picture to appear, if not then push the button again, continue until you have selected the input that provides a picture. Right now you are in the Front inputs you should look for Video 1 or 2.
Feb 18, 2011 | RCA 20F420T 20" TV
I have a gateway 42 inch TV and the onscreen menu
1. check the batteries in your remote. if the batteries need replacement replace them
2. Then click the exit button on the remote.
I am not sure of the model of you TV but your user manual should instruct on how to remove the menu screen this is possible that the TV needs a reset.
3. You can unplug the set for 30 second and this usually will solve this issue if not then there is a firmware issue or circuit issue.
Hope this helps you with your issue. Have a great day!
Mar 11, 2010 | Gateway GTW-P42M303 42 in. Plasma...
Tv plays for a few minutes then shuts down. the red light blinks.
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
Feb 14, 2009 | Sony KDF42E2000 42" HDTV
Blue screen on my haier 37 inch tv
my tv just went to a blue screen one day. I can turn it on and then it will just remain on the blue screen. Any button (except the volume) I push on the remote comes up on the screen "no signal". What would you suggest? I have been reading about replacing a fuse or board? Most of those are on the 42 inch version---I have teh 37 inch version.
Feb 02, 2009 | Haier HL37S 37 in. LCD HDTV
Haier LCD TV
Follow these instructions to the "T". On step 13 use factory on the right menu block instead of the left.
The procedure resets your monitor to factory setting on the boards an eeprom. It may or may not work if you have a bad component.
1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
2. Hold the Menu button on the Monitor.
3. Press the Menu button on the Remote.
4. Press and hold the Volume button on the remote for 5 seconds and then release the Menu button on the Monitor. After this step the date will appear on the left side of the screen within 10 seconds.
5. Click the Menu button on the remote.
6. Click the Left Arrow button on the remote.
7. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
8. Highlight "Eepreset" and click the Left Arrow button. (The monitor will turn off at this time)
9. Push the Power button on the remote, the unit will turn back on.
10. Click the Menu button on the remote.
11. Click the Left Arrow button on the remote.
12. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
13. Highlight Factory and click on the Left Arrow button to select "Off"
14. Click Menu on the remote.
15. Click Menu on the remote.
Apr 15, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Insignia 42 in plasma tv
cableman try this exactley to the "T" with the instructions in front of you. The procedure resets your monitor to factory settings. On step 13 use the factory setting on the right side menu block not the left. It may or may not work if you have a bad board or eeprom. 1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
Jan 06, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
116 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
