Question about Olympus Camedia C-750 Ultra Zoom Digital Camera
Olympus fe-310 camera will not turn on even with new batteries.
  • 919 Answers
SOURCE: olympus FE-310
The reset option is located when you hit the Menu button when in shooting mode - it is on the left hand side of the screen. You would click Reset and press Ok. It will show Reset Yes or No. Select Yes and press Ok. The camera will now be in factory default settings.
Posted on Jan 15, 2009
  • 291 Answers
SOURCE: i lost my cd , and i need to install CD of olympus FE-310
click the link below and download the drivers for your camera: http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1351
Posted on Apr 03, 2009
SOURCE: camera won't work even with new batteries
Just had that same thing happen.
Try lithium batteries...Should solve it.
Posted on Jun 15, 2009
BillB-SA
  • 2761 Answers
SOURCE: my camera keeps turning off when i try to take a picture even whe
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Posted on Nov 29, 2009
  • 1705 Answers
SOURCE: how to reset olympus camera model no.fe-310
Go to this site :-
http://www.olympus.co.uk/consumer/208_digital_camera_fe-310_18519.htm
On the right hand side of the page there's a menu list under the title customer support.
Click on Manuals and dowload. Should give you all the info. you need.
Posted on Mar 24, 2010
I need an owners manual for an olympus FE-310
You can download a PDF version of the manual and/or order the printed one from the manufacturer's web site at http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1351
May 13, 2010 | Olympus FE-310 Digital Camera
Fe-310, only used a few times, kept protected, one
Short answer - yes.
Manufacturers have become very good at making products that are reliable for exactly 1 year.
Usually it's small components that have a deffinate shelf life.
I would first check that you are using the correct battery for it. Even if it looks like it takes standard AA's - they often will only work for original spec rechargable blocks.
If this does not solve it - write a letter to Olympus saying how dissapointed you are with their product.
They may offer you a good deal on a repair hopefully.
Unfortunately Sony and HP are even worse - HP and lexmark printers now stop working after a period of time - telling you to buy more ink - even though you still have plenty.
Oct 01, 2009 | Olympus FE-310 Digital Camera
Olympus Fe-310, lens is messed. Possible sand in it but not sure.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 14, 2009 | Olympus FE-310 Digital Camera
Have no cd-rom installation for olympus fe-310
you should be able to hook your camera to your computer by usb cable and have it autodectect the camera (make sure the camera is on) if that will not work... let me know i'll find you something
Robert
Jan 25, 2009 | Olympus FE-310 Digital Camera
Every time i turn on the camera it say card-cover open
clean the seal around the door... else it is repair
olympusamerica.com/repair
Jan 20, 2009 | Olympus FE-310 Digital Camera
Olympus FE-310 will not turn on
Bring your camera to your vendor so that you can avail warranty.
melnavz
Jan 06, 2009 | Olympus FE-310 Digital Camera
BLACK SCREEN WHEN TURNED ON
This is either a bad CCD or the lens aperture not opening. You could send it to mackcam.com or to olympus for an estimate. Might be looking at a $125 repair
Dec 31, 2008 | Olympus FE-310 Digital Camera
Olympus Camedia C-750 Ultra Zoom Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
