Question about HP PSC 1510 All-In-One InkJet Printer
Hp problem There is no image printing. Usually there is a gradual deterioration but this time it happened over night.
    Scholar:
  • 54 Answers
Please make photo copy using the front panel copy button if that works then the issue is with the software and if that does not work issue with the hardware. Click Start - All programs - HP - Hp Director/Solution center. Click Settings - Print settings - printer settings. Click on the Colors tab. Enable the option.In color management select "Managed By application". Click Ok. Also set the print quality to Best from Paper Quality tab. If the issue persists get back with detail description.
Posted on Dec 22, 2007
My Dell 1720dn mono laser printer has not printed properly for some time - in fact it's dreadful! The letters and dark images have white vertical lines going through them, and some of the printing do
Change your toner cartridge. A properly working toner cartridge will never leave that much toner lying around. The white lines are an indication that either the toner is low, or the mag roller is defective.
Dec 05, 2014 | Dell 1720dn Laser Printer
I have an HP3500 which I've had from new since 2004. On the whole it's been remarkably reliable but recently I have problems with a multicoloured stripe which appears down the lefthand side. It...
Hi Richard,
Dots, Lines and smudges on the printouts are usually due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and inspect them. You may observe the lines on the green drum. Gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines. (corresponding to the location where you are having a green line on the paper)
Also, make sure that the visible inside of the printer are clean and there is no spilled toner inside, which sometimes results in dots.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Observing the PCR with the help of a sharp torch light would let you assess the condition of the PCRs at the corresponding location where lines are appearing. Replace the Cartridges one by one and inspect the prints for the changes. I think you would be able to identify the faulty cartridge/ rollers. Also, if the waste toner area is filled and/or the plastic wiper/ cleaning blade removes the leftover toner/ waste from the drum and holds the waste is worn out, it results in spilled toner usually at edges and at early stages lines only.
Moreover, the function of the fuser is to fuse the toner onto the paper and it is usually done at the end of the printing process just before the paper is ejected (and the image/ toner on the paper is just fused - not changed). The fault at the fuser area usually results in smudges, ghosted image or unbind toner (which easily gets erased when touched). The time during the printing cycle when the toner is spread on the paper, additional toner (resulting in lines) is shifted to the paper due to cartridge related issues, which results in lines. Note that after cleaning the rollers, the print quality improves and the lines disappear or lighten. Try and check if the above suggestions work.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 16, 2011 | Office Equipment & Supplies
Quilt y of print !, it gives double printing on page one is print of original doc.& second as its image what should i do to improve its print quilt y. i will be thank full to you
Dots, Lines, shadows and smudges on the printouts are due to dirty/ deteriorating cartridge and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines.
Also, make sure that the visible inside of the printer is clean and ther is no spilled toner inside, which sometimes results in dots. Double printing is also due to the deteriorating cartridge. The drum is not getting clean after its each rotation and hence the remaining toner/ image is transferred to the paper resulting in double printing. So, it is recommended that clean the drum etc (this would help temporarily). Also, make sure that the toner cartridge is in good working condition. If not you may replace the cartridge.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Jan 14, 2011 | Canon Image Runner 1630 Copier Copier
My Brother MFC-3240C printer does not print crisp images. Colors are washed out and lines run though the images. I reinstalled the CD and no luck. Can you tell me what to fix?
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there. Better than throwing the printer.
Good Luck
RK
Nov 25, 2009 | Brother MFC-3240C All-In-One InkJet...
Sony cybershot pictures fracture when stored on computer
So you mean that when the photos were transferred to the computer, they were fine and now after few months the images on computer are corrupt .. Right?
If that is the matter then I feel that its not a problem with the camera .. It should be some (strange) problem with the storage device on which you copied the photos to.
May I look at a sample image please?
Apr 02, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
My hp deskjet 9650 sometimes makes this terrible noise when printing a screaching noise like it is off track and my print looks like it took a shift one way or the other. When it is printing letters they...
Printers usually have some sort of cable or belt that moves the carriage. Check the belt on your machine. They will wear and deteriorate over time and sometimes will shred. If you REALLY like your printer, the belt can be replaced.
Jul 27, 2017 | Office Equipment & Supplies
No image but good quality speaker.
Sony has had a problem in older sets with-believe it or not- lack of humidity. I had one with the same problem. If it is under warentee take it back, if not-I know it sounds insane- put a large plastic garbage bag over the turned off set. Leave it that way for a couple of days. do not turn it on during this time. After a couple of days remove the bag and turn it on. If it works-that's the problem, if it doesn't- it's dying, and to expensive to fix. Surprised the heck outta' me when I tried it on my old Sony 19" set- it worked.
Jul 01, 2008 | Sony KP-46S25 TV
Ipod Nano won't hold a charge
Hello oob5491,
The battery may be going bad. The internal battery in the ipod has a limited lifespan and will eventually fail. When this happens the amount of operating time you get between charges will gradually decrease unti eventually the unit will not stay charged. It sounds like this is what you are experiencing.
You will want to contact Apple about the unit to get more informaiton on getting battery refresh service,
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 26, 2008 | Apple iPod nano
Large grey streak down center of page
It is the fuser at rear giving you grief! The upper heat roller has a teflon coating that wears away allowing toner to stick to roller and smudgin prints as they pass threw it. The fix is to replace fuser assembly, take to brother dealer to fix.
You can prove it to yourself by timing the print to stop mid way threw machine then remove print cartridge and look at paper, you should see a image is good untill it hits the fuser,( pre fused image "rubs off" paper.) If you have changed drum and toner thats all it can be. They all do it in time.
Fuser is hot bit at rear, pull out drum and look in the back with a small torch you will see upper heat roller is worn, guestimation $90 for fuser plus labour to fit.
Nov 16, 2007 | Brother IntelliFax-2820 Laser Fax
HP PSC 1510 All-In-One InkJet Printer Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
