Question about Mitsubishi WD-62525 62" Rear Projection HDTV
I have a mitsubishi 72 inch tv that i bought about 9 years ago for $3,000. There are lines going up and down the screen. Id like to fix this myself, anyone know what part it needs?
  • 3,230 Answers
Hi there
Well the problem seems due to some bad capacitor, caps which is located in the power supply circuit for the video drive circuits, check the CRT neck for a bad or faulty capacitor and the power supply section that is supply this circuit with voltage,also if this does not result in anything can t find any capacitor causing the problem than continue on to the to checking the filament voltage for insuffient voltage, this can be caused by a bad connection or a bad component in the filament power supply probably from the the fly back transformer,do not leave out the vertical deflection circuit and the horizontal deflection circuit as this two circuits can cause this kinds of problems as well.
Good Luck!!
Thanks
Posted on Oct 04, 2009
I have a sony 50 in rear projection. 9 years old
Sounds like the CRT tubes are going out which is fairly common on Sony. Inside the back of the TV there are 6 knobs - 2 for each color...one is for focus - dont touch - the other for brightness...turn down the brightness just a hair untill the lines go away.
Dec 01, 2009 | Sony KP-51WS510 51" Rear Projection...
I have a 9 year old mitsubishi projection tv
Could be a problem in the high voltage section or a bad signal board. Let the TV tech do it.
Good luck
N Sabre
Nov 08, 2009 | Mitsubishi VS-60607 TV
Mitsubishi 72" projection TV I turn on and then turns off
If this this a LCD projection It may be a faulty lamp. It is a great idea to call the support center. they can walk you through it and advise you too.
Apr 26, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Need a new screen and protection screen for Mits ws 55513 where can i get one or is it cheaper to buy a new tv
the only solution u have is to call all tv repair shop and see if they have a use screen with the same model ,
Jan 16, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Full screen has lighter colors on 8 inches on both sides.
YOU WILL NEED ALL CRTS REPLACED TO CORRECT THE PROBLEM. NOT WORTH REPAIRING.
30 YR SERVICER
APGONZO
Dec 26, 2008 | Sony KP-57WS500 57" Rear Projection...
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
any repair shop can re converge the tv for you.id do some calling arond and get a few quotes to see what it would cost to have them come to you
Oct 09, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Vs-60705
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility that works on rear-projection TV's should be able to repair your set. I bought the set on Jan 1, 2000. Coming up on 9 years and the set works like new.
Jul 30, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi vs-7071 rear projection tv
hey i have had the same prob on my other tv .it was about 300 to get it fixed.if you havent allready fixed it and if your not to fare away,id like to buy the screen
Jul 29, 2008 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi CK-3513R - Horizintal white line
this ic is soldered onto the board with a heat sink it is related to horizontal circuit.your problem could also be the flyback.good luck
Apr 12, 2007 | Mitsubishi CK-35308 35" TV
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
