Question about JVC DR-MV7 DVD Recorder/VCR
Door opens and closes 3 times
Everytime I try and load a new DVD, the door opens after I close it. I then press OPEN/CLOSE to close it and it opens again. It always seems to load properly after 3 tries. I would think that it is kicking the disc back out because it is dirty, but this happens on every disc and it always seems to work after I close it again 3 times exactly.
  • 2 more comments
  • Anonymous Mar 01, 2008
    I've got the same problem, except that it sometimes takes many more attempts to successfully load and view the DVD. Often the disc is ejected with a message that reads "Unkown disc" or something to that effect. What is the solution to this problem. Thanks
  • Anonymous Mar 09, 2008
    My unit is about a year old. Started similar problem a couple of months ago. I keep pushing open/close button, then depends on the luck it accepts after several attempts. This became a major headache. Also my VCR has problem, not recording properly, when replays, it has many lines over it and looks not worth using it either. Please advise, if any know cure with clear instructions. Advance thanks to all those who proposes a solution.
  • Anonymous Apr 07, 2009
    Same problem but getting worse...have to try to load it 15 to 20 times before the DVD stays in the machine. JVC told me how to reset the unit (also says how in the manual), but this doesnt seem to help. Have it a little over 1 year, so of course the warrenty is over. Is it worth getting it fixed?
  • exgipi75 Oct 01, 2009
    Well, it worked for a very short while but has returned to the same problem of the disk not reading and the drive door not staying shut. If I could just replace the drive I would do that but then I'm not sure it is just the drive that is the problem.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
V\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} t needs to be realigned
unplug power
open unit
Door opens and closes 3 times - clip_image001.jpgremove dvd drive (4 screws)
remove power cable to dvd right rear of unit on circuit board
(squeeze plastic connector and pull up)
remove ribbon cable CAREFULLY wiggle it from side to side and it will come up clip_image002.jpg
Then with drive removed, open up drive to access the bottom near front door
Once open you will see a smalll motor and a white pice of plastic that slides. with tray closed slide that piece of plastic as far towards the middle as it will go
with that slid all the way over you should be done.
close it up and be carefull sliding the ribbon cable back into place
Worked for me!
Good luck
Posted on Jul 08, 2009
Try the fix where you slide the piece of plastic as for towards the middle. I opened the unit and checked the gears. They seemed okay although I did push the white piece of plastic which is located in front of the drive and opens the dvd drive. However, I think I may have just needed to seseat the small ribbon cable that connects the dvd drive to the motherboard. I'm not sure but the unit seems to work okay for the time being
Posted on Sep 20, 2009
Mazda 6 2005 driver door jammed
if you talking about door latch wont let door close.try to reset all door locks.first if you cant get door close.work unlock button with remote or door switch.then hold open door handle while you flat screw driver pull up latch in door latch should stay up so door will close.once get door close.try resetting all door locks by sitting inside vechicle with all doors close.remove key from ignition.open drivers door.wait 24 seconds.turn ignition switch on and back to lock position 3 times.press and release drivers door courtesy light 3 times.ensure doors lock and unlock.if not wait 40 seconds and repeat procedure.if this procedure fails. you have problem in the door latch and lock mechanism inside the door itself.
Jan 04, 2013 | 2004 Mazda 6 Sport
How do I open the DVD/CD Loading Door? It will not open!
You have a physical problem---make sure front of unit is not touching the door or out of position----
May 22, 2012 | Televison & Video
RCA RTD315 Theater System The DVD Player recently
My identical system has exactly the same problem as the one described by dipaola, above. When I insert a DVD, the DVD carriage pops back open after a few seconds. In fact, mine won't stay closed even without a DVD in it, as long as the system is set to play a DVD. I'd like an answer to the big Q - Is there anything I can do about this, or should I just find another DVD player to hook into the system?
Nov 05, 2010 | RCA RTD315 Theater System
My DVD writer can read and write files without any problems but from time to time when I open and insert a DVD it would not easly close. After serveral tries door closes and windows explorer can read the...
When the door is closed, push a paperclip into the paperclip-sized hole in the front to open it manually w/o the motor. Put the disc in and press it shut manually. Bypass the open/close motor completely.
Dec 20, 2017 | ASUS DRW-1608P3S DVD±RW Dual Layer Burner
F-26 flashing
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door
switch is open while the door is locked for more than
5 seconds.
Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Faulty door Switch or CCU board or door not closed during run cycle.
Starting Diagnostic Test and bypassing
the Service History Mode:
Execute this procedure with an empty drum. All
of the steps below must be done in sequence
in order to reach the Diagnostic Test. This
executes the automatic test but does not show
the error history.
Close the door.
Push POWER.
Select the CLEAN WASHER cycle.
Press EXTRA RINSE four times within
5 seconds.
Press EXTRA RINSE to advance to the
next step of the test procedure.
If the starting procedure fails, push
PAUSE/CANCEL, then repeat the starting
procedure.
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Unable to open the door of the dvd --when you press the eject button to open the slot---the door does not open---everything else works
Quick trick
First let's find out if the motor is dead or
the magnetic clamp is to strong for the motor.
Press eject then listen closely for the sounds of struggling motor
if you hear it trying SLAP the top right over the DVD drive
and that should break the magnetic seal and release the tray
you may have to try a few times Press eject and open hand slap kinda
hard the top of the DVD drive , don't worry you won't hurt it.
if that works email me and ill tell you how to fix this.
Rob
rsheehan@northernsteeldesigns.com
Oct 14, 2009 | GoVideo Go Video DVD/VCR Combo
Door Ajar Light
the switches for these vehicles are in the latch and they seize up from time to time. you will have to spray some penetrating oil into the dor and rapidly close and open the door hard to try and fix it. if that doesn't work then you will have to figure out which door it is and replace to latch. note if key is on, the dash will make a tone everytime you open and close door. so the door that doesn't chime that is the door with the issue.
Aug 28, 2009 | MTX Ford Explorer/Mercury...
Door on DVD player
The drawer seems to hang up when it sits closed for a while. I found that using a very thin but rigid metal item such as a nail file under the leading edge, allows it to open with the first press of the  open/close button. I load the DVD, press the open/close button and it closes and stays shut.  After I submitted my problem, it occured to me that the reason for the door to continue to open and  close, was the repeated pressing of the button. The door was merely responding to each time it was "called."
Jan 15, 2009 | Sanyo DVW-6000 DVD Player/VCR
Internal DVD
hi if your dvd driving belt is slack, it wouldnt be able to draw the door to a position where it will press the loading switch, so it will eject back. 2. if your dvd laser lens is dull or too dirty or dead it might be making attempts to load severally.if the disc driving motor is bad, the tray can be open & close many time without a success
May 24, 2008 | Polaroid 3211TLXB 32 in. LCD Television
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
JVC DR-MV7 DVD Recorder/VCR Logo
329 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
