If it's leaking out the front by the door then you should check the latch and the rubber gasket/seal around the door.
If the leak is under the dishwasher then it could be the waste/drain hose or it's connection to the dishwasher or the pump/valve assembly. You should be able to narrow this down by running the dishwasher with the kickplate removed and feeling around underneath while it is running to find the water source.
