Question about HP Photosmart M425 Digital Camera
I can only turn on the camera when it is docked. it does not work otherwise. does it require a special type of battery?thanks.
3 Suggested Answers
SOURCE: HP R927 Camera
I had this problem with my camera after a year. Scratching the battery contact terminal inside the camera fixed it.
Posted on Nov 11, 2007
i had this problem with this camera when i had it new i would put the camera on the dock to charge and then use it then finally it wouldnt work and i realised that the camera wasnt charging. i contacted hp who i found to not be very helpful, they eventually sent me out a new battery even tho i told them i felt it wasnt the battery, of course the same thing happened with the new battery. i called them again and said i felt that there may be a loose connection in the wire going from the transformer to the dock as by messing around with it had made the light come on but as soon as i let go it went off, they agreed to send a replacement. when the replacement arrived they sent the part of the cable that plugged into mains and as such was no use, they siad they would send the right one but as yet i have not received it. =S however, by moving the wire where it plugs into the dock i have manged to get the camera to charge, it may be worth messing with the wire to see if this is the case with urs and calling for a replacement. claire xx =D
Posted on Jul 17, 2008
Changed batteries, wont turn on.. Vivicam 5022
Welcome to FixYa.
1. Make sure that the battery meets the required battery type for your camera.
2. If you are using rechargeable battery, make sure it is charged properly.
3. The battery you newly bought might be defective. It happens once in a while specially if the battery is an old stock.
Thank you for using FixYa.
Jas247
Sep 24, 2011 | Vivitar Cameras
I got a dx4530 w/easyshare Dock II. from a friend of mine. He had been using AA batteries and it worked fine. I went to Best Buy and bought 2 Ni-MH batteries and put them in the camera. I then put the...
In the Kodak cameras of that vintage the original 3V rechargeable battery was made of 2 regular AA rechargeable batteries and a special piece of plastic that pushes some microswitch in the battery compartment. If this piece of plastic is missing, the dock would not charge the batteries. You either need the special CRV3 battery or to charge the normal AA rechargeables with a separate charger.
Sep 18, 2011 | Kodak EasyShare DX4530 Digital Camera
I have a DX7590 that won't charge the batteries.
Jeff, you didn't verify the type of battery that you have on your camera, is that the KLIC-5000? if yes then still it will not charged on your dock try to charged your camera using the 5V AC adapter. If your camera will not turn on using the 5V AC adapter or will not turn on using your dock it means the camera is defective and not your battery or charger. You can still contact Kodak repair center at 1 800 665 6515 they will handle your issue.
Feb 09, 2010 | Kodak EasyShare DX7590 Digital Camera
Kodak EasyShare Z612 Shuts down after taking a few pictures.
Question : What batteries can I use in my digital camera, and how long do they last?
Battery life depends on how you use your camera, the type of batteries you select, and how you handle the batteries.
Your camera is compatible with: KODAK Li-Ion Rechargeable Battery KLIC-8000 and KODAK CRV3 Lithium Batteries: A non-rechargeable battery. (so your battery might be in need of a change)
Using Your Camera
Some features, such as reviewing pictures and using the flash, require more power than others. Follow these guidelines to get the best use of your batteries:
  • Limit the time your camera is in Review mode.
  • Limit your use of the flash.
  • Use the LCD Dimmer or Auto Power Off features, if available on your camera.
  • Transfer your pictures to your computer using a compatible power adapter, camera dock, printer dock, or memory card reader.
  • Check that the latest firmware is installed on your camera. See Software, Driver & Firmware Downloads.
Handling Your Batteries
  • Wipe the battery contacts with a clean, dry cloth before loading it in your camera.
  • When using your camera in temperatures below 41° F (5° C), carry spare batteries and keep them warm.
  • Do not discard cold batteries that do not work; they may be usable when they return to room temperature.
  • Do not allow batteries to touch metal objects, including coins. Otherwise, the batteries may short-circuit, discharge energy, become hot, or leak.
Dec 10, 2009 | Kodak EasyShare Z612 Digital Camera
Batteries will not recharge on Kodak EasyShareDX4330 Camera dock seems to be working fine otherwise.
if your are using the ordinary AA rechargeable battery it will not charge., Camera dock will charge only on a 2 Pack AA battery like KAA2HR batteries or the 2 AA battery that attached together (Ni-MH rechargeable battery pack )
What type of battery are using?
try to purchased KAA2HR
Nov 05, 2009 | Kodak EasyShare DX4330 Digital Camera
Samsung camera still not working
I personally have had great luck with the Kodak Z650. It's an inexpensive full featured camera that provides a good zoom ratio (10x optical + 5x electronic = 50x zoom), the convenience of a charging dock that lets you connect to your computer AND charge the camera by simply dropping the camera into it, and plenty of available accessories. I have two of these cameras and I recently gave one to my daughter and her husband. Kodak.com is a good source for these (new & refurbished), and eBay is probably an even better source. AVOID the Kodak printer dock though. Quality is poor, and they are prone to multiple problems.
Don't give up on the Samsung yet, though. The problem you describe is frequently battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing into the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 14, 2009 | Cameras
My G600 printer dock does not charge my rechargeable batteries
are you using a D26 adapater?
can you verify what type of batteries are installed in the camera?
The only battery that the dock will charge in the CX7530 camera is the
KODAK Ni-MH Rechargeable Digital Camera Battery KAA2HR
8156572
May 03, 2009 | Kodak Easyshare G600 (1633379) Dock /...
How 2 charge a kodak with rechargable batteries!!!
get a charger for the rechargable batteries. Charge the batteries and then put them into the camera. You cant really chare the camera..
May 02, 2009 | Kodak EasyShare C613 Digital Camera
With my camera on the dock and the dock light is on, the battery light does not come on at all.The camera is turned off. It does not show to be charging or to be charged. No light at all. Nearly new...
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Feb 19, 2009 | Kodak Z8612 Digital Camera
Camera dock can not charge camera battery
It sounds like defective batteries if the printer unit works otherwise,
Feb 16, 2009 | Kodak Dock Series 3 Laser Photo Printer
HP Photosmart M425 Digital Camera Logo
13 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
