Blank screen Screen is blank, power light is blinking green. Disconnecting the video connection makes no difference. A substitute monitor works OK, so definitely seems to be a monitor problem. Any ideas? Many thanks. have a Envision 19''model # EN9410e was bought at staples 1 yr ago,it started to flicker then screen would go blank then come back on afew times we turned it off turn it back on green light flickered but screen stayed black,whats wrong with it
Its cheap buy a good one!!!!!!
Posted on May 06, 2008
2 Suggested Answers
SOURCE:
SOURCE: monitor started to flicker then went blank
I have the same problem with my monitor. It started a few days ago and Christmas day it was done. So now it just keeps turning itself off and on.
Posted on Dec 26, 2007
I have a samsung syncmaster sa300 that just went blank.
do you mean this monitor have been tried to hooked up with other pc then still no display?. ok if their is a power indicator light at front with no blinking but their is no display ( black screen ) the cause will be either the inverter board has damaged or screen back light is busted .
Jul 25, 2012 | Computers & Internet
Desktop screen is blank even when the cpu and monitor indicator a
It looks like issue with either mother board or processor.
open the box and remove all memey and power it on. if it makes a beep sound, there is no issue with processor, else we suscpect processor. If it make beep sound, it might be mother board issue. And for checking monitor working condition, remove monitor data cable and see no cable connected messages comes in monitor or not
Oct 13, 2009 | Dell Computers & Internet
Screen is blank. Green LED power light is
Might be your graphics card, try swapping it out for a new one and see if that works
Oct 09, 2009 | Dell E173FPb 17" TFT LCD Monitor
My monitor won't come on, the green light blinks, but nothing shows up on the screen at all. i've already changed the video card but that did not fix it. prior to changing the video card, once in a while...
try shining a light directly on the screen to see if youve got a backlight failure, if you have there will be an image on the screen but nothing lighting it from behind thus making it seem blank, if that is not the case id start with the vga cable and work from there
Sep 26, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
HP L1706- screen is blank when I switch on
First if you have a extra monitor try to plug it in and see if it works. If not then check your video card. or get into the computer and try and remove and reseat the memory. Sometimes by just doing that can solve the problems
Feb 06, 2009 | HP L1706 17" LCD Monitor
Blank screen
This looks like a problem with the video card or the power supply to the monitor. Try connecting a different monitor and if you still face the same problem then probably you may need to have a look at your video card or its connection in motherboard
Feb 01, 2009 | ViewSonic A90f+ 19" CRT Monitor
Blank Screen while Green LED is Blinking.
It's because I accidentally plug the cable to the built-in graphics card port. Now I connected it to the right one and my monitor is working great!
Aug 19, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Monitor started to flicker then went blank
I have a envision professional series and I love it, but I will get to the point.
I recent ly received a Envision EN9410e monitor, had the same problem (flickering screen then turned on, then off then on then blank). The problem is bad capacitors. There are 7 electrolytic capXon capacitors that will need to be replaced. You should see if the caps are bulging or leaking, if so replace. As known by many replace with the same capacitance and voltage. There are a few incidences that the capacitors where replaced and the problem wasn’t solved; this is because the cap problem wasn’t taken care of and damage occurred to another part of the monitor. The back light is a Royer oscillator (cool things) and it uses two smd mosfet transistors. They are on the green side of the circuit board near a big control chip (they each look like a off rectangle black square with eight pins) you need to see if there is any carbon or chard residue between the pins or burning smell from them, if there is you need to remove the transistor and do some board repair then ether put a new transistor or try the old one. No offence to the people at Envision but not smart putting the drain, gate and source so close to each other under the chip where there is such high voltage! Hope this helps.
Dec 24, 2007 | Computers & Internet
Open Questions:
Computers & Internet Logo
287 people viewed this question
Ekse
Alun Cox
