Question about Champion International Air Tools & Compressors
Wiring Diagram for a champion Air compressor - Champion International Air Tools & Compressors
  • compman66
    compman66 May 11, 2010
    what model?
3 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: Wiring diagram to convert Craftsman 5HP Air compressor
look on the motor cover or on the wiring cvr on mtr or on the inside of the wire termination cvr
Posted on Oct 06, 2009
compman66
  • 169 Answers
SOURCE: champion vr3-8 auto drain blowing out when compressor turns off
If the air continues to come out on top of the drain valve well after the pump has stopped, you may have a faulty tank check valve where the pump discharge line enters the tank. when this valve sticks open it will cause this problem.
Posted on Nov 26, 2009
Im looking for a 1976 dodge champion motorhome chasis wiring diagram
Champion built motorhomes from the early 1970s until the mid-1980s. While Dodge powertrains supplied the momentum for Champion Class A motorhomes through the 1970s, the Class C between 16 and 22 feet were powered on General Motors chassis frames. 1986 was the final year of Champion motorhome production.
It will be nearly impossible to find a chassis wiring diagram for a vintage orphan RV. Perhaps an online enthusiast forum or keep an eye on eBay.
Oct 30, 2014 | RVs
Champion CSF30 compressor high screw temp fault
Check the oil level, if oil level is ok, check the cooler for cleanliness, if cooler is clean, check the thermal valve by measuring the temperatures going in and coming out of valve. The final thing would be the air-end (pump). has lost it clearances.
Apr 04, 2014 | Champion Air Tools & Compressors
Builds up pressure pop off valve at tank opens will not regulate pressure
I would say you have a problem with your pressure switch, you may need to adjust it down. The pressure switch is normally located under plastic cover where your on off switch is on the compressor. There should be a screw with arrows next to it. Try that, otherwise you may need a new switch
Sep 27, 2012 | Champion International Champion 2 Stage...
Need manual for air compressor 5 rca
That is made by Gardner Denver under the same model number. I could not find a manual for it but here is their site. I would contact them and see if they can furnish you one.
Gardner Denver
Aug 25, 2012 | Champion International Champion 2 Stage...
Having problems with my champion air compressor
Crankcase vent may be stopped up. Could have too much oil in the compressor.
May 28, 2010 | Champion International Champion 532 2...
Hi - While being moved, Speedaire compressor (model 32180) fell on its side. Side opposite pulley and dammaged unit directly opposite of pulley. I have no idea what the unit is called or its function. Was...
Lee,
I'll email you the breakdown. The pump is probably actually a 3Z180, made for Speedaire by Champion. If you are looking for the assembly sticking out of the back of the pump, it is probably the centrifugal unloader, which vents the pressure after the compressor shuts down. You can get the parts from Grainger parts (888-361-8649), or your local Champion compressor distributor.
Nov 06, 2009 | Air Tools & Compressors
Compressor not cycling and building pressure after servicing
Hi
I suspect you may have either overfilled the sump or used the wrong viscosity oil, may have splashed up onto valves and patially jammed one open.
Aug 11, 2009 | Champion International Champion 532 2...
Need wiring diagram for a kobalt 60 gallon 3.7 hp air compressor.
I have a Kobalt 60 Gal 3.7 hp air compressor. Send me your email address and I'll make sure you get your schematic. Hope this helps! MichaelGG@health.ok.gov
Jun 16, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
890 people viewed this question
Top Champion International Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Champion International Air Tool and Compressor Expert? Answer questions, earn points and help others
