Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishes are wet and the not drying
My dishes are wet, and not drying. how do i reset or get it to go on sanitize mode
    Problem Solver:
  • 14 Answers
Try using just the rinse aid in the tablets, don't put anymore rinse aid in the dispenser(This may take a while for it to empty) this should help with the drying.
failing that look at manual that will tell you how to put the extra heat programme on
Deep Diver
Posted on Jan 17, 2008
#FDB1500LFB2 does not dry dishes after sanitize
Hey friend, I appreciate your post!
From my understanding your Frigidaire dishwasher, FDB1500LFB2, is not drying dishes after the sanitize cycle. Check to make sure the heat dry option has been selected on your dishwasher panel. I would also check to make sure that the rinse aid dispenser has been filled.
Assure that the temperature going into your dishwasher is 120 degrees, which you can verify by using the sink closest to your dishwasher. If all of that checks out I would suggest seeking assistance from a professional for further diagnosis and repair. I hope this is helpful. -Matt
Oct 08, 2014 | Frigidaire Dishwashers
What causes grit to dry onto dishes after dishwasher has finished?
Check water hose leading to the dishwasher for deterioration..
May 11, 2014 | LG LDF6920ST Stainless Steel 24 in....
Dishes not dry after wash cycle
Hello uno203 - Hi - If the unit is not drying nor cleaning properly, there are two main things to check first. Is the incoming water temperature at least 120F (49C)? If not, I strongly suggest that the temperature be adjusted on your water heater. Are you using rinse aid? Use a rinse agent to increase drying performance and using Sanitize or Air Dry Off mode also helps improve drying. If any proves to be ineffective, contact a professional to move forward accurately. Unit may have an issue with the heating element or a communication problem with the board not responding.
Nov 12, 2012 | Electrolux 24 in. EDW5505EPS Stainless...
Frigidaire Dishwasher Model GLD4355RFS0 Will not sanitize and leaves dishes wet ?
One common issue on these units is the heater wire will fall off. If this happens, the dishwasher will not heat. Also make sure the rinse agent is full. On most of the newer dishwasher rinse agent must be used to help dry the dishes.
Appliance & Refrigerator Repair
Mar 23, 2011 | Frigidaire Dishwashers
Not drying and sanitize light is not coming on. Dishes are WET
is it draining ok? Are the cycles really long? if yes it might be a control module problem also found on other models.
Bosch Dishwasher Stuck on 2H
bosch dishwasher troubleshoot manual
I soldered mine. works.
keep us updated.
Nov 05, 2009 | Bosch Evolution 300 SHE33M05UC Stainless...
Kenmore Quiet Guard
You dont really need it, when the washer gets done Open the door for a minute and let the steam out and shut the door dishes will then dry. the reason there still wet is because of the steam from the Hot water
Sep 16, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishes are ALWAYS WET!!!
If the dishes are made of plastic they will be wet , they don't retain heat when in the drying cycle!
Aug 10, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Kenmore Dishwasher Not Sanitizing
You don't need an additive.
The sanitized LED itself is probably out.
It will not light up if the sensor doesn't sense that the water has reached 155 F. If the dishes are getting clean, I assume the heater is working properly. You could have a failed sensor, but you would usually notice longer than normal wash times and the dishwasher getting hotter than usual.
Alternately press heat dry and hi temp scrub 4 times. This puts washer into diagnostic mode. The first thing that happens is all the LED's light up. If it lights up then it is ok and the problem is somewhere else.
If these instructions don't apply to your machine, please post the complete model number from the decal just inside the front of the tub and I will look it up for you.
Nov 16, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
My Dishwasher does'nt dry my dishes.
How old is the dishwasher? Check the front control panel for a AIR DRY / HEAT DRY switch. Perhaps the switch is in the AIR DRY position. If so and you really want to HEAT DRY your dishes, set the switch for HEAT DRY. Otherwise: Second, it is not a bad thing to let your dishes AIR DRY. It saves money! Just open the Dish Washer door after the last rinse cycle has finished and let the dishes AIR DRY manually. In a hour or so they can usually be put away. Works for me :)
Nov 30, 2006 | Frigidaire 24 in. FDB510LC Free-standing...
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
415 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
