Question about Briggs & Stratton Garden
John Deere L118 stalls after it runs for about 3 mins. runs fine hard to turn over after it stalls. Have replaced battery changed gas replaced fuel filter. After sitting for 2-3 mins will start again but only runs for a short time. Briggs & Stratton 22hp 180 hours
    Sniper:
  • 197 Answers
2 problems are common with this machine.One is the earlier machines had bad placement of the fuel line at the tank causing it to get pinched off and restrict fuel flow.It may get pinched at the very top of tank where line starts or between very rear of tank and frame.2nd problem is with the decompression setting of the valves causing engine to have too much compression at start up.Set your valves when piston is a 1/4 inch past top-dead-center.Set your intakes at .004.
Posted on Nov 14, 2009
    Scholar:
  • 108 Answers
Those motors are funny. Oil level and oil delivery are essential. They have saftey shut off sensors if there is any problem with oil level. There aren't many hours on the motor for that to be an issue but check oil level, check it's color. If it's anyting but nice gold color (considering the low hours), you may have found your problem. Change filter, and flush (don't just drain and replace).
Posted on Oct 05, 2009
I have a John Deere JS30 self propelled lawn mower I had issues with it running for 15 minutes and then it stops running. Was low on oil. Added oil over the full line now it runs for 3 min and dies
Wayne, correct your oil level to full line, change your spark plug and try mower. If still acting up after a couple minutes, the Gas cap vent may be plugged, remove or loosen cap to see if mower will run longer and better. If no improvement, the carburetor is dirty and needs cleaned or rebuilt.
Lawn Mower Starts Then Stalls
How TECUMSEH FUEL CAP can Give You Problems
lawn mower troubleshooting
HOW TO CLEAN The Carburetor on BRIGGS Stratton Quantum Lawnmower Engines
Apr 03, 2016 | John Deere Garden
Runs for 10 min and stalls.
check your vent hole on fuel cap,or just loosing the gas cap so it can get air if this helps than you know it is the vent.
Aug 12, 2015 | John Deere Riding Lawn Mower. EZtrak Z225...
Tractor runs fine stalls like its out of diesel, 10 min. starts again runs awile, does same thing
Sounds like you have a fuel restriction, change out the fuel filter
it probablly is plugged up.
May 31, 2014 | Peg Perego John Deere Turf Tractor
84 john deere 410b stalls out
could be something floating around but did you fuel it one day and not the other try and run it with the gas cap off there is a vent on the cap that gets plugged
May 13, 2012 | John Deere Garden
My john deere l118 would not start only a clicking sound, so I replaced the battery but its still doing the same thing. any ideas?
use jumper cables and bypass the battery cables they do go bad check the safety switches as well
Apr 15, 2012 | John Deere Garden
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
Stalls after 20 mins. of running fine. (Starving for gas)
From the rear of machine look at the top left of fuel tank for the fuel line.Where line comes out of tank see if it is pinched where it goes down between frame and tank,grab line and see if it moves freely.If that is OK loosen fuel cap after 10 minutes of run time to see if your vent hole in cap is working.These are 2 common problems for the L series mowers.
May 22, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John deere runs then stops
I fixed my mower stalling issues on the L111 by loosening the gas cap. I ultimately drilled a hole in the gas cap and screened the hole. Sounds ridiculous but without that venting the engine would run approximately 20 mins and die. It was also much more difficult to start the next time. Something else to pass along to whomever might view this... I replaced the cranking battery with a battery that had allot more cranking amps and I no longer had hard start issues ( this was after I vented the gas cap). Hope this helps.
Aug 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
485 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
