Question about HP Pavilion dv9000z Notebook
Will not boot or power fully on.
When I push the power button it starts and the fan comes on but then all power is lost to the computer; it will then loop back and do this over and over until you pull the battery.
CHECKOUT demolaptopparts AT EBAY. NEW MOTHERBOARD WORKED GREAT. EASY INSTALL
Posted on Oct 08, 2009
Fan is running, power button with blue light is off, cpu won't boot up
Your cpu might have died. As the computer is starting tap F8 and choose last known good configuration to see if you can get it started.
Apr 26, 2009 | Gateway 500GR PC Desktop
On my laptop the vent fan starts then stop and the power goes out
These machines have a terrible overheating problem! You will have to clean the fan opening and, put sylicon grease on the heat pipe and, heatsink that covers the cpu
Apr 04, 2009 | HP Pavilion dv9000z Notebook
Toshiba M45-S165 startup issues
This is normally a motherboard issue. I had one with the same symptoms and I had to replace the motherboard. Worked great after the board was replaced. I had to replace the board because unlike your issue mine stopped working all together. It did take a while before it quit though. Just a note: I have had to replace several of these motherboards for customers as well. If your LCD is broken, you may be better off to save your data and put it in a new laptop that would include a warranty unless your super fond of the machine or you have access to inexpensive parts.
Hope this helps...
Jan 30, 2009 | Toshiba Satellite M45-S165 Notebook
Friend has a Emachine T1862 that won't start
May be the CPU fan is going bad. I hope it is that simple.
Dec 14, 2008 | E-Machines Computers & Internet
T1150 emachine Computer not booting up correctly
did you hear any beeps from the bios? Try to remove all the peripherals like all the PCI cards, specially the "video card", your ram's,. Once you removed and cleaned all of those, put it back,make sure that theres no loose connections and boot the computer.
Nov 29, 2008 | E-Machines T1150 PC Desktop
I'm having problems starting my desktop computer. After I push the power button, I hear the computer working but it doesn't fully com on. There's no display on the monitor and I continue to hear the...
When you say you hear the computer working and working do you mean that the fans are going and the lights are on?
i ask this because the fans and power lights can come on just from the power supply coming on when you push power but that doesn’t necessarily mean the cpu is functioning.
Do you hear a post system beep and the hard drive reading files also?
Or does it just sound like only the fans cam on ?
If you think that possibly only the fans are working then try this
Shut down the computer and unplug the power cable.
Check to make sure monitor cable is connected all the way
Open the case and check to see that the video card is inserted all the way into the board properly
Remove the memory (RAM) and then put it back in to make sure it is properly seated in the slots
Plug in computer and try it again and if it still does not work then try clearing CMOS
on some systems you can clear the CMOS very easily by just holding down the insert key on your keyboard while pressing power button and continue to hold it down when releasing power button until you see something on the screen but since this does not work on all computers you might have to do it manually by moving the CMOS jumper on the board
(the CMOS jumper on the motherboard is usually the one closest to the little battery that you see on the board. with the computer off move the jumper over one notch to the other pin for a second and then put it back where it was (there are usually only three pins so this is easy step)
You should now be able to boot but you will need to go into the CMOS setup and set the clock again and other settings
If you still have a blank screen then let me know and i will take you to the next diagnostic step...
Hope this info helps
Nov 19, 2008 | Computers & Internet
HP Compaq nc6000 won't come on
well make sure the battery is fully charged you could have a bad motherboard or no memeory inside it check those first
Nov 08, 2008 | HP Compaq nc6000 Notebook
Power ON/ nothing on screen-
enter the bios setup, if you can boot the computer/laptop. Usually F2 on bootup, it will say entering Setup.
Then scroll through the pages to see if your hard-drive is recognised by the system.
Mike @ Compurepair.
Feb 24, 2008 | Acer Aspire 5100-5022 Notebook
Computer powers off during boot
Hmmm...try resetting CMOS & checking all external peripheral connections: (KB/mouse, monitor, etc.)
Oct 26, 2007 | ASUS A8N-E Motherboard
HP Pavilion dv9000z Notebook Logo
121 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
