Question about Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier
How do you clean the vaporizer? - Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier
    President:
  • 2,976 Answers
Take it apart, and UNPLUG IT. soak the blades in vinegar for about 30 minutes. That will soften the deposits. Wipe clean and if necessary, repeat. rinse and it's ready to use.
Posted on Oct 04, 2009
My vaporizer is running however there is no steam coming from the machine. Ran all night and used no water does it need cleaned or should i just replace it. thank you
Well, let's consider what we have:
How old is the vaporizer?-- Could the heating coil be all limed up?
Lime-Away, or Vinegar might help clear the Calcium and mineral build up on the heating element-
Or there might be a bad connection?-- Do you have any lights lit?
Open it up, and tell us what you find-
Mack B
Jan 20, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vaporizer is spitting water
You added too much salt. Clean it out, start over with less salt.
Feb 08, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vaporizer is barely putting out any steam...is there a way to clean this unit so that it will produce more steam? This is a Vicks 1.5 gal unit.
Is the water in your area soft? If so, add a few pinches of salt. Vaporizers boil the water by running electricity through it. If your water is too soft, no electricity and therefore no steam.
If you have hard water, and the unit must be cleaned, try soaking it in vinegar.
Dec 24, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
This vaporizer is supposed to run for 10 - 12 hours, and mine only runs for about 5. What can I do to change this?
clean out any deposits with white vinigar (soak for a few hours) or use a special cleaner for this ... the deposits will keep the unit from using all the available water .. if it is using all the water in 5 hours then your vaporizer may not be big enough for the area you are trying to humidify ..
Oct 16, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vicks steam vaporizer
i do apologize for the inconvenience but the unit will need to be cleaned by hand or you can go to a local hardware store and get a solution that you put in your water to help kill the residue. it's basically from your hard water. now if you do it by hand you will need to get a soft toothbrush. you'll have to scrub the coils. then rinse the particals away. now doing this the unit needs to be turned off and cooled. after you do the cleaning you can run it like normal. if you have any other concerns or questions please feel free to ask.
Jun 11, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Looking for manual instructions to clean vaporizer with vinegar
all you need is a capful of vinegar mixed into the water and it will clean it like new again
Feb 21, 2009 | Bionaire Warm Mist BWM0400-U Humidifier
Humidifier leaves a crusty dark substance in water
SPECIAL NOTES
Discoloration/Black Particles
After use, the water residue in the bottom of the container may contain black particles, and, in
some areas the water and the bottom of container may discolor. These conditions are normal and
do not effect the purity of the steam or medicine. The container is easily cleaned with soap and
water. Rinse and dry the container after cleaning.
This was taken from the manual that comes with the humidifier...
Dec 12, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vaporizer is making a spitting sound -
No salt, unless you had 0 steam - to stop water spit, throughly clean the water tank, just as clean as new. It will work like new if the tank is as clean as new! I dont know where the small particles of dirt come from, but trust me, I just went thru this with mine, it's got dirt in it!
Nov 19, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Air o swiss 7133 doesn't send out any vapor
Interestingly enough as soon as I posted here, I was able to find the source of the problem. It appears that during cleaning the water level sensor, a bobber which normally floats as the water level rises, became stuck the to bottom of the water base - see below for the picture. I was able to use a small wooden spoon to lightly apply pressure and release the bobber so that it could float, and instantly the vapor started flowing again.
Aug 24, 2008 | Air-O-Swiss 7133 Humidifier
Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier Logo
757 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
