Question about Motorola Mobility StarTAC ST7868W Cellular Phone
Copy numbers from current sim to phone? - Motorola Mobility StarTAC ST7868W Cellular Phone
How can i unlock sim to use on diffrent carrier
SIM cannot be used on another carrier, but your phone can be unlocked to use another carrier's SIM. You can also transfer your existing number to the new SIM by contacting your existing carrier and requesting a PAC code. Then contact your new carrier and give them the PAC code to transfer the number.
Any contacts stored on your current SIM can be copied to the phone memory or exported as a file, then copied back to your new SIM if required.
May 05, 2016 | Cell Phones
How do I copy phone book entries to another handset?
1) Copy the contacts onto the SIM on the current handset, place that SIM into the destination phone and either access them from the SIM or copy them onto the new phone.
2) If no SIM then you may need to connect the phone to a PC and copy them using either a s/w program supplied with the phone or downloaded then connect your new phone and import them onto that device.
Sep 28, 2014 | Cell Phones
I want to copy my contacts to my sim.I am using a HTC Wildfire S phone and i have got a new phone.WQhen i put the sim i am using now into my new phone there is no contacts
To transfer contacts from your current phone to a new phone by means of a SIM card, do the following:
  1. On your current phone, download the Copy to SIM Card app on the Google Play Store.
  2. Use the app to write all your current contacts that will fit on the SIM card.
  3. After writing is complete, put the SIM card in new phone.
  4. If new phone has built in SIM manager, use that to transfer contacts from SIM. If not, again use Copy to SIM Card to transfer contacts from SIM to phone.
Nov 05, 2012 | Cell Phones
MODEL NOKIA 6021 CONTACTS STORED IN PHONE MEMORY DELETED BY MISTAKE HOW CAN I RETRIEVE IT?
H,
Once you delete the phone numbers from phone then it is not possible to retrive the phone numbers.
If you saved the numbers in SIM card then you can copy to phone memory.
To copy contacts from SIM card to phone,Contacts > Copy. You can copy names and phone numbers from the phone contact memory to the SIM card memory or vice versa.
Thank You
Aug 11, 2010 | Nokia 6021 Cellular Phone
Motorola Razor had all my phone numbers on sim lost
if you have backup in phone memory then you have to go to backup on your phone and get your all number
May 18, 2017 | Motorola Mobility RAZR V3
Transfer phone numbers from my phone to my sim card
may i respectfully suggest the use of a sim manager device. it is available on gadget stores on affordable prices. what specific phone model was it?
Feb 18, 2009 | Samsung Cell Phones
How do i transfer my contacts from phone to sim - Nokia 5140i
Search for the contact you want to copy and select Options > Copy. You can copy
memory, or vice versa. The SIM card memory can save names with one phone
number attached to them.
Oct 06, 2008 | Nokia 5140i Cellular Phone
Contacts
If you have phone numbers stored on the SIM card, copy them to Contacts. Entries that are saved ONLY on the SIM card are not shown in the contacts directory. So for incoming calls and msgs, the phone cannot match the number to the name.
To copy individual names and numbers from a SIM card to your phone contacts:
Menu/Contacts/Options/SIM contacts/Sim directory. Select the names you want to copy and: Options/Copy to contacts.
Feb 08, 2008 | Nokia N70 Cellular Phone
Copy phone book to sim card
go to contacts select the option , scroll to copy contacts then highight copy from phone to sim.
allen8354 - no you can not , what you will have to do is rename the contact to home number,cell number, work number under one name on the sim.
Dec 09, 2007 | Samsung SGH-d807 Cellular Phone
Cant copy the numbers from my phone to my new sim card
  this problem is due the sim space may be u have 32k or16 k sim  . so memory is nt  enough to save  all the contacts - so do these things to solve ur problem ..
1) if u have an alternative sim   which is 64 k sim then copy all the contacts  in that sim then transfer them to ur required phone afterwards ...
 2) if u any other alternate phone than transfer half the contacts in first atempt than transfer rest the contacts in other atempt...
Sep 20, 2007 | Sony Ericsson T610
Motorola Mobility StarTAC ST7868W Cellular Phone Logo
32 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
