Question about HP Easy Refill Kit for (HP) Color Inkjet Cartridges Printer
My computer had to be restored to factory,and i lost my installation disk for my hpofficejet j4540 all-in-one printer and can't get it installed
  • 8,197 Answers
Posted on Oct 04, 2009
How to preform a factory reset
Step 1:
Restart your computer then press F8 key many times until the restore setting was appear. Do this before the windows logo appear. Then select Restore Mode and follow what was the instructions in the computer to complete the restore settings.
Step 2:
If not so, perform re-install of windows 8 operating system. Just insert the windows 8 DVD into your disk drive.
Step 3:
Or else you just reprogram the Operating System of your computer using the previous windows that you used.
Apr 05, 2013 | Computers & Internet
Mi notebook acer aspire 3000LCi the only do is a an upper and i dont have a recovery disk
When you restore your system back to the new factory settings, it will wipe your hard drive clean and do a fresh install of the operating system with the original factory setting.
To start this process, unplug all extra devices from your computer
(printers, external hard drives, etc.) as these can interfere with the system restore.
Starting with Windows XP, most systems with issued a system recovery disk in case of any problems with the factory installation.
Check the documentation and disks that came with your computer to determine if you have one of these system disks.
If you do have a copy of this disk, place it in your CD/DVD drive and restart your computer.
If you do NOT have a copy of this disc, skip to step 3 for further instructions.
Once you restart your computer, a screen will appear with the words.
Press Any Key to Boot From CD. Once you press a key, a screen will come up containing instructions to format your hard drive and restore the original factory settings.
Follow the on-screen prompts to finish the installation.
Once the restore is complete, remove your Recovery CD from the disk drive so that your computer does not try to boot from the CD again.
Restart your computer to complete the restore.
3. If you do not have a System Restore disk, then your computer should have a recovery partition on your hard drive, separate from the main partition of the disk.
Unplug all external devices and restart your computer.
When the loading screen comes on with the Windows logo, press Alt+F10 together five times.
This will bring up the system restore menu.
Follow the on-screen prompts to restore your computer back to the factory settings
hope this helps
Oct 17, 2012 | Acer Aspire 5610-4648 Notebook
I need to install my HPOfficejet J6413 All-in-One Printer/Scanner/Fax
YOU NEED TO INSTALL YOUR SOFTWARE FIRST...SO INSERT YOUR DISK...PLEASE MAKE SURE YOUR PRINTER IS NOT HOOKED UP TO YOUR COMPUTER YET...CLICK ON START...GO TO CONTROL PANEL...GO TO INSTALL NEW SOFTWARE.
(NOTE) SOFTWARE HAS TO BE INSTALLED BEFORE HARDWARE
AFTER SOFTWARE IS INSTALLED...YOU WILL WANT TO DO A RESTART...UPON RESTART...HOOK YOUR PRINTER UP TO ANY USB PORT...AGAIN... GO TO ...START...CONTROL PANEL...TYPE IN PRINTERS...GO TO INSTALL NEW PRINTER.
YOU'LL NEED TO DO ANOTHER RESTART...SO TOO MAKE SURE YOUR COMPUTER DETECTS THE NEW SOFTWARE AND HARDWARE. YOU CAN ALSO GO TO...PRINTERS...(FROM YOUR START...TYPE IN PRINTERS...SEE IF THIS PRINTER IS THERE? IF THERE, CLICK ON IT...GO TO PROPERTIES...DO A TEST PRINT!
NEED FURTHER ADDITIONAL HELP...PLEASE DON'T HESITATE TO CONTACT ME!
HAPPY PRINTING!
MARTIE
Sep 06, 2011 | HP Computers & Internet
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
Everytime i put in the disk for the officejet j4500 it says my computer isn't compatable with this unit I run windows 7 it says to fix the problem before going on
For that you need to install windows 7 drivers in your computer.
Drivers are same for j4500 series so you can install driver of j4540 because driver are same for j4500 series.
click here
Click on above link and select any mdel and then select os then download driver also there is some updates download updates too then install.
Then it will work .
Let me know if you need further assistance.
Thanks for using FixYa.
May 26, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do i use the restoration disks to fix my computer (restore it)
What you will want to do is find the First Restoration Disk and put it into the CD/DVD drive and restart the computer. When the Computer starts you will want to start the computer from the CD/DVD drive, and follow the directions that are on the screen to use the disks. Please remember every time when doing this Back-up everything you want to keep from being lost!!! Even more so now that you are restoring the computer, there are times that the restoration disks will not allow you the option of repairing the installation and go straight to Complete Factory Defaults.
Oct 16, 2009 | Acer Aspire 3000 Notebook
Restoring averatec 3150 laptop to factory setings
With no disk you cannot restore your computer to a factory settings, at least that your computer has a second disk with the restore settings installed on it (usually this disk is called restored)
Nov 09, 2008 | Computers & Internet
We just bought a HP Officejet J4540. I've inserted the disk & now nothing will install.
Hi rognvirg,
Let me ask this, did you hook the printer up to the computer before you installed the software. If so, un-install printer(uncable from computer) and printer software. Reboot your computer and install the software first, follow the setup wizard to the letter. In the event that doesn't help try rolling your computer back a week or so or try downloading new software from the printer manufacturers website(drivers/downloads and sometimes support. And if all else fails, take it back to the store and exchange for a different one. I hope this helps you.
Thank you for using FixYa.com
Sincerely, cyyyd7
Oct 11, 2008 | HP Office Equipment & Supplies
Seeker5211
Seeker5211
