Question about Kenmore Dryers
My dryer stopped working in the middle of the cycle and will not restart. I have checked the breaker and it is not tripped.
  • Kenmore Master
  • 7,482 Answers
Your problem could be a faulty timer switch, faulty motor, broken belt, or belt that has slipped off of the motor pulley or idler arm pulley.
If you have a front loading machine, remove the front to expose the belt and drum, this will tell you if you have a belt problem...if you remove the drum and belt, this will expose the motor with pulley and idler arm pulley. You can then check the motor.
While you have the drum out, I also recommend that you lubricate the shaft of the drum rollers with a good grade of Machine Oil....such as 3 in One oil...this will save problems later down the line.
Good luck,
Hope this helps
Posted on Oct 04, 2009
What part need to replace LG DLGX5171V keep getting power Trip or stop working
Check wires going to motor. Must be a short there.
Aug 16, 2017 | LG Dryers
I have an admiral electric dryer. It stopped in the middle of a cycle and the light is out and it won't turn on. I checked the fuse box, the plug and the belt is still on, so what do I do now?
Did you test the power outlet with another device...Sometimes a power outlet will fail under the load of a high current appliance like a drier...If the drier runs on 220 volt current...and have circuit breakers instead of fuses...make sure the 220 volt breaker for the dryer is not tripped...If it is tripped...reset it....if not...have a tech to check the outlet. oncee it is established that the drier is getting power and still not working...you may want to get it checked out by service personnel....Hope this was helpful....PEACE.....
Jan 25, 2012 | Admiral Dryers
Help
You will need to check for any blown fuses or tripped circuit breakers. Electric dryers should have the wiring checked at the terminal block to make sure that the connection is good, or to verify that the connection is burnt out.
If the power is there, you have to check the door switch, thermal fuse, thermostats, and start switch to see if one of these is faulty.
Good Luck and have a nice day
Rating the solution is highly appreciated
Jun 17, 2010 | Frigidaire GLEQ332A Electric Dryer
Dryer was working, quit in middle of cycle. Will
It's rather unusual for any internal failure to cause the dryer to just stop in cycle. Check the circuit breaker that supplies the dryer. It should be a double-pole breaker of at least 30 amps. Turn the breaker off and back on to ensure it is reset. Internal causes could be the motor, door switch, thermal safety switch, timer, or a broken wire.
Apr 30, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore Ultra Care Dryer- Electric
Your dryer doesnt have a fuse. Your home breaker panel is the only protection it has..Check your circuit breaker box for a tripped breaker.
Oct 22, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
61 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
