Question about GE Dryers
GE Electric dryer doesn't produce any heat. Before the heat totally went out, it would not self-regulate itself to stop producing heat. We would need to turn it off manually. Can you please tell us what you think the issue is and the estimate for the cost of this repair.
  • GE Master
  • 7,482 Answers
I do not know the cost of repairs, but it sounds like your thermostats, and or the timer switch is faulty.
You will need to contact an appliance repair man in your area to determine the cost of repair.
I hope this helps
Posted on Oct 04, 2009
My Magtag dryer model#DG612 (series 05) stopped producing heat to dry the clothes. There was a flame for approx two minutes, and then the fame went out. What can I do to fix this problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 28, 2011 | Dryers
GE dskp333ecoww electric dryer no longer producing heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 18, 2010 | GE Dryers
My gas dryer stopped producing heat produce heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 28, 2010 | Maytag Atlantis MDE7400A Gas Dryer
Dryer has stopped producing heat
I have a Thin Twin manual that will give you an idea of where to start:
THIN TWIN SERVICE MANUAL
Jul 12, 2010 | Whirlpool WHP1500S Electric Dryer
Our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
Mar 20, 2010 | GE Dryers
My dryer spins and heat just a little but not enough to dry any clothes
Need to change the heater filament. The heater filament has several portions to produce heat. As it ages, some portions are not producing heat anymore hence the total heat produced by an old filament can not put out as much as originally designed.
Jan 08, 2010 | Estate EED4300TQ Electric Dryer
My dryer does not produce heat Model #pcks443eb1ww
Could be a thermal fuse, which is generally the problem. It's cheaper than replacing the whole heating element. Try that first, or you can even test it, if you have a voltage meter.
You can also check to see if your vents are blocked. If airflow is blocked, it can turn off the flame, and not produce any heat. You can take off the vent hose and turn the machine on to see see if you get airflow, or if the ignitor kicks on the heat.
Oct 31, 2009 | GE DSKP233EWWH Electric Portable Dryer
Dryer works but does not produce heat
THE HEATING ELEMENT NEEDS TO BE REPLACED, NEED A SERVICE TECH, IT IS NOT A COSTLY PROBLEM , IF YOU AVE THE ORIGINAL BOOK IT SHOULD TELL YOU HOW TO DO IT YOUR SELF JUST ORDER THE PART THRU THE COMPANY IT'S NOT THAT HARD TO DO,
May 29, 2009 | Maytag Neptune MDE6700A Electric Dryer
My Dryer has stop producing heat
hi mark it the heating coil in the back of the dryer
Feb 10, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
