Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Kitchenaid Household stand mixer. Model no.
I was mixing pasta dough and mixer began to make a rattle noise - still turns but noise is not right. Also a little grease always dripped in mixing bowl ever since I first bought it new.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 143 Answers
It is hard to tell you exactly what it could be, but a common problem is after a while the transmission gasket does deteriorate and will begin to leak oil.the gasket is part number4162324. the rattling noise inside your unit is most likely cause by a chipped gear inside, this can happen when the unit is put under heavy loads, such as dough. this problem could get worse as there may be fragments inside that will damage it more.hope this helps
Thanks
Posted on Oct 11, 2009
Brand new Kitchen Aid. Loose Bowl,
go talk to the place you bought it .
Dec 09, 2017 | Food Mixers
A-200 hobart mixer grease leak, there is grease present in some of the doughs that we make, black streaks but there is nothing dripping on to the dough...
several reasons
too much grease worn bearings or bushes not holding the shaft in the center
worn out grease seal;
the fix is an overhaul and seal replacement
Nov 01, 2017 | Hobart Food Mixers
Oil in mixing bowl during operation from motor head
there is 6 oz of a food safe lubricant in the motor housing that is held in by a gasket around the front of the gear housing in the top of the mixer, the gasket is leaking the separated liquid of the grease. The grease because it is a vegetable based product separates over periods of non use and the gasket gets soaked and releases the liquid into parts of your mixer and it drips it's way out when you use it. the best thing to do is install a new gasket and remove the old grease then repack and add a new gasket. There wasn't that easy?? problem is that most people don't know where to buy the KA approved grease and gasket (ebay about 17.00) and most people don't know how to take their mixer apart to do this, (youtube has about four really good step by step videos on how to do it) BUT!!!! there is a trick that often works, seriously!!! get a towel and spread it on an open work space, grab your significant other or any one that will tolerate you when you get this way you will need their hand. Now turn the mixer upside down (no I'm not being sarcastic) turn it upside down, now have your partner hold it while you reach down and plug it in and turn it to speed Two, and hold the mixer like that for two minutes, (that's why it's better to have a really good friend help you they won't tell you how nuts you are doing this, but!! continue. After two minutes turn the mixer off and turn it right side up and turn it on again for two minutes, then do it all over again upside down then right side up, do this at least three times. the drip is now fixed. You think I'm nutz right??? Wrong!!! What you have done is re-mix the gear grease, the liquids are now re-mixed with the solids or gear grease base material. It should last about a year or so. My suggestion is to do this once or twice a year if you are not going to use the mixer for long periods of time. The separation usually happens when the mixer goes for long periods of time without use. the grease is designed to work for five or ten years without being replaced. however the gasket is made of fiber and the weight of the motor head pressing down on it for a few years of say 17 pounds causes it to compress and allow the liquids to leak out. So to fix that you take of the drip ring off (round silver thing that attaches to the planetary ) then drive out the little silver pin in the planetary shaft and pry off the planetary. you will then see five flat head screws that hold the motor head to the lower gear case, thightem them up and re-assemble the mixer then remix the grease, you have fixed your drip problem without spending a dime and it will stay fixed for years as long as you have no other issues arise during it's life. Hope that helps you.
Jan 31, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid 525 stopped working while mixing cookie dough
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Dec 15, 2012 | KitchenAid KP2671 Professional 6 Series...
How do you use the KitchenAid SNFGA Pasta Maker Attachment
If it's gumming up, the dough is too wet and needs to be dried out more by adding flour. The right consistency dough is such that if you tear off a small piece and then tear it in half and squeeze it back together with your fingers it should stick back together but not stay stuck to your fingers. If it stays stuck to your fingers it's too wet and needs more flour. If it is crumbly, it's too dry and needs more water.
Apr 24, 2010 | KitchenAid K45SS Classic Stand Mixer
Mixer head loose
Referring to the diagram on:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10157992.pdf
Remove the screw, item 22, to remove the trim band around the mixer. This will reveal 4 screws which hold the top cover on. Remove the screws and lift the top off. Find all the screws which hold the gearhead in place and tighten them all. If you want to make the fix a permanent one put some thread-loc compound on each screw and tighten it.
Mar 28, 2010 | KitchenAid KL26M8XOB Stand Mixer
Kitchenaid Heavy Duty 325 stand mixer. Making cookies and now the motor runs but it doesn't turn to mix. PLease help/.
kITCHEN AID ARTISAN 325 WATTS TILTING HEAD PIN CAME OF WHILE MIXING DOUGH. HOW IS THE EASIEST WAY TO INERT PIN BACK OR LINE UP THE HOLES TO INSERT PIN?.
FRANKAMOR
Feb 06, 2010 | KitchenAid KSM5PS Heavy Duty Stand Mixer
MY KITCHENAID MIXER MODEL # KSM5 TURNS ON BUT THE BEATERS WONT TURN. I MIXED UP SOME PIZZA DOUGH AND GUESS I BROKE SOME GEARS OR SOMETHING. PLEASE HELP!!!!!!!!! THANK YOU
The most common part to fail in this mixer is the worm gear:
http://kitchenaidmixerspares.co.uk/Home/tabid/36/p/Mixer-Part---Worm-Gear-and-Bracket-240309-2/ProductID/103/CategoryID/17/Default.aspx
Oct 31, 2009 | KitchenAid K45SS Classic Stand Mixer
The dough hook is stuck in the beater shaft of kitchenaid mixer
It sounds like it got overloaded when you last mixed dough. It will only come off the way it went on. If it has been bent on, it may need a bit of gentle encouragement.
Jun 15, 2009 | KitchenAid KSM50PR Professional Series...
Bread dough hook slips when mixing
This is not a solution but I think you have a serious problem you might have sheared some gear teeth whent the mixer jammed and it only manifests itself under a heavy load, I would take it to a repair guy, those mixers are expensive and it would be worth it.
Mar 28, 2009 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
534 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
