Question about Epson Stylus NX400 InkJet Printer
Replaced black ink cartridge (69)
After replacing the cartridge, the printer doesn't recognize that the new cartridge has been replaced. I have cleaned all of the cartridges, re-inserted them and still no luck.. The screen still says "Replace ink cartridges. OK to proceed
  • 10 Answers
SOURCE: Just installed Epson NX400 printer.
If you have re-inserted the inks, then you might have a faulty ink cartridge. M88/69 indicates Magenta is not recognized and B88/69 is for black. You can have the store replace those inks for you or contact Epson tech support.
Posted on Jan 03, 2009
SOURCE: epson r340 ink cartridges not recognized
god pm my printer ako na epson r230 ang problem niya ay walang lumalabas na output paano irepair yong
Posted on Feb 13, 2009
SOURCE: epson stylus cx8400 cannot recognize ink cartridges
I had the same problem except it would not recognize any of the ink cartridges. I kept hitting the OK button over and over again with the same cartridges in place not removing them at all and it finally recognized them. Decided to go to maintenance on the printer to do a test, and it went right back to not recognizing the cartridges. So i pressed the OK button over and over again until it finally recognized all the cartridges again, but this time i did not try and go into the maintenance to do a test run. Plugged it up to the computer and it has been working ever since. So press the OK button until it recognizes the cartridges, and run no tests on it is what my solution was for the problem. Really is a pain but it works now.
Posted on Apr 06, 2009
sherlyn c
  • 134 Answers
SOURCE: My Epson NX 400 is giving me this error message:Error B88/69/68 C
Try to run the ink pad reset utility software.
Please log on to epson.com. The software runs on win xp and win vista.
Posted on May 03, 2009
don_farr
  • 1018 Answers
SOURCE: Ink cartridge not recognized. But ink is new!
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Jan 19, 2010
Testimonial: "Thanks, i'll surely do it. "
I replaced a black cartdridge epson sx 510w, but the printer doesn't recognized it?
I would recommend the following:
  • Remove the cartridge from the printer.
  • Turn the printer off.
  • Wait 30-60 seconds.
  • Turn the printer back on.
  • Reinstall the ink cartridge.
If the printer still doesn't recognise the cartridge it is likely to be faulty. In which case I would recommend seeking a replacement from wherever it was purchased.
Feb 27, 2013 | Epson Office Equipment & Supplies
BOUGHT NEW CARTRIGE FOR MY NX 415 AND THEY AREN;T REGOGNIZED!
If the cartridge is not the same code as the previous used by the printer, then it will not be compatible. Your printer has been replaced by Epson Stylus NX415 All-in-One
  • One 69 Black Ink cartridge (T069120)
  • One 69 Cyan Ink cartridge (T069220)
  • One 69 Magenta Ink cartridge (T069320)
  • One 69 Yellow Ink cartridge (T069420)
  • Therefore, ensure that the catridge follows the above code (69).
    Best regards.
    Jun 10, 2011 | Epson Stylus NX400 InkJet Printer
    Just purchase and set up Epson Stylus CX9400 Fax Series. States "Cannot recognize ink cartridges." It also has a RED box with a Y and a YELLOW box with a Y both have same number (69) next to them Removed...
    Make sure cartridges are part number 69 on all four or 68 on the black if its the high cap cart.
    Also check the carts contacts and the machines contacts in the cartridge recetacle for contamination or damage.
    Apr 27, 2010 | Epson Stylus CX9400 Photo Printer
    Epson rx680
    one ink cartridge is out of ink but...
    when we try to replace one of the color ink cartridges we get this error message:
    ink cartridges cannot be recognized. make sure ink cartridges are installed correctly - how do I get the printer to recognize my full ink cartridge?
    Sep 18, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
    My ESP 7 printer will not accept that a new black ink cartridge has been inserted. I've tried 2 new ones, same with both.
    Black ink cartridge is not recognized. I installed a new cartridge last week and had no problems printing till 2 days ago. What can I do to resolve this?
    Sep 13, 2009 | Office Equipment & Supplies
    I just replaced black ink cartridge and snapped all cartridges back in place and recharged the printer now it wont recognize the black ink cartridge even though it was just replaced
    Try wiping the copper contacts on the new cartridge with a dustfree cloth dampened with some alcohol. Dry thoroughly before reinstalling.
    May 05, 2009 | Office Equipment & Supplies
    REPLACED TWO 68 CARTRIDGES IN CX9400 EPSON
    Generic carts are sometimes not recognized. Epson's chips are the cause. I solved this problem for a small investment. I purchased a CISS system for about $75.00 [ink included], that's the cost of OEM carts that do not last very long. The CX9400Fax is an Ink Hog, which is why the printer is so cheap. If you want a CISS go to http://www.inkproducts.com/ink-store/ They are great if you need help and will call you back in less than an hour. Get the Waste Ink Kit when ordering the CISS.
    Apr 05, 2009 | Epson Stylus CX9400 Photo Printer
    Mar 31, 2009 | Epson Stylus NX400 InkJet Printer
    Just installed Epson NX400 printer. Keep getting M88/69 "Cannot recognize ink cartridges" error. Tried re-inserting cartidges twice already and still same error. What next?
    I found a solution to the same prolem that you guys have. I took the cartridges out and shook them horizontally, instead of vertically, with the large surface up for 3-4 seconds. Re-inserted them back in. Then I started seeing on the LCD "Recharging Cartridge". When it returned to regular copy screen, I turned the printer off and turned it back on. No more error message. It's been working for almost a day now. Try it to see if that works for you. Good Luck.
    FYI. I just bought NX400 last Friday. The error message came on this morning.
    Jan 01, 2009 | Epson Stylus NX400 InkJet Printer
    Epson Stylus NX400 InkJet Printer Logo
    29 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
