Question about Briggs & Stratton Garden
B&S 400707 1222-01 Flywheel has ''locked up.''
  • 3,230 Answers
Well the problem seems due to broken flywheel key. See if you can remove the flywheel and look at the keyway.
To remove the flywheel - take a nut with the same size threads as the one that holds the flywheel on. With your weak hand, lift the flywheel with a little upward pressure. With the strong hand, tap the nut with a wooden mallot if you have one. when you opened it you will be able to see if that is the problem.
Good Luck!!
Thanks
Posted on Oct 04, 2009
Citroen Berlingo 1.9d. 2002. Fitted with DELPHI injector pump. Timing of cam belt & flywheel is by locking
I have been doing research on the Delphi pump and it apparently is associated with lucas/cav and as such is timed by the use of a dial test indicator that, through the use of a plunger and cam, runs on the cam block in the pump and determines when injection begins. Initial timing is to set the flywheel on the injection timing mark and the pump flange mark set on the timing case mark. To get it exact I would recommend that you have a diesel pump shop do the timing using the correct tools. As the pump is not electronic as such (from my research into Delphi ) it is basically a manual injector with a electronic controlled governor. Any way the best advice is to have a pump expert set the timing.
Jan 05, 2014 | 2004 Citroen Berlingo 1.9
Flywheel key on 12.5 hp B & S engine
remove the upper cover and the nut that holds it down you should be able to see it then use a puller to remove the flywheel
Jul 03, 2012 | Garden
I need to replace one of the front brackets and can't find one
Dear Sir:
Attached is a copy how to fix a bracket.
How to remove flywheel (97):
Put a set of locking pliers on small shaft end (WD-40 or some other similar lubricant may be necessary to loosen the threads on the motor's flywheel.)
Turn the motor clockwise to loosen off the old shaft.
Spin the new motor shaft in a counter-clock wise direction, use pliers to lock in place.
http://www.youtube.com/watch?v=zXeHMWTcLUY&feature=related
Please the video, and it will guide you.
go to next web, if you need to buy some bracket:
www.fitnessrepairparts.com
If you need further assistance, please reach me.
E.CUADRA
Oct 17, 2011 | Proform 570 CrossWalk Treadmill
A friend took the flywheel off the motor that I'm trying to get back into my 1999 ford escort. I'm trying to figure out how to re- install it. Does the flywheel go on first then the plate behind...
I"M not bsure what plate you are referring to, I think it may be the locking tab plate for the flywheel bolts, is the flywheel goes on first then the holding bolts go through the locking plate & when the bolts have been tightened up the tabs on the locking plate are bent over the head of the bolts to stop them from coming undone, you need to make sure that the tabs are very secure on the bolt heads, use a small hammer to hit them down unto the bolt heads.......hope this helps.......cheers.
Sep 03, 2011 | Ford Escort Cars & Trucks
What is the best way to prevent the crankshaft from rotating when loosening & tightening the flywheel nut on a small, single cylinder gasoline engine. I want to change the contact points.
There are a number of ways to lock the engine, there are special tools that fit into four places on the flywheel fins, there are piston stops, you remove the spark plug and re fit this through the plug hole which locks the piston, you can tie a knot in a peice of starter cord, feed this through the spark plug hole, bring the piston up to top dead centre, the knot will come up against the cylinder head and lock the engine, as you see there are many ways, but be carefull when entering anything into the cylinder
Apr 12, 2011 | Poulan 14" Chainsaw
Need a copy of the manual pages, showing how to replace the clutch
Removal & Installation To Remove:
  1. Remove the transmission.
  2. Install a flywheel locking tool.
  3. Remove the pressure plate mounting bolts from the flywheel.
  4. Remove the pressure plate and clutch disc.
To Install:
  1. Insert a clutch disc alignment tool through the disc splines and into the flywheel pilot bearing. Pressure plate balance mark location subaru-07-00-6722.gif
  2. Install the pressure plate on the flywheel with a gap of 120° or more between the "0" balance marks on the flywheel and pressure plate. Hand tighten the pressure plate mounting bolts.
  3. Tighten the pressure plate mounting bolts using a crisscross pattern 12 ft-lb (16 Nm).
  4. Remove the clutch disc alignment tool.
  5. Install the transmission.
Dec 28, 2010 | 1998 Subaru Legacy
How to remove the damper bolt on a 1997 honda
safely raise & support vehicle, lock down flywheel, remove wheel, get a really big breaker bar 1/2 inch drive. a long extension . the apropriate 6-point socket & a jack for all these tools. assemble the socket/extension/breaker bar, set onto the bolt on the crankshaft, support the extension close to the head of the breaker bar with the extra jack stand & use this extra leverage to break the bolt loose by pushing down towards the ground on the breaker bar using the jack stand as a fulcrum. You MUST lock down the flywheel with the right tools for this operation to work. Do disable all electrical before you start this operation to avoid injury from accidental starting of the vehicle.
Nov 03, 2009 | 1997 Honda Civic
Cost to replace starter & flywheel on a 2003
for the starter and flywheel 1400 sounds right they would have to take the tranny out to get to the fly wheel but why do they need to replace the fly wheel did your old starter do a lot of grinding its not to often you have to replace a flywheel unless the starter wrecked it somehow again not to often starters are ment to break before it wrecks the flywheel the flywheel made of harder metel i would get a second opinion on replacing the flywheel
Aug 27, 2009 | 2003 Ford Taurus
Acess to fly wheel bolts
If you cannot turn the engine to get access to the bolts, you will have to remove the converter with the engine as an assembly. It will get messy with trans oil.
Jul 18, 2009 | 1983 Chevrolet Silverado
Chipper won't start
what engine do you have im guessing a briggs & stratton was it running previously or sitting awhile it can be a few things the flywheel key could be sheered or the points are bad or the flywheel & coil are rusted check flywheel & coil to see if rusted if so take coil off mild sand paper like 80 grit i beleave clean both to get the right gap between flywheel & coil turn the flywheel alittle bit so the magnets won't touch coil or if coil still of set flywheel to where it will touch magnets fat peice of sand paper not folded but flat sand paper about .020 gap between magnet & coil if you place sand paper against the flywheel magnet then set coil against sand paper & magnet that should give you 0.020 gap & it should start if not e-mail me i will guide you through everything to get it started
May 11, 2009 | Heavy Machinery
Garden Logo
70 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
