I keep getting a paper jam signal but all paper paths are clear
forgot
  • 17 Answers
SOURCE: keep getting paper jam error message for hp office jet 6210 all in one
check the skew parameters
Posted on Dec 09, 2007
SOURCE: Duplex Path, paper late jam
Can you save that one document as a pdf and print it?
Posted on Mar 31, 2008
FixinFax
  • 3085 Answers
SOURCE: HP 3015 Laserjet paper jam error message
The paper is probably jammed between the fuser and the rear cover if you can't see it.
Posted on Aug 18, 2009
SOURCE: keep getting the error message "Paper jam"
mine does too! help
Posted on Sep 18, 2009
SOURCE: Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Posted on Feb 01, 2010
I have a lexmark e238. Keeps showing paper jam light after cleaning rollers even though no paper is in there.
Either paper is moving too slow through the paper path or one of your paper path sensors is not registering. Pull the paper tray out and check to make sure the little plastic sensor is swinging free. That sensor tells when the tray is empty. Follow the paper path thru the printer checking all the sensors to make sure they are "opening" and "closing".
Apr 07, 2015 | Lexmark E238 Laser Printer
HOW DO I CLEAR PAPER JAM ON KODAK ESP.5
It's probably a fragment or small piece. Look at paper path with a lot of light very carefully. You may need to dismantle to clear it.
Aug 08, 2014 | Kodak EasyShare Office Equipment &...
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Error code 3528 keeps coming up,telling me to remove back cover and remove paper jam then replace back cover.there is no paper jam,checked printer heads no paper anywhere? and paper is not low????
Check the complete paper path very carefully, it only takes a small fragment of paper stuck somewhere to signal a paper jam. Also check that the paper sensors have returned to their normal positions. See that the printer has not picked up a second sheet of paper and this is somewhere in the path.
Jan 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
HP 3005dn Printer Tray 1 paper jam error
If message in display panel reads [13.XX PAPER JAM [LOCATION]]Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken.
Soln.
For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
For message 3.0 PAPER JAM [LOCATION]
means
A non-specific paper jam occurred.
Soln
1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation.
For more help check yhis site
http://www.printertechs.com/tech/error-codes/error-codes-0-19.php
Nov 26, 2010 | HP LaserJet P3005n Printer
"carriage jam. Open door. Clear carriage jam, then press okay" error keeps repeating... tried everything still no change...
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Sep 01, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
XEROX TELECOPIER 7024
Does it say clear jam immediatly or does it start to run then declare a jam?
If it starts then tells you to clear a jam and no paper is in the machine, your feed rollers are shot. Smooth like trying to drive a car on ice.
If it says that all the time, no attempt to feed then you have a sensor either dirty, knocked out of place or something stuck on a sensor.
Either in the paper path or in the scanner.
Mar 26, 2008 | Office Equipment & Supplies
Clear Paper Jam error -- but there is no paper jam!
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects...
Apr 16, 2007 | Canon PIXMA MP780 All-In-One InkJet...
154 people viewed this question
jasbo
jasbo
