Question about Frigidaire GLER331A Electric Dryer
My frigidaire GLER341AS1 shuts off after nearly a minute when turned on. I opened the door while pushing in the safety tap to see if elements were heating and they were. What could be the issue?
  • Frigidaire Master
  • 7,482 Answers
Maybe your problem could be a faulty timer switch...that is where I would check next.
See if the timer is working thru out the cycles, this will tell you if the switch is functioning properly.
Good luck,
I hope this helps you
Posted on Oct 04, 2009
What would cause the blower to run all the time even when heating elements are not on
Sounds like a bad sensor or something stuck. I had a similar problem. the drum would keep turning when I would open the door, turned out to be the little safety button for when u shut the door it pushes that button in, well when I would open it the button wouldn't release it was stuck. So mabey it is just something so simple as that.
Nov 23, 2015 | Dryers
My dryer is not getting hot to dry clothes
That sounds like the heating element has become defective.
You can find the parts HERE if the model is GLER341AS0
You can find the parts HERE if the model is GLER341AS1
Though, I highly recommend you either take it and consult the location you purchased at. Or try calling Sears or Best Buy to see if they can coordinate a repair for you.
hope that helps.
Mar 04, 2011 | Frigidaire GLER341A Electric Dryer
Dryer runs when door shuts. Only stops when door is open
There is a safety switch in the door that shuts dryer off when door is open. If there is more to your problem let me know. From what you have stated there is no problem.
Jun 06, 2010 | Frigidaire FEQ1442ES Electric Dryer
I have a frigidaire mef352bgwd electric oven- after a power outage the lock engaged (door open) and now blinks continually. Tried shutting off breaker for 30 minutes- no change.
There is a pin that tells the oven the door is open, you need to push it in an hold it. It is pretty stiff, you can't use your bear hand. It will be in the upper left of where the door closes.
Jan 07, 2010 | Frigidaire GLEB27S7A Electric Single Oven
How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
Nov 17, 2009 | Kenmore 63942 Dryer
Opened oven door before it could lock while I was
try unplugging the unit,
depending on your exact model it may just be lost in the programming becuse it sensed the door open while locking so it shuts down the lock for safety
just unplugging if for a few minutes might clear the error enough for the lock to rotate back to closed
position
Nov 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire dryer hums when button is pushed in but won't start
ok can u turn the tumbler freely,
if no well there is something stuck in you blower like a sock or something
if the tumbler turns freely
keep the door open and hold the door switch
try pushing the start button
and tuning the tumbler, yes all three at the same time lol you may need a hand
try tuning the tumbler when you hear a hum
if it takes off bad news your start winding on the motor is bad or the capacitor depending on your model
if it does not turn, but the hum continues longer than 1-2 minutes it could be just a belt
Oct 19, 2009 | Frigidaire Electric Dryer
Frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Mar 30, 2009 | Frigidaire Kitchen Ranges
Frigidaire---oven door locks.
On my Frigidaire electric range with flat screen front controls, when the "Clean" control was accidentally pushed and the door locked, I could not unlock the door by cutting power, by running the clean mode for 30 seconds then pushing "Clear", or by hitting any button. What opened the door was holding down the "Clear" button for 30 seconds until the range started beeping and code "F11" read on the led. This worked. Good luck with yours.
Dec 31, 2007 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire GLER331A Electric Dryer Logo
75 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
