Question about Bosch & Tankless LP Hot Water Heater
On-demand Bosch Confort 13 water only works intermittently
We bought a new on-demand Bosch Confort 13 water heater (in Mexico) for our cottage. It seems to only work intermittently, with the burner not turning on immediately, or turning off when still in use. The unit is new, with fresh new batteries for the ingniter. We have tried adjusting the temperature control, as well as the flame intensity control on the front of the unit with no improvement. There is adequate water pressure and volume, and the 5'' exhaust meets specs. My Spanish is OK for traveling, but not good enough to thoroughly understand the manual. Thanks
    Champion:
  • 248 Answers
Will still be under warrent call supplier
Posted on Oct 25, 2009
  • fox8337 Jan 07, 2011
    I had the same problem. I think I found the solution. Your water pressure is too low and the heater is shutting off from overheating. Turn the heater way down so you can run only the hot without scalding. This is working for me. I will be installing a pressure booster pump on the water intake line for the heater.
Bosch Confort S 13 BP tankless water heater won't ignite, It clicks but no gas going thru valve
The S 13 BP is a simple unit that does not have a pilot light. It uses electronic ignition on demand, which is what you hear clicking. If there is no gas going through and you've verified there is gas to the inlet, then it has to be the gas control valve.
Feb 01, 2013 | Bosch & Tankless LP Hot Water Heater
I have a Bosch GWH 425 HNO propane Tankless Water Heater which began intermittently exploding when demand for hot water occurs.
Call a qualified service tech immediately.
Gas explosion indicates dirty combustion parts, and gas is not fully igniting when tankless turns on the gas. So gas builds up and then explodes causing serious damage to tankless, and serious risk to homeowner.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 14, 2012 | Bosch & Tankless LP Hot Water Heater
I have a Bosch Tankless Water Heater Model WR 400-1 KV1 P32 S3100. The water valve has cracked and I need to know where to get a replacement. Thanks
Before calling service technician, open following link for Bosch troubleshooting resources including parts, contact, possible manual, possible service bulletin covering replacement:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 24, 2011 | Bosch Water Heaters
I have a Bosch confort 13 tankless water heater in my Mexico home. I have had problems with consistent water temperature. My contractor told me they have problems with them down there...not sure if it...
Your contractor understand the market there, but problems are mirrored in US also.
As evidenced by fixya.
1) Tankless cannot be exposed to more than 11 grains hard water, and require minimum water flow and water pressure or sensors will shut down burner or element.
2) For example, tankless might turn on with 2/3 gallon-per-minute water flow, but then another faucet is turned on so pressure and water flow drop, and tankless turns off. Or neighbor's water usage causes decrease in line flow, so tankless turns off. This is called 'cold water sandwich.'
3) If problem is water pressure, you can add in-line pressure tank, but root causes vary widely with more than one factor as suspect.
4) Also incoming water temperature can be a factor, along with temperature setting of unit. Most tankless are preset to 120 degrees F, which is modest temperature and certainly not very high. If tankless cannot raise temperature of incoming water fast enough, then tankless turns off. Of course water flow continues, so you get dose of cold water.
You can add simple120Volt 30 gallon tank-type electric heater as a tempering tank that pre-heats water either passively or actively: http://waterheatertimer.org/Tempering-tank.html
5) Both internal and external factors affect tankless, with bottom line that these high-tech devices are not do-it-yourself repair for most people.
6) Install DIY tank-type gas water heater and avoid the whole headache
http://waterheatertimer.org/How-to-install-gas-water-heater.html
7) In my opinion, the genius of tankless is not that they save money or energy. Because they don't.
The genius is marketing that targets a certain affluent who believe tankless save money and energy.
http://waterheatertimer.org/pro-n-con.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 22, 2011 | Bosch Water Heaters
Bosch tankless hot water heater: Confort TOO HOT!!!
Look for a water temp control on unit. Otherwise a lower temp can be attained by having a higher water flow to minimize temperature buildup in heating coil.
Sep 06, 2017 | Bosch & Tankless LP Hot Water Heater
I have a Bosch GWH 425 HN Tankless Hot Water Heater...On 2/28/2010, it began intermittant exploding when demand for hot water occurred. Local technicians worked on the unit several times, changed and...
I have the same problem with the same model. The problem has been identified by a friend of mine, correctly, I think.
This is a very dangerous problem involving Bosch's much touted safety feature, ironically enough. IT IS THE FLAME SENSOR IN THE GAS VALVE. The flame sensor is supposed to confirm that the pilot has lighted BEFORE the main gas line sends gas to the main burners, after which the pilot shuts off. The pilot light is not coming on, the sensor that shouldn't let gas fto the main burners is failing and the main gas is flowing and ignighting from the spark that is supposed to light only the pilot in a big explosion.
This is the 2nd unit of this model that has failed. I think Bosch should do a recall
Apr 25, 2010 | Bosch & Tankless LP Hot Water Heater
I purchased an aqua star 1600h-lp to be installed in a cottage. Question is, the cottage is heated with a large wood stove/fireplace. The water heater is located in a bathroom at the other end of the...
I would say that the wood fire/stove must have a heck of a draw to affect the bathroom heater. Maybe a separate air supply from outside via a pipe,to the stove meshed off against vermin would decrease the problem. Plus it could stop cold air being sucked across the room from an outside door.
Downdraft through the heater could happen with either vertical or horizontal vent. More important is the direction of the prevailing wind [horizontal] ingress of water/snow etc [vertical]
We often use the separate air supply in the UK and if the pipe bore is large enough 4" plus it seems to work ok.
Mar 20, 2010 | Bosch & Tankless LP Hot Water Heater
Bosch on demand tankless water heater gwh 2400 E LP error code "
BOSH AQ 250 On demand propane water heater ran out of propane, got gas now, but get EC flashing on the display and the unit won't fire? Lost manual, any suggestions. Thanks, Jim
Jan 06, 2010 | Bosch AquaStar 2400ES-NG
Bosch & Tankless LP Hot Water Heater  Logo
990 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
