Question about Nokia N95 Cellular Phone
Lights ok in my n95 8gb but no display - Nokia N95 Cellular Phone
My n70 mobile keypad light does not work and display light throbing please help
first check these led properly if ok then check the resistance near led if ok then apply a jumoer from display led to keypad ld
Jun 09, 2013 | Cell Phones
Display Light on Jandy wall remote
check at aqualink take off front panel see if 4 pin red connector is plugged in if ok see if wire is cut if ok need new display board or make a cheater cord and plug in at aqualink if ok need new wire to controller if no display replace
Mar 15, 2012 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Screen wont light up
connect with external monitor or tv.
if works ok you have problem with display or the cable that connects the display with motherboard. If your model is too old maybe you have problem with inverter.
Feb 17, 2012 | HP Pavilion Computers & Internet
I have a full memory need to delete files and forgot how
Here are some steps to delete a file in your Polar watch.
Deleting a file
1. In the Time of day display scroll up or down until FILE is displayed.
2. Press OK to enter the File mode.
3. Scroll up or down until desired exercise file is displayed. Press and hold
the signal/light button. DELETE FILE and file number are displayed.
4. Press OK. The wrist unit confirms if you want to delete a file
(Are you sure).
5. Press OK to delete the selected file.
6. Press stop to exit the file. Wait appears. The wrist unit rearranges your
file, which takes few seconds.
7. Repress stop to return to the Time of day display
Deleting all files
2. Press and hold the signal/light button. DELETE FILES is displayed.
3. Press OK. The wrist unit confirms if you want to delete all files
(Are you sure).
4. Press OK to delete all exercise files.
5. Press stop to return to the Time of day display
For more information, refer to manual of the watch.
I hope this will be able to help you.
Thank you for choosing Fixya.
Mar 16, 2011 | Polar S S625X Wrist Watch
Requested sir, My Intel motherboard problem CPU power on, cpu fan ok, keybord light ok, mouse light ok,RAM ok,no RAM beap,no display beap,no display???
Try resitting Memory modules Re-seat vid card if not integrated ,If integrated try
a PCI video card or AGP slot whatever is available integrated video may be defective
usually reinstalling memory and or video card fixes this
Feb 14, 2011 | Computers & Internet
W200i-keypad light ok,no display light
its hardware fault i think lcd fault try to change it
Feb 12, 2011 | Sony Ericsson W200i Cellular Phone
6030 display light problem:
check power supply for light coil is ok or not 3.7 volt if not make jumper from k47 reg to coil
then
change light ic
then
change display and display connecter
Nov 21, 2010 | Cell Phones
Nokia n95 8gb no disply but lights ok
go to a mobile service.the connectors from the display are gone or they moved
Sep 02, 2009 | Nokia N95 Cellular Phone
NOKIA 3315 display not showing any thing
nokia 3315 display not showing anything its ok
Apr 13, 2009 | Nokia 3315 Cellular Phone
Programming handset
Put extension phone on base unit; press menu; press 0 0; press and hold intercom until charging light starts flashing. the display should show OK on the display screen of the extension phone; press OK. If you have more than one extension to add:
after you press 00; the symbol for # # # will come up. Enter a number for that extension i.e. 2; 3; or your choice.OK will come up on display at bottom right of display; press ok. hope this helps. This info should come on the extension phone and "menu" is on ext. unit. So turn the display up so you can see it while it is on base unit.
Jan 15, 2008 | Panasonic KX-TG5632 Phone
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
