Question about Sunbeam 5833 ExpressBake Bread Maker
Mixing paddle won't turn.
The mixing paddle won't turn on my breadmaker Model 5833. The spindle seems to be locked up.
  • 433 Answers
The mixing paddle is supposed to turn by means of a lubricated bearing. This bearing is broken or stuck so the blade will not turn.
Try soaking it overnight in soapy water. If that does not work it's time for a replacement pan if you can find one.
Hank
Posted on Oct 05, 2009
The spindle that holds the paddle won't turn. It's stuck tight.
It may be hard to turn by hand but does it turn when the machine is
turned on? If so it is OK even if you can't turn it by hand
Nov 28, 2012 | Breadman TR555LC Bread Maker
I have an old toastmaster bread machine model 1154, and I realized that the kneading blade does not rotate when the ingredients are in the bread pan. Either the kneading blade mounting shaft and the...
If the spindle is turning and the paddle is not then your paddle is worn out and probable slipping on the spindle. If the spindle isn't turning then your problem is underneath the pan or inside the drive and your paddle may be fine.
Dec 01, 2010 | Toastmaster Kitchen Appliances - Others
Hi there! I've been using my toastmaster model 1142 bread maker a lot lately like almost every day and it has stopped mixing the dough. Once the dough is dense the motor sounds like its running but the...
Pull the pan out and turn the little paddle with your finger. Is the paddle slipping on the spindle? If yes, then your paddle is worn out. If you move the paddle around and it doesn't slip on the spindle then look to see if the ears on the bottom of the pan are turning too when you move the paddle. If yes, then your problem is further down in the machine. You may have a slipping belt. Those are some of the things you can check.
Nov 07, 2010 | Toastmaster 1142 Bread Maker
Bread Maker stir paddle does not spin
Either contact the manufacturer, or remold the interior of the paddle hole yourself. How? Using something like JB WELD. Place a peice of plastic wrap over the metal spindle, spreading it not only around the spindle but 2-3 inches outward like a skirt. Mix the epoxy (I recommend JB Weld) and place a small blob over the spindle. Pack the hole in the paddle with it. Now, place the paddle back over the spindle and let the epoxy set-up overnight.
Because of the plastic, the paddle should lift up off the spindle. Using a carving tool, a hand grinder, or sandpaper and elbow grease, remove the excess hardened epoxy. The interior of the spindle hole should be good-as-new.
OR, find A STORE that sells breadmakers, and find a paddle that will work on yours, and 'borrow it' (a your own risk, shoplifting is a crime).
Feb 03, 2010 | Breadman TR850 Plus Bread Maker
Kneading paddle is baked into bottom of bread loaf. Is this normal?
Yes, this is a common occurrence.
Nothing to worry about unless you chow down and forget to remove the paddle(s). :)
Since the paddle(s) stays in the pan after the kneading and through the baking process. The bread can trap the paddle(s) as the batter cooks.
We have gone through 3 different bread machines and over time all eventually did this. A little wear on the spindle will loosen the paddle(s).
Hope this helps!
Dec 26, 2009 | Sunbeam 5833 ExpressBake Bread Maker
Paddle spindle has come loose from breadpan
Hi pasternak194
It looks athough the small circlip (shaped like a horseshoe) may have come of the end of the spindle.
This holds the spindle on the end of the driving pin.
(I may be wrong)
You need to contact the manufacturers or have a word with someone who can supply these things.
Kind regards
Alleluia
Dec 02, 2008 | Sunbeam 5833 ExpressBake Bread Maker
Paddle won't turn in the breadmaker with any resistance
It is the little metal plate that locks the paddle shaft to the big sprocket. the little flat spot is worn away. now where do I get a new one, it is may be worth a penny.
Jul 04, 2008 | Kitchen Appliances - Others
My breadmaker is not turning properly.
Try either turning the paddle slightly until it aligns with the "gear" under the bottom of the pan.
I've also pressed the start button, and when the mixing process began, managed to push the pan down until it's engaged properly.
Apr 16, 2008 | Sunbeam 5833 ExpressBake Bread Maker
Bread not rising enough
We had exactly the same problem. We contacted Panasonic who supplied bogus "advice" about changing the type of flour and using more water. We eventually discovered the reason for the problems: the mixing paddle was now a loose fit to the spindle. Part way through the baking process it would stick. We also have a solution. You jam tin foil in the gap between the spindle and the paddle, it works a treat. Don't waste you money on a new paddle, this won't be a tight enough fit.
Oct 24, 2007 | Kitchen Appliances - Others
Sunbeam 5833 ExpressBake Bread Maker Logo
1,012 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
