Question about Ovens
Burner heats to high even when set on low
I put the burner on low, but it continues to heat to high and beyond. One other burner stays warm even when you turn it off.
  • 725 Answers
Are you talking about the cook-top part of this unit or the interior of the oven? If it's the top part, your infinite switch is out. If it's the interior, it's one of the elememts. If you will give us a call as soon as you get a chance, we'll make sure and get the correct part out to you right away to get this repaired. We look forward to working with you and getting your oven fixed BEFORE Thanksgiving. 972-859-0929
Posted on Oct 05, 2009
We have a Bosch ceramic hob model no 9000329649, cooking with rear 2 rings yesterday. They will not switch on, front 2 are OK. Grill and oven fine.
check them with a meter and check the infinite switch's also
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
1.If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons. (Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful.
2.On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires.
3.Set your multimeter to ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective.
4.Repeat the step above for the terminals "L2" and "H2".
5.If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced.
6.With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance.
7.A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed.
If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. )
Jan 10, 2017 | Bosch Ovens
The grill on my Stoves 059050517 cooker will not stay on. It gets warm but not hot and the ignition comes in every few seconds. This problem does not always happen and appears to occur randomly.
Surface burners
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
: rememberI offer free advice bcuz God is so good!
May 20, 2015 | Stoves Ovens
Oven light on - oven warm - but not heating up at all!
If the timer feature is activating and you have not touched the timer button at all, this would have to be a failed Electronic Oven Control. The timer button is either shorting at times or closing on its own from heat or moisture. The Electronic Oven Control would need to be replaced to repair the problem.
Or Why does it take the oven so long to bake?
When the food is taking way too long to bake, it's probably a weak bake ignitor. Replacing the ignitor usually fixes this problem, but you probably want to verify that the ignitor is the problem before replacing it.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element
The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Before testing the heating element, unplug the appliance or shut off the power at thefuseboxorbreaker panelto avoid an electrical shock hazard.
When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps.
First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring.
Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element.
Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity.
Test theresistanceof the heating element using amulti meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be.
To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continuity at any time, the heating element is defective and should be replaced.
The reason for my free advice is GOD is good!
Apr 20, 2014 | Belling Ovens
PLEB30S9DC8 low heat
Oven comes on and off intermittently or heats very little:
ALSO Test the Burner Heating Element The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Why is the oven temperature incorrect?
The oven temperature control is usually controlled by a thermostat that uses a capillary and liquid filled bulb. When the bulb's liquid gets heated up, it expands and puts pressure on a diaphragm which opens and closes a switch that controls the gas to the burner. Just set the dial to what you need the temperature to be. Over time, it is possible for your thermostat to lose its calibration. Sometimes, the thermostat sensing bulb comes loose from the holder. If it is out of place, the thermostat may be getting faulty readings. If this is the problem, re-aligning the bulb properly will take care of this problem.
Digital display models use a sensor to control temperature. If this is faulty, replace it. Other ovens use a mechanical system to control the temperature.
On many models, you can adjust your oven thermostat using a small screwdriver. The adjusting screw is located on the thermostat valve stem. Remove the knob and you'll see the screw underneath it. You want to turn the oven on and run it through at least two cycles while watching a calibrating thermometer in the oven for high and low temperatures. Adjust the screw as necessary to fine tune the temperature.
Some models don't have an adjustable thermostat, and you will have to replace the thermostat if you want to resolve the problem.
Mar 20, 2014 | Frigidaire Ovens
Kenmore oven does not heat evenly
Feb 10, 2014 | Kenmore Ovens
I put burner on lowest setting but it goes on high heat.
Sounds like you need a switch for that particular burner. The switch is the component that controls the level of heat of the burner. Hope that helps
Aug 28, 2011 | Ovens
Ovens Logo
65 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
