Question about Ovens
How do i set the controls to have the oven clean it'self and how can i get a new manual
    President:
  • 1,714 Answers
How about a complete model number and make?
Posted on Oct 04, 2009
I don't know how to clean the oven
Hello OTCHENASH...
Make & Model would be really really really helpful here!!!
if It's a NEW STYLE self cleaning oven... read the new manual.
or
if It's a OLD STYLE self cleaning oven... read the old manual.
It makes a HUGE DIFFERENCE...
Any advice here could fly right in the face of what you
owners manual dictates
You TYPICALLY remove the shelves.. and prep the interior with a warm sponge... to pick of loose particles.
Sets the controls for clean... return WELL after cool down.
Make sure the interior surface is cool to the touch... and
ONLY THEN :
Clean up the ash with a damp sponge!
Clean and return the shelves... and you are good for your next mess.
If it is not SELF CLEANING... get out the HAZ-MAT suits..
Again... remove shelves food, etc.
Open windows... Read the CAUTIONS on the label...
Follow those directions VERY CLOSELY... Else...
Get dressed and go out and by a new oven.
Happy hunting!
Mar 27, 2016 | Ovens
Cant unlock oven door
Hi, unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door. If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
*Note: Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Dec 18, 2010 | Frigidaire 30 in. Electric Gallery Pro...
I have a Kelvinator (used) self-cleaning oven with no manual. I would like to know how to set the dials for cleaning the oven.
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 27, 2010 | Ovens
Manual for Self Cleaning 30" oven: Time to self clean
i think you would set it for an hour. because thats what i do on my self cleaning oven. or you could set it as long as you want.
Dec 18, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I cant get my self cleaning oven to unlock... what do I do, I cant find my manual
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Oct 10, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Self Cleaning Oven help
It should run with you setting anything but clean. You can obtain a copy of the owners manual from the maytag site or by googling your maytag appliance model number.
Dec 24, 2008 | Maytag 24" Built-In Single Electric Wall...
Kenmore electric stove
Hello d_i_a_n_a18,
In order to put most ovens into the self-clean mode, there are a series of steps that must be initiated in a specific order. On most units the oven control needs to be set to bake or clean and the temp. control needs to be set to clean and the door lock mechanism must be engaged for everything to work. I would suggest that you consult the user's manual for directions for your specific model. If your manual is not available, check on line at the kenmore parts web-site and you can usually get a PDF version of your manual. Good luck.
Nov 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
How to use self cleaning oven
  • When using the self-cleaning feature on your oven, the temperature within the oven rises to an extremely high temperature, usually around1000 degrees. The oven will remain at this temperature for a set periodof time, often from 1 to 3 hours.
  • Self-cleaning ovens differ from traditional ovens in that they require a timer to control the amount oftime that the self-cleaning feature operates. They also require extrathermostatic controls to control the extremely high temperatures.
  • While the mechanisms inside aself-cleaning oven are quite complex, the concept behind aself-cleaning oven is fairly straight forward. The extremely hightemperatures incinerate dirt and debris from your oven, thus cleaningit for future use.
  • Safety is very important when using yourself-cleaning feature. You must ensure that the oven door is completelyclosed while the self-cleaning cycle is running. 1000 degreetemperatures are obviously extremely dangerous. Self-cleaning ovenswill come equipped with a secure oven door latch for this reason.
  • The crucial door locking system isinitially engaged to signal that you are ready to use the self-cleaningfeature. When the oven reaches a certain temperature, the door locksystem will ensure that the oven door cannot be opened until the cycleis complete and the temperature has returned to a manageable level.The result is a clean oven without the use of harsh oven cleaners orabrasives.
REMEMBER YOU ARE WORKING WITH 220 VOLTS - USE EXTREME CAUTION!!!
Nov 11, 2008 | Ovens
Self cleaning oven
here is the link where you can download the owners manual for your stove.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318200919en.pdf
you may have to copy and paste this into your browser. and it may take it a min to load.
please do not forget to rate and comment about your experience today on fixya.
Aug 17, 2008 | Frigidaire GLEB27S7A Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
