Question about AMD Sempron 2800, 2.0 GHz 2800+ (SDC2800DUT3D) OEM / Unboxed Processor
When i turn it on i get a strange beep beep beep and pause?
    President:
  • 2,666 Answers
That would indicate a RAM problem. Try removing and reseating the memory cards.
Posted on Oct 04, 2009
Computer won't come on
All computers have beep error codes, if you provide the following details I may be able to help.
1 Make and model of PC
2 error code ( you can count the code for example: 123 could correspond to
Beep - pause- beep beep - pause - beep beep beep
3 does the fan turn
4 does the monitor turn on ok
5 can you hear the hard drive an DVD rom spin a little then go quiet or do they spin and then chuntle on for a little while
Nov 25, 2016 | Computers & Internet
I'm trying to recover my system, but everytime I push F11 to get to the System Recovery Manager, I get a repeating Beep.
That sounds like it might be "POST" code beeping out at you. If it goes beep beep beep (pause) beep beep (pause), or something like that, etc.... then it is definitely a POST code. It can be anything from a bad or unseated video card, to a loose memory DIMM card.
The computer's BIOS chip is hardwired to a dedicated speaker, if something goes wrong (like your video card is roached), it beeps out a series of beeps (not unlike Morris code). Check the manufacture's website, see what BIOS your model is using (AMI, PHOENIX, ETC..), and then look up their website to interpret the code you are getting. The computer Mfg.'s manual might also have that BIOS POST code information in it too.
Please give more detailed information about the beeping sequence. Like, does it ONLY beep after pressing the F11 key once, or because your holding it down (keyboard buffer is full then). Are the beeps continuous, or are their pauses between beeps (if pauses, count number of beeps between pauses until it repeats, usually has a long pause before it repeats if BIOS POST CODE). Also, did something happen just prior to your computer going belly up, or did it just not want to turn on one day? Give as much information as possible (make, model, OS, etc) about your computer, and what its symptoms are. The more info I have, the better I can help you.
Jul 29, 2011 | Computers & Internet
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
Apr 06, 2011 | Computers & Internet
My t42 laptop's screen froze the other day so i turned it off and when i turned it back on the screen stayed black and beeped four beeps then pause then four beeps then pause then four beeps then pause...
keep pushing f2 now youll see the page use arrow keys change your boot log f12 now restart it back up on a f12 now it going ask you do you want run windows go there.
Feb 05, 2011 | IBM ThinkPad T42 Notebook
When I go to turn on the computer, it just makes a beeping sound.
Beeping sound leting you something is wrong with some hardware. As for what,, listin to the beeps.. also depends on motherboard... here is a link http://www.pchell.com/hardware/beepcodes.shtml
But best way is to open up machine and make sure all the hardware is hooked up tight. If that does work look at the code list then go from there.
Sep 09, 2009 | Acer Aspire X3200 PC Desktop
Computer problem
during these beeps there should be pause between them at some point...in other words you may get 2 beeps/pause/1beep/pause/2 beeps noting the number of beeps and where the pauses are will help. From what you are describing and without more info it sounds as if you are describing beep codes, and they generally can give us a lot of information.
Aug 09, 2009 | Computers & Internet
Dell precision 3100 machine will not boot up
If your computer is beeping at you, 9 times out of 10 its going to be an issue with the memory or video. (more often the memory) Try re-seating both. If your still hearing the beep fest, below is a list of the most common beeps and what they refer to. This will help you to find out what needs replacing.
Long beep followed by 3 sequential short beeps. This issue is linked to your Graphic card configurations
Short beep followed by three sequential long beeps You are facing a system memory problem
Beep- PAUSE- Beep- PAUSE- Two sequential beeps This error is linked to your CPU
Three beeps-PAUSE-Three beeps-PAUSE-Four beeps You have an issue with the video memory
Three beeps-PAUSE-Four beeps-PAUSE-Beep This is linked to an error with your Graphic Card
Four beeps-PAUSE-Three beeps-PAUSE-Beep You have a system memory problem
Five short beeps You are facing a problem with your CPU
Long constant beeps It’s a system memory problem
Short constant and high-pitched beeps The temperature of your CPU is too high
Jan 05, 2009 | Dell Dimension 3100 PC Desktop
Beeping with no boot up
Beep codes mean something has gone wrong with the computer. Beep codes most likely happen for: Memory, Processor, Motherboard.
Try reseating the memory in the computer.
Jul 11, 2008 | AOpen XC Cube EZ65 Barebone
AMD Sempron 2800, 2.0 GHz 2800+ (SDC2800DUT3D) OEM / Unboxed Processor Logo
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
