Question about Dyson Vacuums
Dyson Ball makes high pitched noise
Dyson ball vacuum is making a high pitched noise
    Master:
  • Dyson Master
  • 894 Answers
Hello, this is Ava with Think Crucial.
To fix any noise issues that your Dyson vacuum gives, a proper maintenance will do the trick. Most of the time , cleaning the filters, checking for blockages and clearing the passageways will eliminate the noise. Please refer to your operational manual how you can do this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Posted on Jul 06, 2017
5 Suggested Answers
albertjunior
  • 56 Answers
SOURCE: it makes a loud high pitched noise but it still
sumthing is blocking the suction....
Posted on Oct 06, 2009
ThinkVacuums
  • 144 Answers
SOURCE: The brush on my dyson ball DC24 will not turn on-
That noise you're hearing is the clutch, which is expensive to replace and difficult to change.
If you want, you can still use the vacuum for bare floors but that noise will always be there. Using it for anything else won't work.
Posted on Mar 23, 2010
Dysonteam
  • 167 Answers
SOURCE: I cleaned out my dyson ball as it smelt when i
Hi its Darran at Dyson.
The screws on the base of the cleaner head should not have to be removed to access the brush bar so it is possible that the brush bar has come out of alignment, hence the noise the machnie is making.
Please ensure that the soleplate has been correctly positioned and that the brush bar is aligned correctly before attempting to use the machine.
If this does not resolve the problem, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Posted on Apr 19, 2010
  • 9 Answers
SOURCE: The Dyson roller ball vacuum I have is making me
Check that you dont have anything blocked in the roller, if all is clear there is a little red button on the side off the roller. Push this in and this will reset the roller... If that doesnt work, check that it is switched on with the switch next to the power button.. That should solve your problems
Posted on Oct 04, 2010
Valve on top of filter container keeps closing?
Hi Kim,
Thanks for your question and I am sorry for the delay in contacting you.
The valve on the top of the cyclone assembly is commonly known as a 'bleed valve' - it is to allow air into the machine when there is a blockage. This often produces a high-pitched whistle or noise.
I would recommend washing the filters and checking for blockages - you can see this on the following webpage under 'Maintaining your Dyson machine'.
Support forDC15 The Ball Animal
I hope this helps but if you continue to have difficulty, please give the Dyson Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK). Our experts will be happy to talk you through some further diagnostic checks when you have your machine easily to hand.
Many thanks,
Allan
Jan 09, 2016 | Dyson DC15 All Floors - The Ball Bagless...
Ball makes a clicking noise every 0.25 metres. Please help
Please read this answer all the way through there is something that may be relevant (strike out 'important') at the end !
Maybe it's this
"clip that holds the filter in place and the locating lug of the access flap to gently rub together as the ball rotates and create a slight clicking noise as the appliance is moved around (though is not routinely noticed due to the motor noise)"
(from Fully Cleaned Serviced Refurbished Dyson DC25 Animal Ball Vacuum Cleaner )
stop press - I just saw this - if you do not have proper Dyson brand HEPA filters - see end of answer - you may get a loud clicking sound....
The manual tells you about removal and cleaning HEPA filter - the All floors version has one as well)
Otherwise I can only refer to Dyson support, there are various ways of contacting them given at the top right of this webpage Support forDC25 Multi Floor
(the user guide manual is downloadable from this webpage)
Sounds to me as if maybe there is an irregularity on the ball that is contacting the body/ball housing every time the ball does round....unfortunately this makes the ball diameter ~8cm which too small.
18.April.2015
Beware Some After Market DC25 Filters Do Not Fit Correctly March 2014
Apr 18, 2015 | Dyson DC25 All Floors Bagless Upright...
My DC24 is very noisy. What can I do?
Hi Nena, it's Jack at Dyson.
If your DC24 is making an unusual noise in use, our experts would need to listen to this over the phone to diagnose the cause and resolve the issue. It could be something as simple as a part or seal which is slightly out of place.
When you have your machine easily to hand, please call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a repair or replacement part is needed, we can also confirm if this is covered under your Dyson guarantee.
We'll look forward to speaking with you.
Oct 18, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Clicking noise
Hi there, it's Jack at Dyson.
A clicking noise from the ball suggests the washable HEPA post-filter may be out of place. This is simple to resolve - the video below shows how to remove the ball shell and re-fit the filter. As you push it back into position, you should hear it lock securely with an audible 'click':
I'm confident this will resolve the issue for you. However, if you would like some further advice from our experts, you can reach them by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 13, 2014 | Dyson DC25 All Floors Bagless Upright...
Dyson high pitch noise
Dear Tasha ,
I suggest that you clean out the tubes and see if any paper has been rolled into the bottom. P.S. Do you know how tall 170 cm is in feet.
Feb 25, 2014 | Vacuums
Filter whistle noise
Hi Basil,
I am sorry to hear your machine is emitting a high pitched sound. Based on the details you provided the problem may be isolated to the post motor filter, if so a new filter will be needed. We would like to help with this. Please contact our Helpline to speak with an expert:
US - 1-866-693-9766 or UK - 0800 298 0298
Best wishes,
Jessica
Sep 01, 2013 | Dyson DC25 Vacuum
The ball is not rolling freely on the dyson dc 25 upright it sticks and makes a noise as the vacuum is pushed
Inspect closely while spinning the ball looking for a rubbing or restriction. Look for a crack or debris that could be causing it. Remove the ball shell to inspect it looking for cracks, check the bearing and the area the ball shell connects to the vacuum to try to find the cause.
Aug 14, 2010 | Dyson DC25 Vacuum
The brush on my dyson ball DC24 will not turn on- it makes a bad noise if I try--
Mar 22, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
I cleaned out my dyson ball as it smelt when i hoovered, cleaned filters, washed out canister and took the screws out of the front bar so i could clean near the brushes.. now its making a high pitched...
Kind regards
Darran
Feb 24, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Dyson motor making high pitched noise. Is this
Most likely, there's something in the dirt tube. Ic could be something like a piece of paper or cellophane, vibrating from the air going over it. without hearing it, a high pitch noise could be different things.
Jun 13, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
618 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
