Thier is a red streak across the screen of my Sony projection TV (54"). how do I Repair?
  • 74 Answers
SOURCE: Red streaks across my screen of my tv
is it like a double image kind of thing?i dont know what 'red streaks' are....
Posted on Oct 10, 2008
SOURCE: KP-57WS500 57 in Sony Rear Projection
I had the same problem with my sony KP-57ws500 rear projection tv and thanks to the thread I fixed it in 10 minutes. At first I thought it was a white curved line but then after a closer look it was a very light green curved line. To solve this problem all you need is a flat and phillips screwdriver. Right below your speakers on the right and left side are tabs. Pull out the tabs and remove the screw on eachside. Once that is done remove the speaker cover. The two screws at the bottom are the only screws and you just have to wiggle the facing off by pulling out and down. You will see a fiber board cover in the middle of the tv, there will most likley be twist ties holding some wires, to make it easier to work remove the ties. Now remove the screws on the fiber board and pull it off.
You should see 6 adjustments screws. on the top for is focus, do not touch those.
Below the focus adjustments are the Red, Green, and Blue. The adjustment is slight so turn the correct color slowly and don't push hard on the screw. I had to turn the green to the left to get the lines to disappear and it was only about a 1/32 of a turn. Very very slight. Good Luck.
Posted on Feb 05, 2009
  • 135 Answers
SOURCE: Pink bar across top of tv screen
This could be from 2 things. 1 is the optical block is going bad or 2 you got a peice of dust blown in from the cooling fan and its blocking the color filter internally. If you are capable you can take the tv apart and blow compressed air into the color block and remove the dust. Hope this helps
Posted on May 25, 2009
Wise Frog
  • 13 Answers
SOURCE: Sony wide screen projection tv model kp-57wv600.
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Posted on Aug 05, 2009
supertech6
  • 513 Answers
SOURCE: sony kdf-55e2000 tv
This indicates problems with the image engine. (Lamp does not control the colour). If the TV has not been cleaned recently, excessive dust build up internally may have overheated the image engine. If Sony will not cover it, you might want to consider a new TV.
Posted on Apr 21, 2010
Testimonial: "thanks, tv is only two years old and don't want to buy another one. Hope it is not the image engine."
I'M HAVING BRIGHT RED BOWED STREAKS ACROSS THE SCREEN AND DOUBLE VISION LETTERING
Sounds like a convergence problem. This means 2 Chips need to be replaced by a qualified tech.
N Sabre
Nov 08, 2009 | Akai PTH5498 54" Rear Projection...
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Picture turned red then tv turns off
The red picture tube is bad, you must replace before it cause damage to the boards.
Feb 24, 2009 | Sony KP-57WS500 57" Rear Projection...
Oct 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Red line convergence problem on KP-57WS510
Yes replacing the ic's should solve it. It worth a try if you want to spend the money
Jun 02, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Red shadows and mild distortion
Hi, relasmith did you ever fix your tv kp-57ws510
thank you
Apr 03, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Hitachi 53udx10b
sounds like convergance amp ic's see links below
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
· http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
· http://www.hdtvoice.com/voice/index.php?s=
Jan 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Red and Green flashes
Possible CRT coolant liquid leak onto circuit board.Check
for moisture evidence....................T.
Nov 03, 2007 | Samsung PCL5415RB 54" Rear Projection...
Sony KP-51HW40
I had the same problem with mine 2 years ago (TV was 1.5 years old at that time) I had extended warranty on TV and it was fixed by Sony at no cost to me. Now yesterday I have another problem with it. All of a sudden screen went BLUE. No Sound either. It could be the CRT (That's what I read here) Out of luck this time. Will call local Repair shop (70 miles away) and see how much it will cost to fix it. Good luck.
May 31, 2007 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
