Question about Microwave Ovens
Microwave...after a few seconds it starts sparking
I have a samsung microwave...after a few seconds it starts sparking under the round panel in the top right hand corner..it is only a few years old....I took the top panel off and there is a metal disk inside..do you have any suggestions Thanks
    President:
  • 1,564 Answers
The main unit in a microwave oven is called a magnitron. When these units get to a point of fault they do one of two things, they get weak or they get dangerously sttrong. You appear to have option two, and I would suggest a replacement unit ASAP. Do not use this machine for the output of waves is no longer being directed through the "normal" channels and it has become dangerous. Thank you, Dana
Posted on Oct 04, 2009
    Problem Solver:
  • 12 Answers
OMG,
first thing, THROW IT AWAY!
These panels are in place to protect you from radiation that the microwave puts out to heat your food. Under no attempt should you use this piece of equipment, or attempt repair!! Either use the warranty program to send off and get repaired, or throw it out and buy a new one. I have found that even sending one for repair the owner is responsible for two way shipping, and that is usually half as much as a new microwave!
good luck,
Jay
Panasonic 1250w genius senor inverter less then a year old. Control panel lights up, works.microwave itself does not, control panel shuts off in a few seconds
When a Panasonic Inverter Microwave shuts off after a feew seconds, it is either a bad inverter which is the quite expensive circuit board that powers the magnetron that puts out the microwave energy, or a bad magnetron, Or BOTH typically this would be a costly repair, But since it is still under warranty. You need to find a Panasonic warranty service provider in your area. If it is a counter top unit, you may have to take it to them for repair.
Jul 05, 2017 | Panasonic Microwave Ovens
Our base inside the machine won't go round
Sounds like the motor has blown, I did have this once before and I found by taking the glass plate out and turning motor top where plate rests on by hand a few times it started to work again but it might be gone anyway, you might be able to get a second hand one but a new one is about 30 pounds so might be advisable to renew machine.
May 10, 2014 | Sharp R-1405 / R-140 Microwave Oven
Samsung microwave se error
see the video attached. God bless you
Dec 09, 2013 | Samsung MS1040BB Microwave Oven
Samsung se error keeps coming back
i think your getting to much moisture in your microwave the exhaust fan is to small and can't handle it. once everything dries out you are able to rest it check with samsung.
Dec 13, 2012 | Microwave Ovens
SParks and smoke from microwave
it may be repairable but not by yourself
take it in for a quote and proper diagnosis
Aug 31, 2017 | Panasonic Microwave Ovens
5E (SE) error showing on my samsung C106FL micowave oven (2 years old). None of the other keypad buttons are working. I unplugged the oven & re-plugged next morning but still saem result. Pls help.
The "SE" error indicates a shorted membrane keypad.
You can find support from Samsung in India here.
Dec 18, 2010 | Samsung MC5694 Microwave Oven
It displays SE and nothing works.
SE error means you have a shorted membrane keypad.
With your model number I can detail your options.
Jul 02, 2010 | Samsung SMH7178STD Microwave Oven
GE Profie JE1860SH 04 microwave sparks
Our JE1860SH was also sparking after a few seconds. The GE tech pulled the upper round disk and found the problem. The plastic was burned and the round metal which is behind the plastic dome was arching with the frame. Lasted seven years expected more especially from a GE product. So my suggestion is to remove the dome and check it out.
Jan 03, 2010 | GE Profile Spacemaker Over-the-Range...
How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
Jun 25, 2009 | Frigidaire FMV156DC Microwave Oven
Sparks inside the microwave
remove the round button(s) and remove the cover..clean thoroughly and replace anything thats burnt, if metal clean and paint touchup
Jun 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
97 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
